Author Topic: 72 Eldorado jumping out of top gear !  (Read 1962 times)
Stella
« on: November 28, 2016, 09:17:02 PM »
Can anyone speculate on why my friends 72 Eldorado jumps out of top gear ?
Thank you
Re: 72 Eldorado jumping out of top gear !
« Reply #1 on: November 28, 2016, 09:19:34 PM »
Usually that's caused by worn gears.   New gears need to fix it.
Stella
« Reply #2 on: November 28, 2016, 09:22:18 PM »
Thank you, I'll pass on your suggestion to my friend
« Reply #3 on: November 28, 2016, 10:01:53 PM »
Could be something as simple as a linkage issue, or something more serious like rounded off engagement "dogs" on the gear and sliding sleeve or a bent or worn shift fork.
Stella
« Reply #4 on: November 28, 2016, 10:06:38 PM »
Thank you :-)
Offline jacksonracingcomau
« Reply #5 on: November 29, 2016, 02:02:08 AM »
Charlie's onto it but jumping out of top is rare, worn dogs on 5th so very unlikely, linkage or selector problem IMHO, obviously look at linkage first.
Worn gear teeth whine like billyho, but don't jump out, it's the dogs that hold engagement, teeth just drive (or break & go bang)
« Reply #6 on: November 29, 2016, 03:27:39 AM »
This. Worn 5th gears only started being a problem in the early 2000's when the box was being asked to do much more than it was designed for. Early ones are generally well up to the task.
If it's 'Jumping Out' it's most likely because it isn't 'Going in'. Pawl adjustment, linkage adjustment or as a last resort drum shimming, (Although this is usually irrelevant for 5th.) would be on mt shit list.
