Author Topic: V65 regulator/rectifier - connection to loom Question  (Read 1391 times)
Offline chrisk
« on: December 02, 2016, 03:27:22 AM »
Hi, just reconnected this after removing the air box, are the two black wires at the top the right way around?
imgbb
Offline pat80flh
Re: V65 regulator/rectifier - connection to loom Question
« Reply #1 on: December 02, 2016, 04:37:57 AM »
Looks the same as mine, the top wire with the 90 degree spade connector on mine is a different color wire, blue I think.
Does it charge?
 Are you putting pod filters on?
00 Bassa
80 FLH (in rehab)
75 850T prject
Offline chrisk
« Reply #2 on: December 02, 2016, 05:43:00 AM »
Hi, haven't started it yet, but I'll assume it's okay for now - thanks.
I was very close to fitting pods as the air box is such a f*r to fit and needed a few repairs but after much patience I got it back in there. Not a job if your in a rush...
Offline Groover
    • Scooteropolis
« Reply #3 on: December 02, 2016, 07:18:14 AM »
If it doesn't charge, swap the red and the white-ish one (the one next to it), but otherwise I'd say it looks stock and correct. The only reason I say possible swap the two is because my G5 has the red on the end terminal (where that white one is) and has a dark blue where that red is now. The blue goes to the charging lamp on the dash and in my case and needs to be in place for the charging system to work, and I think that charging system works the same way.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
