Author Topic: Finally found a LED headlight bulb that fits  (Read 18173 times)
Offline leafman60
Re: Finally found a LED headlight bulb that fits
« Reply #30 on: March 06, 2017, 09:28:06 PM »
Well, the rub for me is that this LED uses as much power as a halogen!
Offline redhawk47
  • Traveler
« Reply #31 on: March 06, 2017, 09:36:18 PM »
How do you figure that? the LED is 20 watt, Halogen are 55/60 watt.
Dan
« Reply #32 on: March 06, 2017, 09:46:28 PM »
My trucklite LED is 35w total drain.
Offline swooshdave
« Reply #33 on: March 06, 2017, 09:54:53 PM »
The Cyclops is 25/50 so if you run it on high all the time it will be close to the halogen on low.
To reiterate I tend to ride my old bike around town and in the daylight. Make sure you make the right lighting decisions based on your riding style and lighting needs. What works for me may not be best for you.
2001 V11 Sport
Offline leafman60
Offline redhawk47
  • Traveler
« Reply #35 on: March 07, 2017, 12:55:03 PM »
25W on low, 50W on high
http://www.cyclopsadventuresports.com/7000-Lumen-H4-LED-Headlight-Bulb_p_169.html
Now I understand. I forgot that you had been talking about the 7000 lumen LED. I was thinking about the more common LEDs.
I noticed this in the 7000 description "(Do not expect this bulb to last longer than your vehicle)".
This translates to me as "Carry a spare bulb".
Dan
« Reply #36 on: March 07, 2017, 01:14:21 PM »
It translates to me as "This bulb will die a scant few seconds before the bike and you do."    :evil:
Offline leafman60
« Reply #37 on: March 07, 2017, 04:06:18 PM »
Specs say 30,000 hours.  The same as the previous 3800 lumen version.
I just got a message from Darryl, at Cyclops. He says my problem is the reflector design....
« Reply #38 on: March 07, 2017, 04:32:44 PM »
I used to try explaining reflectors and parabolas and lenses and such in this context, but I got shouted down so much by folks who didn't care that I quit.
Quote from unnamed source:  "Unfocused and unaimed? It's light in front of a reflector. The light comes out of the front of the headlight and onto the ground. Win!"
How's a guy supposed to discuss that?
Offline swooshdave
« Reply #39 on: March 07, 2017, 11:05:12 PM »
It goes back to my point on how you are going to use the bike. Like I said I just need something mostly during the day around town. Bright and annoying for the people in 2 ton killing machines to see. I made no claims about it working great for touring at night.
You can name the source, I have my big boy diapers on!  :shocked:
2001 V11 Sport
« Reply #40 on: March 07, 2017, 11:14:36 PM »
I understand the application -- basically you ride daylight only.  For the incidental night use, for you it doesn't matter.  I have no problem with that, and didn't mean to come across as picking on you.
Offline swooshdave
« Reply #41 on: March 07, 2017, 11:21:41 PM »
I'll be right back, need to change my diaper. I pee when people pick on me...  :grin:
2001 V11 Sport
Offline wirespokes
« Reply #42 on: March 08, 2017, 12:30:09 AM »
I recall reading a thread on LED bulbs and one of the guys found he got much better light 'direction?' 'focusing?' by tilting the bulb a little. The idea being that the light source wasn't positioned in the correct place to bounce it off the reflector properly.
What HID would you recommend? It seems they have about the same power consumption as the LEDs.
« Last Edit: March 08, 2017, 12:32:04 AM by wirespokes »
« Reply #43 on: March 08, 2017, 01:26:37 AM »
I got components for mine through
http://www.ddmtuning.com/index.php
I used the projector and bulb kits to make these:
Offline leafman60
« Reply #44 on: March 08, 2017, 06:36:05 AM »
Update.  I received another message from Cyclops.  They suggested I try the aiming spacer they provided (I didn't realize it was in the box) and see if it helps.  I installed it and will try it tonight.
Offline leafman60
« Reply #45 on: March 08, 2017, 06:38:41 AM »
I have bought several from various sources on Ebay.  They're cheap.  I go for the thin ballast types that have molded weatherproof wire connectors  at the ballast etc.
