Author Topic: death of the manual in pickup trucks  (Read 16742 times)
Offline ITSec
Re: death of the manual in pickup trucks
« Reply #90 on: February 17, 2017, 09:45:43 PM »
Damn my new 06 Baja with a manual was 2 vehicles ago (4 if you count all the ones in the household).
Truthfully I kinda miss it. I might still have it if I'd gotten the turbo. But I was in a "try to be more responsible and conservative" phase... That obviously didn't take. [emoji23]
Great vehicle though. Tough as nails and rock solid in foul weather.
Here's a shot of mine from a few years back - nothing's changed, though  :wink:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Kev m
« Reply #91 on: February 17, 2017, 09:47:54 PM »
Nice!!!
Offline Kev m
« Reply #92 on: February 17, 2017, 10:52:15 PM »
So I was having some fun with this today, remembering all my manual transmission "trucks."
This was from a Chilton cover photo shoot. This was a RWD when I bought it, but a 4wd a year later. 😎
« Reply #93 on: February 18, 2017, 12:14:32 AM »
I used to prefer manual tranny vehicles until I got into pulling RV trailers.  Then I found out a stick shift tranny is not better, and noticed automatics got the same mpg or better than manuals.  :huh:  Now all my cars/trucks are automatics and I have no regrets as I've had no more maintenance than with the manuals(actually less).  :huh:
Offline Aaron D.
« Reply #94 on: February 18, 2017, 07:53:41 AM »
An auto usually will require less maintenance, the basic design is quite clever and similar to the 3 speed hubs on bicycles, and the torque converter takes a lot of the punishment that kills clutches.
Offline Murray
« Reply #95 on: February 18, 2017, 06:53:31 PM »
That has not been my experience! Regular fluid and filter changes assuming you don't turn it over every couple of years and let it be the next guys problem, rebuilds are vastly more expensive, if they say ZF !@#$ing run away! Even if you go through two clutches over the life of the vehicle and pay someone else to change them I doubt you'll get anywhere near the cost of an auto.
Offline sign216
« Reply #96 on: February 18, 2017, 09:18:26 PM »
My experience too!  Autos are $$$.  Manuals are old school simple.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #97 on: February 18, 2017, 11:24:16 PM »
I've had the opposite manual/automatic experience of you guys.   Maybe that's because I have pulled trailers that put a burden on stick clutches vs. automatics  if the auto. has a tranny cooler like it should.  It's kind of the same thing with a Guzzi clutch vs. a wet/multi plate MC clutch.  When a Guzzi car type dry clutch goes out it's a major PIA vs. when a wet/plate Jap. bike clutch goes out.   To each their own preference.
It does matter how you treat the 2 designs and their quality too.  If you get stuck in stop/n go traffic an auto. is by far better.
Offline Aaron D.
« Reply #98 on: February 19, 2017, 07:27:30 AM »
Rebuilds more expensive? Not in my experience, and in fact I've rebuilt a few automatics. And usually it's just a dirty valve body causing trouble. Otherwise easy stuff.
I prefer working on manuals but a problem with a manual often ends up being a more involved issue. That all said, I still prefer driving manuals.
Rough Edge racing
« Reply #99 on: February 19, 2017, 09:08:55 AM »
 I was "trained" to rebuild Allison AT 540 medium truck auto trannys and GM Turbo 350/400.  Along with the Torqueflite and Ford C4-C6 types these old school autos are not difficult...Modern auto  6-10 speeds with electronic interface are more demanding... Some of the new 5 and 6 speed manuals need special tools and the use of a press...Generally the old 3 and 4 speeds require just hand tools, put a press might be necessary..Automati c  transmission rebuild/replacement in a newer vehicle can cost north of 3000 bucks....A clutch replacement might cost $1000  in some cars and twice that in a Diesel 4x4 pu truck...
 Generally speaking, most won't have transmission problems in a typical time period the vehicle is owned from new... Except for several models know for issues...
Offline Two Checks
« Reply #100 on: February 19, 2017, 12:34:35 PM »
I understand why they stopped putting manuals in trucks. Nobody reads them.
1987 1000 SPII "Il Duce' II"
Offline gearman
« Reply #101 on: February 19, 2017, 04:00:14 PM »
All of my vehichhillles are autos. Cars,truck ,Honda Gyro,Guzzi Convert. I love them all.
Offline sign216
« Reply #102 on: February 19, 2017, 04:45:54 PM »
I usually keep my cars until about 150k miles.  Buy them used.  So I'm looking for something easy for my mechanic.
Usually I can keep the orig. clutch beyond 150k miles (except when I was trying to teach a girlfriend to drive a standard, big mistake).  My work cars are automatics (not my choice) and they are traded out before the mileage gets too big.  Did have a Chev auto transmission fail at 80k miles, but the dealer covered it.  Kudos to McLaughlin Chev. of Whitman, Ma.  Their service dept. is top notch.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #103 on: February 19, 2017, 04:53:43 PM »
I'm probably the one buying your old cars.   I don't consider them "used" until they've got about 150K on them ....  :wink:
Offline old head
« Reply #104 on: February 19, 2017, 06:50:25 PM »
In my 45 years of driving, I have owned more manuals than automatics.  I can only remember one time when 1 time when I had a transmission issue and that was an automatic.
It was an 84-85 Accord that I bought for 300 as it wouldn't go into drive.  towed it home, change the oil and few times and it worked, but just the first 3 gears, still wouldn't go into 4th, but since my daughter used it around town no biggie.
during the summer when she wasn't using it to go to college, I had it rebuilt.  Worked fine until I got rear ended and it was totaled about 6 months later.  But I made money as the car was worth much more than I had in it.
never had a clutch go out on me, had a rear seal leak a couple of times, but that is about it.
Still, I prefer manuals, just a preference.  I think clutches and autos are much better than they used to be, as I have several cars over 200k without clutch issues.  My Saturn and Dodge 2500 both over 300k and neither has had a clutch replaced.
However, the wife says the next one will be an auto, she is tired of shifting in stop and go traffic.  So......
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Offline sign216
« Reply #105 on: February 19, 2017, 06:57:51 PM »
While we are remembering....I recall when I was a student with no money, I had a used Honda with their strange Honda-matic 2 speed transmission, that you shifted.  A clutchless auto that was shifted between 1st and 2nd, and those were the only two gears.
That car lasted only a few months due to some other issue that I don't remember.  It wasn't the best car, but it's wasn't the worst.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline screamday
« Reply #106 on: February 20, 2017, 12:51:47 PM »
Here's my last manual trans pick-up. These were taken right after I got it painted.
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
Offline sib
« Reply #107 on: February 20, 2017, 01:34:11 PM »
My first car was a used '54 Chevy 6 coupe.  I broke a tooth off 1st gear by trying to impress friends with my clutch-less shifting technique.  After that I was more careful.  I owned several auto trans used cheap sub-compacts while I was a student, then graduated to an auto trans Corvair (talk about unreliable and impossible to tune!), then an auto trans GTO (It could go fast but was impossible to stop!).  Then a succession of manuals including a 1966 BMW 2000-Ti, a couple of VW Rabbits and a Toyota Corolla.  My current cage is a 2004 Prius I bought new and now has 165,000+ miles.  Over the last ~60 years and ~1,000,000 miles, I've learned to adapt to both manual and auto transmissions, and I've never had a problem with any of them, after that first broken gear tooth.  For some reason, I've never owned a pickup, so this whole post is off the thread, sorry.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #108 on: February 20, 2017, 04:42:35 PM »
 :1: My initial thoughts when I first saw the thread title.  :grin:
Kentktk
« Reply #109 on: February 20, 2017, 05:10:07 PM »
Manuals are a hard sell these days when you want to get rid of one. Limited market.
http://minnesota.cbslocal.com/2016/10/11/report-only-18-percent-of-americans-can-drive-manual/
« Reply #110 on: February 20, 2017, 05:57:06 PM »
Old Head
I don't have manual tranny issues........it's the clutches that don't last for me when I own the vehicle for a long time and end up having to abuse the clutch in some situation, which wouldn't happen with an auto.
Offline MadMike
« Reply #111 on: February 20, 2017, 06:15:40 PM »
Here's a picture of my Manual Truck pulling my Manual Jeep YJ....I had to trailer the Jeep from Iowa to New Jersey
I would never entertain an automatic vehicle ...2/5ths of driver input (clutch and shifter) are taken over by "the machine". Steering, Breaking and accelerator are too boring by themselves.
« Last Edit: February 20, 2017, 06:25:57 PM by MadMike »
2013 MG Stelvio NTX, 1975 MG Eldorado,
1991 BMW R100GS/PD, 1976 BMW R75/6,
2004 HD Roadglide
Rough Edge racing
« Reply #112 on: February 20, 2017, 06:25:55 PM »
 What sort of abuse?
« Reply #113 on: February 20, 2017, 06:31:18 PM »
What sort of abuse?
Like 1 time my 16' RV trailer wheel got stuck in a pot hole and to get it out I had to abuse slipping the truck clutch.   Not too much later the clutch was worn out prematurely.  :violent1:
Rough Edge racing
« Reply #114 on: February 20, 2017, 06:40:20 PM »
 Driver error!  You should stick to two pedal vehicles   :evil:
Offline 1Sourdough
« Reply #115 on: February 20, 2017, 09:44:37 PM »
I feel your frustration, but the mfg aren't forcing it, the buying public is.  The American buyers simply don't want sticks.  If they did, the mfg would gladly provide them, all they want to do is sell more units.  It's hard to text and steer and shift all at the same time! :sad:
Oh;  A few years ago it was said to be the need to restrict rapid engine speed changes such as are common with manual transmissions, to make the pollution numbers.  Have the manufacturers gotten by that roadblock?
1993 Strada 1000, 1996 R1100RT, 1999 V11 EV
                            -30-
« Reply #116 on: February 20, 2017, 10:13:02 PM »
Yes, technically it was driver error, but I had just quit my job, my family was living in a house in norCal and I was in Vancouver, Wa., it was cold/wet, I had just backed up my trailer in a trailer park to leave, and managed to put my 13" trailer wheel in a hole I didn't even know about!   At that point I just wanted to get the hell out of there !!  :evil:
I did but in the end it cost me a $400 new clutch on my Dodge Ram 50.
« Reply #117 on: February 20, 2017, 10:21:08 PM »
Ram 50 AND a travel trailer?
That clutch was going to go, just a matter of when.  better the clutch than the engine, tranny or rear end.   :thumb:
Or the brakes.   :shocked:
« Last Edit: February 20, 2017, 10:23:27 PM by LowRyter »
« Reply #118 on: February 20, 2017, 11:59:28 PM »
Actually I had 2 Ram 50s I pulled RV trailers with.  1 was a `80 2L 4 spd. and the latter 1 was a `84 2.6L automatic.  I pulled a 16' Komfort Lite trailer no problem.
Before those I had a `75 Toyota Chinook 2.2L pop top motor home.  In the snow that rig didn't need chains since all the weight on all it's tires it got traction no problem w/4 ply tires & low 20s mpg w/4 spd.  :bow:
« Reply #119 on: February 21, 2017, 09:40:49 PM »
FIL had a Comfort Lite fifth wheel he towed with a Rampage.  Yep, the little FWD pickup based on a car.  5sp and clutch.  He pulled that thing over 15k miles.  Only burned out one clutch.  That was a sharp incline from a campground onto a highway and no room for a running start.  FWIW, I don't think an automatic would have done any better, probably would have burned up the fluid in the transmission if it had tried the same thing.
