Author Topic: 1200 Sport Centerstand Question: Are the mounting bolts already there?  (Read 3272 times)
Offline willowstreetguzziguy
I was able to obtain a new center stand from a Guzzi forum member THANK YOU, and the mounting parts for my 1200 Sport from another source.(looking at the parts diagram, the center stands were optional for the 1200 Sport but not the Breva 1100).... so are the mounting bolts for mounting the left and right brackets already screwed into the frame under there or do I need to buy bolts? and if so, what size bolts do I need?
« Last Edit: November 02, 2016, 01:49:03 PM by willowstreetguzziguy »
2008 Guzzi 1200 Sport
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: 1200 Sport Centerstand Question: Are the mounting bolts already there?
« Reply #1 on: November 02, 2016, 02:10:27 PM »
Have a look for them, but I'm sure extra parts are needed than just the centerstand.
« Reply #2 on: November 02, 2016, 02:32:51 PM »
There are bolts and bushings
 I'm not 100% sure but highly doubt the bolts are there
« Reply #3 on: November 02, 2016, 03:11:03 PM »
I have "on order" all the extra stuff like bolts, springs, plus the left & right mounting brackets which the center stand bolts onto. I'm wondering where these two mounting brackets attach and are the bolts already there and do I  attach the brackets to the existing bolts, or do I need longer bolts, or something else?
« Reply #4 on: November 02, 2016, 05:28:17 PM »
Jeff ..... look at the pic  (0275IMG)  that I sent to you attached to an email.  It shows each and every part that came in the Guzzi center stand kit.  The individual from whom I purchased the center stand kit had (a) purchased the kit but (b) sold his 1200 Sport before he had the opportunity to install it.  So, all the parts in that photo are what Guzzi shipped with the kit.  If you don't have all those parts, you probably don't have the pieces necessary to install the stand.
If for some reason the email with attached pics and line drawings didn't show up, check your spam folder.
Regards,
Bob
Offline Darren Williams
  • Finally got me a Griso!
« Reply #5 on: November 02, 2016, 05:49:14 PM »
It's been a while, but I remember having to remove a couple of brackets and replace them with ones for the center stand when I installed mine. Had a couple parts left over.
« Reply #6 on: November 02, 2016, 05:54:29 PM »
Bob, I did look at the picture and I ordered all of those parts that it shows. I'm just wondering where those two brackets get bold it on underneath?
« Reply #7 on: November 02, 2016, 06:28:34 PM »
I think Darren and I have the same problem ...... it's been a few years since we installed the stand and have forgotten some of the details ..... but yes, as he says, the old brackets do have to come off before you can install the new brackets.
« Reply #8 on: November 02, 2016, 07:24:27 PM »
Is there a chance anyone with a 1200 Sport, Breva 1100, or an early Norge that could take pictures of the underside where those brackets w/ center stand are installed?
Offline rudolf35
« Reply #9 on: November 02, 2016, 08:37:09 PM »
Jeff, check your email :popcorn:
« Reply #10 on: November 03, 2016, 11:46:21 AM »
As I look at some pictures, I'm beginning to believe that the existing brackets are to be removed and replaced with the "new" centerstand support brackets. The new ones appear to be the same as the existing brackets where they bolt in but the new ones have an additional lower areas where the centerstand attaches.
