Slime does not act as a balancer, only a sealant.
Me, I would rather fix the tire, I used some fix a flat on my 3 MPH lawn tractor but that is about it.
Did you use the tube formula?
Can someone tell me how a slime substance can work as a balancing agent even at the best of times?
I'm an engineer, and I, too have wondered how a semi-liquid substance can act as a "balancer" in a spinning tire. The physics just don't work in an intuitive sense, but maybe they do in a physical sense. If the stuff remains semi-liquid, then I can understand the need to balance before adding it, because it should distribute evenly about the inner circumference, adding a net effect of zero. But if the inner circumference were dead concentric, but the center of mass were off-center (an un-balanced wheel/tire combo), as Huzo said, how does the liquid migrate to the right spot to offset the off-center mass?Doesn't make sense, BUT, the testimonials for Ride-on all say it works. However, I'm going to get the wheels balanced before adding it, just so I KNOW I have a balanced starting point.
I can imagine a liquid might achieve balance at a steady speed.....London messenger riders have stated that the highest percentage of punctures were eliminated by the use of an inexpensive, simple device: a front mud flap.
1) if the wheel is out of round, the liquid will fill in the part of the tire that is furthest from the axle under centrifical force. If the liquid is the correct density (or close), it might balance the wheel at a steady speed.2) ever notice that most of your flats are on the rear tire? This happens because the front wheel kicks up road debris and the rear tire goes right through this elevated and sometimes pointy stuff. The mudflap keeps all those nails/cotter pins/deck screws low or out to the sides, drastically reducing your chance of a puncture. The $11 model I use is visible in this photo:
