Author Topic: Guzzi v65 airbox question  (Read 1302 times)
Offline chrisk
« on: November 19, 2016, 08:14:03 AM »
Hi, from the attached pic I'm pretty sure that the yellow arrow points to the hole (which should be a spigot but it snapped off...) that goes down to the sump along with the main hose. It's effectively an overflow for the main chamber where the oil from the heads runs.
Question is, what's the red one? I took the bike back to bits ages ago but am pretty sure there was nothing there. I think it's just an overflow to atoms?
Offline SED
Re: Guzzi v65 airbox question
« Reply #1 on: November 19, 2016, 11:41:39 AM »
Hi Chris,
That red arrow marks a vent (drain?) to the road.  The parts books show a hose hanging down (Rubber pipe 5 x 9   GU00823944050) Not sure why it doesn't suck in unfiltered air.  The hose was about 10mm id so I inserted a reducer at the lower end hoping that it would reduce the amount of dirt sucked in if air were also sucked in.
This post shows the airbox set-up on mine (reply #16) http://wildguzzi.com/forum/index.php?topic=87045.0
Cheers,
Shawn
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline chrisk
« Reply #2 on: November 19, 2016, 03:14:48 PM »
Top man, thanks.
