Hi Kev,In UK there seems to an issue of V7 bikes faltering at start up and hesitating at low revs. The problem appears to be less in the US (eg your bike). Why?? Maybe due to UK being colder in the riding season and perhaps lower and the map not adequately enrichening the mixture to compensate for this? Without access to the maps and knowing how the MG compensation compares with the tables I can not say if the compensation is CORRECT - but in UK conditions the standard V7 engine seems to run lean. Is my use of CORRECT clear now?
Though many TPS's are similar and some from one system may be adapted or adjusted to work on others, no they are not all compatible for various reasons: 1. Calibration 2. Physical mounting Not to mention they are not replaceable separately from the throttle body on more and more modern EFI systems.
That is if the answer is enrichening all over the map and shutting off lambdas.
Which, in the case of the V7, I can assure you it is not.
In theory, except if you're looking to solve "performance" like cold start, stumbling or surging that some complain about. That is if the answer is enrichening all over the map and shutting off lambdas. I mean you just can't safely approach the leanness of closed loop operation with an open loop setup which is why we have closed loop injection.
I'm sure it's not, in YOUR case.
I meant in general for any V7. Simply disabling the lambda and adding fuel across the board is NOT the answer.
Do other bikes have the problem? Do cars and trucks have that problem? If your answer is no or not many, then for the bike in question it's a lack of attention to details because of money constraints or poor development of the electronic engine management...You know how fix it...
You continue to misunderstand me. I was already certain that would be a bad idea and I was already certain it wouldn't be YOUR solution (but WOULD be someone else's).
I understood that. [emoji23] I'll shut up now.
Peter, unfortunately it is easier to dumb down the bike than train the rider.....I am not a fan of new riders having ABS / traction control. They should learn how to ride correctly...and this again follows through to there logically being just one optimum ECU map with others being dumbed down versions.Rode a Mana in Jersey where the slow speed restrictions and country roads made it the ideal bike. Little engine breaking though, but the cubby hole in the tank was useful.AndyB
Kev, you are wrong, lambda is there only to get inside regulations. Not for running the engine better. It would be nice but that needs a wide band sensor, that no Guzzi has. I know of no motorcycle that has wideband lambda. But i'm not to knowledgeable about other makes.
Hi Kev,If my V7 had run from new like how you describe yours, then like you I would not have changed anything. Why the difference between our bikes? I thought it might be the environments we rode in - but you don'tthink this is the reason.But my bike (like quite a few others) did not run right......and the low speed hesitancy in particular I found quite dangerous when pulling out of a junction or making a tight turn as the engine felt it might stop.So (after the dealer pointed out the fault to me on a road test after fitting a new ECU / TB, but was unable to do anything about it) my options were:A) sell the bike / return it to MGB) do something about it myself....and all I could do was remove the lambdas.Luckily Option B worked - and I wanted to share that solution with others whose bikes may have the same hesistancy below 4000rpm.Now Beetle is working on it there may well be another solution available soon - but six months ago my only other option was a GT remap.I would disagree with one thing you have said, however, about the removal of the lambdas making the a/f ratio richer 'all over the map'. They only effect the bike when it is in closed loop operation below about 4000rpm. At faster speeds the engine runs in open circuit so they are redundant. Or am I wrong on this?Andy1
Maybe I missed this Beetle, but what then is the point of the O2 sensors in a bike running your map? Does your map effectively turn them off or not use their inputs?
I get the impression that the O2 sensors come into play only in a certain range of rev/throttle openings. And that this happens largely or exclusively to satisfy emissions requirements, as opposed to just making the engine run sweet and happy.
Am I missing some nuance here? In a perfect world with this particular ECU, do you want or need the Lambda sensor input??
And if you go from the Guzzi OEM exhaust pipes to aftermarket pipes like the Mistrals, do they even have a bung that accepts the O2 sensors?
Maybe I missed this Beetle, but what then is the point of the O2 sensors in a bike running your map? Does your map effectively turn them off or not use their inputs?I get the impression that the O2 sensors come into play only in a certain range of rev/throttle openings. And that this happens largely or exclusively to satisfy emissions requirements, as opposed to just making the engine run sweet and happy. Am I missing some nuance here? In a perfect world with this particular ECU, do you want or need the Lambda sensor input??And if you go from the Guzzi OEM exhaust pipes to aftermarket pipes like the Mistrals, do they even have a bung that accepts the O2 sensors? Sorry. I be stupid about this stuff. Edumacate me, please.
As a matter of fact, when I think about it, when my Breva 1100 was pinging uncharacteristicall y when new (and during the 2 years of warranty) I pursued it every way I could through MG before I finally GAVE UP and had the ECU remapped. And that DID INDEED FIX IT. Which frustrates me because I never found out WHY it was doing it in the first place and WHY SO MANY OTHERS WERE NOT.
Hi Kev,I've just stumbled across this thread and thought I might share some of my findings, based on more almost 3 years of data logging Lambda left/right, voltage, TPS, RPM, engine, oil and air temperature and manifold pressure on my V11 and Jackal. I built an ECU bench to measure the influence of changing single parameters while keeping all others steady. The latest incarnation, Mk VI, includes a narrow band lambda sensor simulator and can be used with the 15M or 15RC. And have also deep dived into the dissassembled program code of the 15M and RC.upload imageThe resulting BINs are used by quite a few Guzzisti around the world, several of them are members of this board and shared their feedback here.The underlying assumption when optimizing BINs is that the engine and its relevant components are subject to deviations of the original. And recognizing that Guzzi wasn't big enough to spend much time in optimizing its BINs to a degree available to larger manufacturers.This begins with very basic parameters such as barometric pressure and air temperature trim. The trim tables used in the 15M/RC and previous ECUs are basically flat, that is they don't correct fuel injected to correspond to the changes in air mass (Mark will know better than me if this is still and issue with later ECUs). And continues with significant differences in lambda between the left and right cylinder.Now, the most likely explanation why you had pinging on your Breva while others didn't is that the series deviation of one or more components aggregated to such a degree that the BIN just didn't fit anymore. This might have been ignition or mixture-related, who knows.CheersMeinolf
So even if we accept that the primary purpose is emissions (and I do), should we not also recognize that they DO effect performance (proper running) of the machine to some small extent?
Or Beetle/Paul, are you saying the small extent is negligible? But if so, why reset trim after ECU updates etc.?
So what effect is the auto learned trim having then?
A manufacturer with less money to throw around might be inclined to make a map that's just "good enough".
Trims to the AFR to somewhere around 14.5 - 15.5. Too lean for the the engine/exhaust configuration we get from Guzzi.
