I'll probably have to pay for the kit myself as there is unlikely to be much wear but c'est la vie. Jim
There are a host of prettier, lighter, aftermarket pipes available but they will all perform better with a dB killer installed due to the design of the heads and the cam timing and profiles.Pete
With the Beatle Map, and based on the dash computer, I averaged 43.5mpg on a 323 mile loop this weekend. I can't wait to do it again this weekend.
Where are we going?
....It was a matter of principle to me; I'd have been gritting my teeth every time I rode it if I'd been done brown by those guys ....
Thanks for the to do/wish lists for the bike while it's in the shop. Thousand Oaks just picked it up, and I spoke at length with Eddie.
Do you know if the suspension link recall has been done assuming your bike was recalled?
We discussed this last week. Engine no. 13524 was officially the first roller tappet Griso. Although Pete said that wasn't exactly true as a few flat tappets have been recorded with higher engine numbers.
Interesting... the 2012 SE I'm about to buy is A8-13542. Hopefully my new ride isn't one of those 'leftover' flat tappet units.
If it is, we could start an entire new thread about replacing the flat tappets with rollers.
The service records show work done for a "double con-rod recall" warranty claim. Is that the suspension link?
OK, Demar, that was FUNNY (slapping knee). That's exactly what I meant about brevity and wit! I plead guilty and I really do thank everyone for their amazing patience and to Pete especially who I can tell probably has little hair left from tearing chunks out when someone like me shows up. Hopefully you won't be saddled with another newbie who doesn't know enough to research enthusiast forums. The service records show work done for a "double con-rod recall" warranty claim. Is that the suspension link?
**** Don't know if I could have shown my face here again after that...
do I get any newbie points for that?
Thousand Oaks pulled the tappets out. Images below. Even after reading all about the issue, I never would have believed a 1300 mile Griso's tappets would have this amount of wear!
Not a particularly good engineering solution to make a bad problem even worse by having bits of "diamond like" coating floating through your oil.. hello..
Don't forget to grease those swingarm bearings!
strange and unexpected qualities, which somehow bring out a fierce love and loyalty in one, became the image in my mind of the marque.
