Author Topic: harpers tonti solo seat  (Read 2591 times)
Offline lazlokovacs
« on: January 23, 2017, 04:17:21 AM »
anyone got pics of the underside of the harpers tonti solo seat? Interested to see how it attaches..
thanks
Offline mtiberio
    • TiberioRacing
Re: harpers tonti solo seat
« Reply #1 on: January 23, 2017, 07:31:36 AM »
good luck with that. I have never seen an OEM or repop tonti solo saddle where I could figure out the bracketry. I get the elevation of the saddle thing, this makes the saddle to floorboard distance more like a Loop. Every tonti bike I ever bought that had a solo saddle had the most bizarre arrangement of plates that mount to the tabs welded on the frame, but with little or nothing to hold down the front end of the saddle. I'm sure there is a correct way to set these up, but I never found it. Add to that raising the saddle height while great for leg comfort while riding, is bad for parking lot maneuvers.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Mike Harper
    • harpermoto.com
« Reply #2 on: January 23, 2017, 08:04:55 AM »
I
There are two steel brackets that protrude from under the front of the seat that slide under the frame crossbar that keep the seat front in place.  The rear mounts match up with the vertical frame tabs and a spring loaded rod keeps the rear of the seat in place while allowing quick and easy removal.
If you want to call Curtis this morning he will be glad to answer your questions.
Mike
Offline mtiberio
    • TiberioRacing
« Reply #3 on: January 23, 2017, 11:47:49 AM »
I
Mike
Thanks Mike. I was sure there were parts I was missing. Still some ambiguity about the direction of the steel brackets, but these are all intellectual exercises for me as I don't own a tonti at present.
Online Groover
    • Scooteropolis
« Reply #4 on: January 23, 2017, 02:08:37 PM »
Not sure if this helps, but I had these photos saved on my computer. Not sure if this is aftermarket or MG OEM.
upload image direct link
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline lazlokovacs
« Reply #5 on: January 23, 2017, 03:23:38 PM »
I
Mike
Thanks Mike,
Will give you guys a transatlantic call at some point!
Cheers
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #6 on: January 23, 2017, 05:09:24 PM »
That is an Original T3 / G5 style LAPD seat
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
