Author Topic: California rear lights  (Read 1867 times)
Offline jeffrey1212
« on: October 30, 2016, 08:15:53 PM »
Hi I have just purchased a 2013 California 1400 so for i have found 2 problems 1 the heated grips are not working. 2 The rear lights are not working in full only the bottom third are lighting up i have been into the menu and it is showing that they should all be on ? looking forward to your advice Jeff
1952 AJS 18
1959 Matchless G12 650
1963 AJS 14 CSR 250
1963 Lamberetta LI 150
2013 California 1400 touring
2009 Vespa GTV 250
Re: California rear lights
« Reply #1 on: October 31, 2016, 06:21:56 AM »
Carl Allison to the rescue again :thumb:
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Entire.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Legend.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Power_Supply.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Ground.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Enabling_Signal_I.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Enabling_Signal_II.gif
I think these last 2 must be a different model
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Blue_Dash_Entire.gif
http://www.thisoldtractor.com/guzzi007/schematics/2014_California_Blue_Dash_Legend.gif
IIt doesn't seem to have tail lights, at least I can't see them in the Legend  :shocked:
Actually 20 and 21 are the tail light, it seems to be divided into two, I suspect the park light (gray/yellow wire) and the running light (green/yellow wire), one of the circuits must have a fuse blown or turned off
The red and blue wires are L&R indicators
It's possible the heated grips and tail light share the same fuse.
Start by checking all the fuses at 62, refer to the legend in your owners handbook but if it's still under warranty call the dealer, it's likely something they know about.
« Last Edit: October 31, 2016, 07:09:00 AM by Kiwi_Roy »
« Reply #2 on: October 31, 2016, 07:38:19 AM »
I'm pretty sure the tail light function is only the lower part of the lights.
Brake and Turn will light the rest.
Offline jeffrey1212
« Reply #3 on: October 31, 2016, 07:54:12 AM »
Thanks for the info about lights that is that one sorted
just need to sort the heated grips
1952 AJS 18
1963 AJS 14 CSR 250
2009 Vespa GTV 250
Offline jeffrey1212
« Reply #4 on: October 31, 2016, 08:15:40 AM »
Grips are sorted now it was a bad connection on the fuse  :laugh:
1952 AJS 18
1963 AJS 14 CSR 250
2009 Vespa GTV 250
« Reply #5 on: October 31, 2016, 08:22:24 AM »
Good Deal!   :thumb:
