Author Topic: road testing Guzzitech reflash on my '14 V7  (Read 3475 times)
Offline ratguzzi
    • road kill
« on: October 19, 2016, 03:07:59 PM »
https://youtu.be/CC26g4_gp94
Clear road, good visibility......... ... I knew the reflash would help but didn't expect the top speed improvement........ .........
and one handed as well!
JB
John Boettcher
Wonder Lake, IL
"I'll quit riding when they pry the handgrips out of my cold dead fingers"
elvisboy77
Re: road testing Guzzitech reflash on my '14 V7
« Reply #1 on: October 19, 2016, 03:26:37 PM »
Nice!  How much did the top speed improve?  What did it cost??
Offline groundhog105
« Reply #2 on: October 19, 2016, 04:21:39 PM »
Very nice
Offline sib
« Reply #3 on: October 19, 2016, 04:30:39 PM »
Stock top speed with OEM tires and gearing is ~113 mph at 7200 RPM redline.  The only way a reflash would raise the top speed is by raising the redline RPM.  Good luck with that!
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline ratguzzi
    • road kill
« Reply #4 on: October 19, 2016, 04:47:51 PM »
It's a joke! The speedometer is reading too fast vs the rpm.
Ok, what is throwing it off? I just put the wheels with new brake rotors on today after making the rims tubeless.
I fixed it, just wondering who can guess what it was!
JB
John Boettcher
Wonder Lake, IL
Offline sib
« Reply #5 on: October 19, 2016, 04:50:24 PM »
JB
OK, I'll bite.  If the new tires are smaller diameter than the originals, the wheels will turn faster at any given speed and the speedometer will read high.
Offline ratguzzi
    • road kill
« Reply #6 on: October 19, 2016, 05:05:39 PM »
Tires are the same size.
I am still surprised on what it was.
JB
John Boettcher
Wonder Lake, IL
Offline makarushka
« Reply #7 on: October 19, 2016, 05:12:44 PM »
Non-magnetic rear rotor bolt? (stainless or titanium?)
« Last Edit: October 19, 2016, 05:13:17 PM by makarushka »
Offline ratguzzi
    • road kill
« Reply #8 on: October 19, 2016, 05:30:19 PM »
I mixed up two of the bolts with the front wheel rotor bolts. Front bolts have a recess in the center and the rears are standard so the recessed ones were sending double pulses showing an increase in speed.
JB
John Boettcher
Wonder Lake, IL
Offline sib
« Reply #9 on: October 20, 2016, 07:25:42 AM »
JB
Kudos to you.  That is a subtle distinction and right on the money.  On the later ABS models, both wheels have slotted timing discs that provide the signals to the wheel speed sensors, but your vintage V7 takes the signal from the rear disc bolt heads.  In addition to the presence or absence of dimples on their heads, the front and rear bolts have slightly different lengths, according to the parts manual, M8x20 for the front and M8x18 for the rear, but they could easily be exchanged, as you found out.  Nice going.
« Last Edit: October 20, 2016, 01:40:38 PM by sib »
Offline sib
« Reply #10 on: October 20, 2016, 01:51:50 PM »
ratguzzi, since you had your brake discs off, maybe you can answer a question I'm curious about.  The parts manuals show a part, number GU32636160, called a "rubber support part", that goes under the brake disc on the rear wheel hub.  This is NOT the cush rubbers that go on the other side of the wheel.  I believe that there are supposed to be 6 of them under the disc, rather than 1 as the manual indicates, and that they serve as anti-squeal dampers.  Also, I think they are only used on the spoked rear wheels, and not on the cast alloy ones, despite what the parts manuals indicate.  The cast alloy rear wheel on my '16 Stone does not have this rubber part(s) under the disc.  Can you provide any info or insight?  Thanks, Sam
« Reply #11 on: October 20, 2016, 02:00:29 PM »
Sucked the gas right out of the tank!
« Reply #12 on: October 20, 2016, 04:07:46 PM »
Here's your sign .....
Offline ratguzzi
    • road kill
« Reply #13 on: October 20, 2016, 04:28:27 PM »
You are correct. The aluminum spoked wheels have the rubber behind the brake rotor and the cast wheel does not. I wish I would have taken a pic because I don't remember if one piece or multiple. I think six separate ones.
JB
John Boettcher
Wonder Lake, IL
