Author Topic: That "tinking" sound from cooling engine  (Read 10296 times)
Re: That "tinking" sound from cooling engine
« Reply #30 on: December 03, 2016, 10:36:00 PM »
Right, your particular motorcycles support your hypothesis, but aren't representative of all motorcycles.  My H2 doesn't tink at all, yet my Mille does a little bit.  Both are air cooled, of course.  Most cars I've owned tink quite a bit if you lift the hood and listen, and they're all liquid cooled.  My wood stove tinks a lot if you build up the fire, or cut off the air intake to cool the fire.
 So ... the H2 doesn't have an exhaust system ????
Offline ITSec
« Reply #31 on: December 03, 2016, 10:40:36 PM »
I guess even the guys writing tech notes can be confused.   :boozing:
If you've read tech notes from Guzzi, this wouldn't even be a guess. At all. Not even a little bit.  :evil:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #32 on: December 03, 2016, 10:59:04 PM »
My Mille has no heat shields and it tinks.  It's the joints in the exhaust system doing it.
« Reply #33 on: December 03, 2016, 11:02:14 PM »
 :laugh:   :boozing:
« Reply #34 on: December 03, 2016, 11:05:12 PM »
My assumption is that the expansion chambers, being one piece from the cylinder to the outlet, don't make noise because they don't have any joints.  The connection to the cylinder is a tube-socket fitting with silicone sealer in it, so apparently it moves quietly.
« Reply #35 on: December 03, 2016, 11:36:12 PM »
The bike I had that did it the most was a CB 900 Honda Bol D'or as they were known then. It did it IMMEDIATELY you turned off the key.
Offline yogidozer
« Reply #36 on: December 04, 2016, 06:36:19 AM »
you're over tinking it.
settle in, it's a long winter.  :laugh:
« Reply #37 on: December 04, 2016, 08:41:45 AM »
Want to hear a lot of 'tinking'?  Listen to a car/truck with a turbocharger cool down.
Yes, the tinking sound will be higher or lower pitch depending on a lot of things.  Stainless heat shields make some interesting noises.
Offline sib
« Reply #38 on: December 04, 2016, 09:51:23 AM »
My barbecues also tink a lot as they cool.  Doesn't matter whether I've cooked ribs, steaks, chicken or tofu (just kidding with the last one).
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #39 on: December 04, 2016, 10:12:58 AM »
My V7S with stock exhaust does it.
My V7R with Arrow exhaust (no heat shields) does not.
Same engine, different exhaust.
I'd say that the sound is from the exhaust.
The V7S and my previous V7C (also with stock exhaust + heat shields) are the only bikes that I've owned where I've noticed this sound.
I've got (and owned others) a lot of air cooled vintage bikes, Honda, Yamaha, Ducati, BMW, none "tink" when cooling.    Most of them didn't have heat shields on their exhausts, only a few Honda scramblers did, and they didn't tink either, maybe because they were mounted to the exhaust differently?
« Last Edit: December 04, 2016, 10:15:20 AM by jas67 »
Offline rboe
« Reply #40 on: December 04, 2016, 11:54:38 AM »
Dino oil tinks, syn does not.....   :evil:
 :popcorn:
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline SmithSwede
  • I don't want a pickle
« Reply #41 on: December 04, 2016, 12:30:11 PM »
Hmmm, Jas67 has a great data point.  Maybe it is about the exhaust--I was skeptical.
Maybe the connection between exhaust header and exhaust port on a water cooled bike is cooler, thereby reducing tink potential.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #42 on: December 04, 2016, 01:17:02 PM »
Exhaust temperature is a factor of exhaust gas temperature.   Water cooling vs. air cooling will have little effect on the temperature of the exhaust.  It will effect the temperature of the head, but, no the exhaust pipes.
Offline ITSec
« Reply #43 on: December 04, 2016, 02:59:13 PM »
 :popcorn:
Somebody's tryin' to stir up a bit o' bother!  :rolleyes:
ITSecurity
« Reply #44 on: December 04, 2016, 04:53:13 PM »
If its a tinking, I'm a thinking .....
It's TEA TIME!  :boozing:
Time for drinking! (tea please.)
« Last Edit: December 04, 2016, 04:55:12 PM by Penderic »
« Reply #45 on: December 04, 2016, 05:03:01 PM »
Alright!  I just noticed your new avatar.  My Favorite Martian was one of my favorite shows when I was a little kid, and I've enjoyed Ray in several things after that.
« Reply #46 on: December 04, 2016, 05:08:14 PM »
I didn't see him in much else here in Oz. Once as a county court judge type and I think that's it as I recall over here ???
« Reply #47 on: December 05, 2016, 11:24:43 AM »
That looks more like whiskey on the rocks.
