Author Topic: GDR MuZ V twin  (Read 3136 times)
Offline pikipiki
GDR MuZ V twin
« on: October 26, 2016, 03:16:37 PM »
Found this yesterday, there's a little museam Berlin Alexanderplatz, wasn't looking for it just stumbeled into it.
interesting V twin, whether this was a prototype, factory job or something an enthusiast built I cant say? Seems a flat twin and V twin were built along similar lines (looks a bit like 2 x ETZ250 block/heads?) but only the flat was exibitted in a motorcycle.
http://www.erstesberliner-ddr-motorradmuseum.de
« Last Edit: October 26, 2016, 03:32:15 PM by pikipiki »
Re: GDR MuZ V twin
« Reply #1 on: October 26, 2016, 03:46:35 PM »
That's oddly cool.  :thumb:
Re: GDR MuZ V twin
« Reply #2 on: October 26, 2016, 05:05:38 PM »
it looks like a twin crank
Online sign216
Re: GDR MuZ V twin
« Reply #3 on: October 26, 2016, 05:28:27 PM »
Yes, it does look like that, but why would a maker go that route?
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Re: GDR MuZ V twin
« Reply #4 on: October 26, 2016, 05:31:23 PM »
Vibration cancelling.
That's why the Suzuki "Gamma" and Yamaha RZ500 V4's (among other 2T race bikes of the day) did it.
Those "V4" engines were actually more of a square 4 (remember the Ariel Square Four), with two counter-rotating crankshafts.
« Last Edit: October 26, 2016, 05:34:44 PM by jas67 »
Offline Aaron D.
Re: GDR MuZ V twin
« Reply #5 on: October 26, 2016, 06:07:01 PM »
Well, the 2 stroke Vs had separate cranks because they needed separate crankcases. I think this thing would be harder to balance for a street bike, though the crankshafts would be easier to make.
Offline Rick4003
Re: GDR MuZ V twin
« Reply #6 on: October 26, 2016, 09:11:11 PM »
Very need little engine, the two cranks are properly as mentioned earlier because a two stroke needs separate crankcases. If you would make it with one crankshaft the engine would be a lot longer as the cylinders had to be out of line just like a guzzi, but just a lot more. Also you could cancel out the centrifugal forces caused by the cranks by making them counter rotating.
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline pikipiki
Re: GDR MuZ V twin
« Reply #7 on: October 27, 2016, 04:37:23 PM »
except the flat twin seems to only have one crank?
Re: GDR MuZ V twin
« Reply #8 on: October 27, 2016, 06:58:09 PM »
Cylinders seem to be offset quite a bit.
Re: GDR MuZ V twin
« Reply #9 on: October 27, 2016, 07:06:08 PM »
If the pistons are going in and out like a boxer, and I assume they are, the crankshaft has two throws, and the crankcase will pressurize fine for both cylinders at the same time.  They'd also fire at the same time, once per engine revolution.
