I just installed a digital tach on my 15M system. I connected it to the tach output. Set to 2cyl it gave me what I figure was 2x rpm. Set to 4cyl it's accurate.Doesn't answer the question, but it implies that the ecu is firing twice. It's not feeding both coils at once though. If it did that we wouldn't care about left/right plug wires. Maybe someone over at the guzzidiag topic knows.
90 degree Ducati V-twin, at least the old carburettor versions (900SS, Monster etc.) with the 2 pickups on the flywheel have wasted spark ignition.
Do you mean every PLUG fires at the same time, not every cylinder. Thinking... thinking...
The front and rear cylinder each fire independently every 360 degrees. So one waste spark per cylinder but never both cylinders at the same time....The two ignition sensor/pick up is on the crankshaft spaced 90 degrees apart...
Indeed, the cylinders obviously fire on the compression stroke but also fire 360 degrees later on the exhaust stroke but each cylinder fires independently of the other, i.e 90 degrees apart as the pickups are set one 90 degrees after the other, but as they are on the crankshaft the flywheel triggers the spark every revolution whereas the cylinder only needs to fire every other.
If you take the pickup from the camshaft drive at half engine speed (as per a Guzzi distributor) then there would be no wasted spark - there is a company in New Zealand that make a conversion to do exactly this; http://www.fastbikegear.co.nz/
[ - there is a company in New Zealand that make a conversion to do exactly this; http://www.fastbikegear.co.nz/
___________________ ___________________ ___________________ ___
Unless you're connected to an output that signals both cylinders then it does imply that it's firing twice, i.e wasted spark.
I have Translogic digital dashes on both my Ducatis; 916 (16M ignition) and 900 Monster.
Both are 90 degree V-twins and the RPM pickup comes from the signal to just one of the coils, to configure it properly you then set it to a (sequential) setting that gives the correct number of pulses to show the correct RPM.
The ignition pickup points are different in that the Monster has 2 pickups on the flywheel which (obviously) runs at engine speed whilst the 916 has a single reference point on the cambelt pulley layshaft which runs at half engine speed, it then use the ECU to generate the spark based on degrees of rotation.
The 916 is set at the second setting, i.e. twin cylinder (no wasted spark) but the Monster needs to be on a higher rate (as if it were a 4-cylinder) due to the wasted spark, otherwise it reads double-RPM.
I doubt it, usually on singles or twins I think where the cylinders go up and down in unison UpdateLowRyter know a lot more about thisThe only bikes I'm familiar seen the NSU Supermax and KawasakisI don't think the Brit bikes use it.I doubt any bikes with 180 or 270 degree cranks use it
My BSA Thunderbolt A65T & Honda CL200 both fired plugs in unison.
An A65 using the stock points ignitions has two separate systems and fires one plug at a time...
Dammed Kiwi's never can be trusted
Well that was the best thing I've ever seen . A jumping cow , simply amazing Dusty
A high-jumpin' heifer.... who'da thunk it? I figgered them Oklahoma boys had already done all that could be done to make a cow jump.
Seems you are confusing Oklahoma with Nevada Dusty
Wasted spark on V twin bikes? Millions of 45 degree Harleys in the past...Don't know if they still use it...
I have a piranha on mine, it doesn't have a wasted spark
Switching the system on/off causes a spark, Boyer ignition and Lucas Rita did the same on the Brit bikes..... DonG
