Author Topic: Website contains animated engine drawings  (Read 3083 times)
« on: December 11, 2016, 06:12:54 PM »
http://www.animatedengines.com/
Check out some of these head-scratchers.
Re: Website contains animated engine drawings
« Reply #1 on: December 11, 2016, 09:22:20 PM »
I have built, without plans, two of those engines from scratch.  The first is an oscillating 4 cylinder engine from brass.
 It has only 9 moving parts, one more moving part is the throttle that controls start, stop, forward, reverse, and speed.
 It worked on the first try.  The second was a two cylinder double acting engine of the locomotive type.  It had more moving parts and was a bit more complicated.
It also worked on the first try.  It is made of steel and brass with a bronze crankshaft and aluminum manifolding.  It was made from scrap metal.  I used a lathe and milling machine to start with a steel block and cut away all that did not look like a steam engine.
 I had photos of it and videos of it in bike pics .com but I no longer have access to that site.
 The 4 cylinder engine had a half inch bore and one inch stroke giving 4 power strokes per revolution.
 The loco engine had a 3/4 inch bore and one inch stroke giving 4 power strokes per revolution.
« Reply #2 on: December 12, 2016, 07:32:03 AM »
Nice selection.  They did leave out the most important, the steam turbine.  Probably cause it has so few moving parts, but, the principle of operation is also one of the more important.
« Reply #3 on: December 12, 2016, 04:02:49 PM »
"I cut away all that did not look like a steam engine."  Great comment!  Wish you still had those pics to post.
Bob
« Reply #4 on: December 12, 2016, 05:47:34 PM »
 That was fun .
« Reply #5 on: December 12, 2016, 06:31:05 PM »
Bob
Some of the PNW riders have seen the loco engine in the flesh.  One morning I put it and an air tank in a sidecar and took it to the Krain breakfast for show and tell.  The air tank had enough to run it for a little less than a minute.  A couple of years ago that one fell and hit the concrete floor.  Since it weighed about 8 pounds it hit hard and bent the crankshaft.
 I did my best to straighten it but it still doesn't run as easy.   It binds a bit in the crank main bearings and requires a bit more pressure to run it. Yes it does make the traditional Choo Choo sound.
« Reply #6 on: December 12, 2016, 07:30:45 PM »
A friend of mine is a steam engine junkie.  He and his dad build a 4-6-4 (IIRC) from scratch.  They made the fuel car into the seat for running it on their "back yard" track.  He now has a 1/4 scale Case tractor, about 2000lb worth, in his garage.  Built by a friend of his from original drawings, also all hand made.
Offline SmithSwede
  • I don't want a pickle
« Reply #7 on: December 12, 2016, 09:40:47 PM »
Is there any mechanical contraption that is cooler than an old rotary aircraft engine?
Other than Guzzi engines, of course.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #8 on: December 13, 2016, 09:07:27 AM »
Nope, especially when you see something like this.
https://www.youtube.com/watch?v=Hq78ZocOAkY
