Author Topic: wiring diagram needed 2007 Norge  (Read 3024 times)
Offline Mike Craven
« on: November 19, 2016, 07:07:30 AM »
I have the factory wiring diagram and the thisoldtractor sourced (Carl Allison's 27 Sep 2008 version) diagrams, but they are not accurate.  I have a no-start problem and the Off/Run/Start switch has 5 wires and 5 contacts with different colors/tracers than the diagrams.  Where have I missed the updated versions?
Any help is appreciated, tia,
Mike
Mike  L-715, Atlanta GA
1983 Cali II
Offline lost
Re: wiring diagram needed 2007 Norge
« Reply #1 on: November 19, 2016, 07:55:19 AM »
You might try Guzzitech.com. You can download the manuals from them. It will require a donation to the website but there is a lot available there.
Online Matteo
« Reply #2 on: November 19, 2016, 07:59:19 AM »
« Reply #3 on: November 19, 2016, 08:34:33 AM »
I have a factory hi=def I'll send ya
check your e
« Last Edit: November 19, 2016, 08:47:23 AM by guzzisteve »
Offline Mike Craven
« Reply #4 on: November 19, 2016, 09:56:24 AM »
Thanks all.  Steve, got it, revision 3 has the same errors.
I'll end up cutting open loom, tracing, etc.  Wow, no fun for a mechanic trying to trouble shoot.
Mike
1983 Cali II
« Reply #5 on: November 19, 2016, 11:13:02 AM »
Mike, do you get the dreaded click?
Perhaps you just need to do the bypass.
Sent from my shoe phone!
Offline Mike Craven
« Reply #6 on: November 19, 2016, 04:33:40 PM »
No click.  I have the mod installed.  I had taken the Stop/Run/Start switch apart and it worked in my hand.  After complete reassembly it doesn't start and I'm trying to figure out what contacts might be bad.
Thanks,
Mike
1983 Cali II
