Magic Gasket Removal Trick ?
Topic: Magic Gasket Removal Trick ? (Read 2153 times)
M0T0Geezer
October 27, 2016, 05:34:51 PM »
Got a 12 year old valve cover gasket on my '04 Breva 750.
Some of it fell apart and the rest is stuck on like welded steel. Cleaned it up best I could but the new gasket leakes a lot.
Any one know of magic solvent or special technique to be rid of all the old ?
"Search" function here is missing.
Wisdom from the road:
Play guitar or keyboard? You will like:
Chuck in Indiana
Re: Magic Gasket Removal Trick ?
Reply #1 on:
October 27, 2016, 06:07:54 PM »
Search works fine, but I use Perma Tex gasket remover in a rattle can. Spray it on, let it soak a while, scrape it off. Be aware that it is also a quite effective paint remover..
so don't get it anywhere you don't want it.
Wayne Orwig
Reply #2 on:
October 27, 2016, 06:14:00 PM »
Angle grinder with a medium scotch brite roloc disk.
Last Edit: October 27, 2016, 06:15:11 PM by Wayne Orwig
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #3 on:
October 27, 2016, 06:19:24 PM »
Quote from: M0T0Geezer on October 27, 2016, 05:34:51 PM
it's in the far upper right corner.
Reply #4 on:
October 27, 2016, 06:48:20 PM »
The "Search" function window can be elusive . Click on the multicolored Wild Guzzi . com window top right and then click on General Discussion, Search should appear .
Last Edit: October 27, 2016, 06:50:23 PM by oldbike54
Antietam Classic Cycle
Happily stuck in the past.
Reply #5 on:
October 27, 2016, 06:55:12 PM »
You can also use "Aircraft Remover" paint remover. I use the stuff in the quart can that you brush on and use an acid brush to apply it.
Muzz
On the backside of the planet.
Reply #6 on:
October 28, 2016, 03:51:26 AM »
I have just replaced the old green gaskets with the black ones. I used a mix of Acetone and acrylic spray thinners, a cloth and a very strong thumbnail. Took a bit of effort but the surfaces cleaned up nicely. New ones don't leak.
Two Checks
Reply #7 on:
October 28, 2016, 06:26:41 AM »
Aircraft remover.....leaves the paint.
1990 Cal III f/f "Il Duce' III"
1987 1000 SPII "Il Duce' II"
