Author Topic: v7III available in US starting in March!  (Read 17900 times)
Offline Adan
Re: v7III available in US starting in March!
« Reply #90 on: January 30, 2017, 01:18:24 PM »
Not to open the whole V7 suspension wormcan, but from my perspective, if the suspension on the III is a wee bit improved over prior models, it might be good enough that I wouldn't feel the need to upgrade it.  Boom, several hundred+ dollars saved.  Folks might still want to upgrade in search of maximizing performance.
V9 Bobber
Zero S
Offline DaSwami
« Reply #91 on: January 30, 2017, 05:28:13 PM »
As for the V7III Special..... the price is $1500 lower than the V7II Special??
How does that happen?
« Reply #92 on: January 30, 2017, 07:15:02 PM »
Lots of reasons and not unprecedented in Guzzi history if memory serves.
* Consumer products are generally priced to the market. Margins grow and shrink with what the margin can bear and what the company can negotiate from parts suppliers.
* Once tooling and initial investments are paid margin grows allowing for more aggressive pricing if the marketing requires it.
* Actual changes to the product (single instrument pod or changes of suppliers) can change margin.
I'm thinking it's mostly A, with a little B, and a hint of C.
guzzipete
« Reply #93 on: January 30, 2017, 07:40:40 PM »
Might have something to do with the exchange rate also.
Offline Adan
« Reply #94 on: January 31, 2017, 12:30:24 AM »
I'd wager that very few people buy Guzzi's at MSRP.  A large percentage of units sit in showrooms until discounted.  That's just my impression.  Maybe the new pricing is just an attempt to cut to the chase and correlate income to production a little more closely.
V9 Bobber
Zero S
Offline mudskipper
« Reply #95 on: January 31, 2017, 01:03:57 AM »
I WAS referring to the mighty BREVA 750, which of course came out before the breva 1100 and looks a whole heap nicer, especially if it is in the fast red colour like mine! :thumb: :thumb: :thumb: :thumb: :grin:
[emoji1417][emoji1417][emoji3][emoji3][emoji1419] then its ditto for me too!
I've been on the lookout for a V7/V7ii/maybe a V7iii to replace my BV11, because they're lighter, and have a heritage to them. But I still love my Breva v11! ... Why?
Pic: my 2006 Breva v1100 with original Guzzi panniers and 1200 Sport bikini fairing. (One of the nicest looking bikini fairings around, IMHO)
I found the Breva v11 well made and designed (almost). And over engineered compared to many other bikes in that price range - especially in the resale market.
Mainly because panniers + lane-splitting ability are important for me. And because of the monoshocks, together with the original Guzzi panniers (Norge 36 litre sized ones), the BV11 can have   tucked-in hauling capacity without the enormous width often associated with dual shock bikes using large third-party panniers (like H&B Junior 40s).
Pic: Panniers utilise as much of the  space where the dual shocks wld be as possible.
Pic: Narrow overall bike width profile.
My main gripe is the huge LCD screen which burns up when the bike is parked exposed to the heat of the sun.
Pic: Large LCD Burnt the by the scorching heat of the sun.
The new V7s have come back to simple speedometers with small LCDs and extra info via the mobile phone. Clever!
I hope future V7s (V7iv ?) might also have monoshocks to take advantage of the space under the seat for larger panniers yet narrower bike width. Although I was explained that dual rear shocks are stronger and more efficient.
Looking forward to more improvements from MG.
« Last Edit: January 31, 2017, 01:26:02 AM by mudskipper »
it's the journey I crave
& the guzzi makes it all sweeter
'06 Breva v1100ie
Offline sib
« Reply #96 on: January 31, 2017, 07:46:21 AM »
The more I learn about the details of the V7III line, the happier I am with my V7II Stone.
Like what?  Would like to hear your thoughts.
Well, we don't know much yet.  Aside from the single clock on the Stone III vs 2 on the Stone II, here are a few things I've noticed on comparing the III specs (taken from the Italian Moto Guzzi web site) to those of the II.
The III weighs more (189 kg dry) than the II (177 kg dry).
The III has less ground clearance (150 mm) than the II (179 mm).
The III develops the same maximum torque (60 Nm) at a much higher rpm (4900) than the II (2800).
The rear suspension travel of the III is less (93 mm) than that of the II (100 mm).
The III claims only 1 more kw of maximum power (38) than the II (37).  They're probably equal within the margin of measuring error.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline jpv7
« Reply #97 on: January 31, 2017, 08:48:48 AM »
Comparing suspension on the 2 different models is pointless - they will both be not very good.  BUT it really depends on what you plan to do with the bike.  If you are going to tool around on it, leave it stock.
If you want to go quicker, be more comfortable, and be in control, upgrade it.  Also, I notice that the majority of people do springs only, and I assume the reason is cost.  But if you are going in there, you might as well do it right, and address everything.
I'm in the process of doing just that on my V7ii, and Race tech springs ($100) and Gold Valve Emulator ($160) means you will get it done for under $300 if you do it yourself.  Sure, you won't get the fancy preload adjusters at the top of your fork, but I usually only adjust them once anyways.
From experience, there will be a huge improvement in the ride quality and control of the bike.  I'll report back when I'm done.
Online Vagrant
« Reply #98 on: January 31, 2017, 09:16:00 AM »
Simple, finally somebody woke up and figured out the only time the V7  (or any Guzzi) retails is when it's sold at $1000-2500 off retail.
many might recall about 8-10 years back Guzzi was getting yelled at by a lot of dealers because a few were cutting margins and making them look bad. so in their stupidity they slashed the dealers margins and put the extra money in the US distributers pocket. had they lowered retail there might be a lot more dealers and Guzzi's on the streets of the US.
Maybe now they have realized that the other brands are constantly bringing out new and improved products while Guzzi continues to die in the future.
And yes I love my 15 V7 and would buy another at the same $6000 plus sales tax only I paid a year ago.
Offline Air-Cooled
« Reply #99 on: January 31, 2017, 09:34:18 AM »
I paid msrp for my Stornello
1973 Moto Guzzi V7 Sport, 2016 Moto Guzzi Stornello, 2023 Vespa Primavera
ponti_33609
« Reply #100 on: January 31, 2017, 09:42:36 AM »
hmmm....you ordered it from the dealer?
Offline Adan
« Reply #101 on: January 31, 2017, 10:00:10 AM »
Stornello's are now $8,500 new.  It's pretty tempting for such a gorgeous one of a kind bike.
V9 Bobber
Zero S
ponti_33609
« Reply #102 on: January 31, 2017, 10:03:04 AM »
For sure.
« Reply #103 on: January 31, 2017, 10:33:40 AM »
I can't help but think that dealers are going to end up losing money on any existing stock of V7-II due to the $1-1.5K price drop of the III over the II.
Offline Air-Cooled
« Reply #104 on: January 31, 2017, 11:29:25 AM »
Yes, one of the first ones. Renaissance Mitircycles doesn't discount much but they have (had) great service. Never knew why Steve closed up shop
Offline sib
« Reply #105 on: January 31, 2017, 01:27:46 PM »
I paid MSRP for my V7II Stone, took delivery on May 8, 2015, the first one to arrive in RI.  But, I sold my '13 V7 Stone the same month, for $6000, with no accessories (I transferred them to the V7II), 12,000 mi on the odo and a set of original Metzler Lasertechs that needed replacing.  So, overall, I think I made out OK.
Offline kenvil1
« Reply #106 on: January 31, 2017, 01:40:39 PM »
The Stornello is $11,790.00 in Canada ($2,600.00 more than the Stone).
 In comparison, the Indian Scout 60, with a 78hp 1000cc water-cooled V-twin mounted in an aluminum frame, retails for $10,999.00.
I really like the V7, but I think Moto Guzzi needs to address their pricing if they want to compete, especially in North America.
Offline Air-Cooled
« Reply #107 on: January 31, 2017, 01:48:45 PM »
Yes, I know I probably paid too much (actually $11,500 otd) but with so few being imported and really liking the bike, I sprung for it. No regrets
« Last Edit: January 31, 2017, 01:50:09 PM by Air-Cooled »
ponti_33609
« Reply #108 on: January 31, 2017, 02:00:59 PM »
At the end of the day you guaranteed you got the bike you wanted.  Nothing wrong with that.
Offline kenvil1
« Reply #109 on: January 31, 2017, 02:15:36 PM »
Yes, I know I probably paid too much...
I wasn't implying that the Stornello isn't worthy of the price, they are handmade after-all. I myself can often be found ogling #307/1000 at the local dealership.
bpreynolds
« Reply #110 on: January 31, 2017, 07:44:09 PM »
Sadly, I think most Guzzi dealers are already losing money.   :sad:  Seat of the pants impression but I haven't seen this much non-current Guzzi stock sitting on dealer floors in years.
« Reply #111 on: February 14, 2017, 06:14:41 PM »
Oh boy!
Prices just announced .....
http://www.roadrunner.travel/2017/02/14/2017-moto-guzzi-v7-iii-makes-u-s-debut/
 "But Honey! It's such a bargain!":thumb:
« Last Edit: February 14, 2017, 06:19:15 PM by Penderic »
Offline Socalrob
« Reply #112 on: February 15, 2017, 02:32:45 AM »
Oh boy!
$9,995 for the Aniversario model looks good to me.  I'm really drawn to it.
Offline sib
« Reply #113 on: February 15, 2017, 09:13:23 AM »
My dealer is now selling V7II Stones for ~$7500, about $1500 less than I paid in May 2015 (the price of early adoption).  He's also ordered a few V7III's.  He's a long-time multi-brand dealer who has an affection for Guzzi's, and he doesn't seem at all perturbed by the drop in prices.
Offline Socalrob
« Reply #114 on: February 15, 2017, 10:17:35 AM »
I was in my dealer here in SoCal, ProItalia, and they had their Guzzis marked down $1500-$2000 for a factory discount.  Of course ProItalia adds back in some dealer prep and destination fee, and in CA the sales tax DMV stub is above 10%, and the $8,500 Stornello I was sitting on somehow got to just past $11,000 OTD (might have been $11,400, can't recall exactly).
I've bought a Ducati from PI before, and as they are only about 3 miles from my house, I would likely buy from them again.  I have never owned a Guzzi, and having an established dealer with decent mechanics close by makes it seem pretty safe to jump in.
Now if I can just source some mag wheels, a small windshield, some fancier suspenders, and luggage that matches that beatiful brown leather seat on the Aniversario, I think I have found the perfect LA commuter and Angeles Crest Hwy runner.
