Author Topic: Part numbers  (Read 1626 times)
Offline simonome
Part numbers
« on: December 23, 2016, 03:35:39 AM »
Good morning everybody.
I have managed to put back on the road my V75 PA, which has been "bricked" on the highway few weeks ago.
Now I need to fix an annoying problem with the starter motor: it doesn't always crank, and even hammering it doesn't always fix the problem.  :violent1:
I need to get a new one. The original part has long since lost its label, so I have no clue which part to look for.
Do you know of any resource on the internet, where I can pick OEM part numbers for MG?
Re: Part numbers
« Reply #1 on: December 23, 2016, 07:38:55 AM »
http://www.thisoldtractor.com/moto_guzzi_small_blocks.html
? I don't see a V75 book but maybe the v50 would work? or the later v7's  ?
Re: Part numbers
« Reply #2 on: December 23, 2016, 08:33:02 AM »
Look around on sale sites. Newer starters fit right on. The price from Guzzi is 3 or 4 times what it should cost
http://www.guzzitek.org/parts_list/pb/750/V75PA_1996-2001_PL(GB).pdf
http://www.guzzitek.org/parts_list/pb/750/V75PA_1992-1996_PL(GB).pdf
Re: Part numbers
« Reply #3 on: December 23, 2016, 08:56:36 AM »
It might not be the starter motor that is at fault, but instead the way the starter relay is wired. If it's like the older small-blocks, the current to that relay takes a very long and convoluted path with lots of connections along the way. If the battery isn't close to "perfect" or if any of those connections is dirty/corroded, then you get a click instead of the starter cranking.
Offline simonome
Re: Part numbers
« Reply #4 on: December 26, 2016, 10:03:36 PM »
Thank you all, these links are of immense help.
