left side brake disc rotor to right side rotor distance on loop frame
Topic: left side brake disc rotor to right side rotor distance on loop frame (Read 1297 times)
harrytief
November 19, 2016, 12:07:22 AM »
I want to convert my ambassador to twin discs and need the distance between rotors to assure centering them in the brake calipers. I will be using the rotors from a cx100 with the deeper aluminum carriers so I will be machining down the 29.5mm hub/bearing carriers.
Harry
smdl
Re: left side brake disc rotor to right side rotor distance on loop frame
Reply #1 on:
November 19, 2016, 08:21:34 AM »
Hi, Harry.
I should be able to measure a little later today if no one gets to it before me.
Glad you're out working on the Loops!
Cheers,
Shaun
Last Edit: November 19, 2016, 08:44:29 AM by smdl
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
harrytief
Reply #2 on:
November 19, 2016, 08:31:57 AM »
Thanks Shaun.
...My name is Harry and I am a guzziholic...
smdl
Reply #3 on:
November 19, 2016, 08:45:21 AM »
Quote from: harrytief on November 19, 2016, 08:31:57 AM
Thanks Shaun.
WELCOME, Harry.
'61 Galletto
'24 Stelvio
harrytief
Reply #4 on:
November 19, 2016, 09:47:50 AM »
For anyone following this thread, I spoke to Shaun this morning as he measured his eldo front end. The distance across from outside each disc is 165mm.
Harry
