Author Topic: California bike lift  (Read 2404 times)
Offline jeffrey1212
« on: November 11, 2016, 07:18:16 AM »
I have just tried to lift my 1400 california with my bike lift I got a few inches of the ground and it tipped to the rear has any one had the same experience and worked out a way around this problem looking forward to your replies
Jeff
1952 AJS 18
1959 Matchless G12 650
1963 AJS 14 CSR 250
1963 Lamberetta LI 150
2013 California 1400 touring
2009 Vespa GTV 250
Offline radguzzi
Re: California bike lift
« Reply #1 on: November 11, 2016, 07:43:26 AM »
What type of lift do you have...?
I have not tried to lift a 1400 however, the Handy Lift raises the Electra Glide with no issues.
I wonder if the Guzzi is longer than the HD...?  And perhaps more rear weight biased...?
Best,
Rob
« Last Edit: November 11, 2016, 07:44:46 AM by radguzzi »
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline stevet
« Reply #2 on: November 11, 2016, 08:00:35 AM »
I'm not there to see your setup, but how about straps from the lower or upper triple clamps down to the lift (if it's a platform lift), like I do here with my homemade setup.  I use a wheel chock on a plywood platform, straps down to eye bolts at the front corners of the lift for stability, with my jack stand lifting from the rear of the frame where a centerstand would be mounted.
If you are using some sort of scissor jack lift under the frame, maybe something like what I built might help you.
http://wildguzzi.com/forum/index.php?topic=82965.0
Sounds like your bike is rear-heavy.  Do you have luggage you could remove to help the center of gravity move forward?
There have been lots of stock motorcycles that tip to the rear wheel while on their centerstands.  BMW models, for example.
Steve.
Steve T.
Twin Cities, MN
Feejer, '10 Yamaha FJR
-George Eastman.
Offline kirb
« Reply #3 on: November 11, 2016, 08:20:37 AM »
Please don't say it's a harbor freight lift.
Buy a good lift and this stuff doesn't happen.
Offline jeffrey1212
« Reply #4 on: November 11, 2016, 09:16:55 AM »
This is the type of lift I have
1952 AJS 18
1963 AJS 14 CSR 250
2009 Vespa GTV 250
« Reply #5 on: November 11, 2016, 09:24:55 AM »
I have three HF lifts in the shop and have had zero problems. But then, I haven't needed to lift anything as heavy as a Porky 1400.  :wink:
Offline radguzzi
« Reply #6 on: November 11, 2016, 09:29:48 AM »
Ahh, well that explains that then...
Put a wood spacer under the rear or tranny area.
rad...
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
