Author Topic: Satardays 850-T, Ahnold part deaux. or the purests be damned lol  (Read 36200 times)
Offline troyhamilton
  • Dr frankie
I got it in satarday, yesterday it was sunny and i got the piston moving. Today the weathers been kinda wet and cool. cloudy. I forgot to mention I have no shop! just a big front porch and a huge tool shed. heres the pictures thus far. im gonna run a old hond seat that you see and a old cb 750 headlight. lo buck . i need a kick stand. i want to get it running to save this motor. i am going to put the ev motor in it eventually but i want to ride before summers over!
I will be raising the tubes..
free image hosting
upload image free google
« Last Edit: September 11, 2017, 12:18:10 PM by troyhamilton »
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline NCAmother
Re: Satardays 850-T, Ahnold part deaux.
« Reply #1 on: March 31, 2017, 11:19:53 PM »
Keep us posted!!  I have a basket 850-T as well, great to see others building theirs (might give me enough inspiration to get off my a** and work on the bike :)
Howdy
  • Dr frankie
« Reply #2 on: April 02, 2017, 03:04:26 PM »
today i started the tear down to put the G5 cam in that I got from FotoGuzzi, many thanks! its getting ready to rain and i only have a porch to work on unless the weather is good, lots of WD-40, and I will wait till my brother Kenny Schubach can be here to give me a hand, a 1100 is danged heavey!
image hosting russia
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline NCAmother
« Reply #3 on: April 03, 2017, 04:52:55 PM »
The 850T gets a V11??!!!!!  Dude, that is awesome!!!!
Howdy
  • Dr frankie
« Reply #4 on: April 06, 2017, 03:36:21 PM »
today i repaired a broken upper shock mount. the po had broken a shock bolt off. then the nimrod got a ease out and that woulda worked except the bit went off center. the easeout was in the shock tube. i had to use a sander to go past the ease out since its hardened steel. then drilled the bolt out and i cut a bolt and put it in the remaning shaft. then i drilled the tube so i could spot weild-roset it. then i cut some metal to make up the 1/4 i had to sand down. down side? ill have a stud sticking out. ill weld it up the next time i have the chance. no pictures till i get it welded lol.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #5 on: April 14, 2017, 06:33:59 PM »
put my lawnmower cam from a G5 in today, thanks to fotoguzzi! got my pins moving also pictures later. im tarred out and looking for a new house! mold!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #6 on: April 14, 2017, 07:07:30 PM »
Mold?? on YOU or the house??   :grin:
  • Dr frankie
« Reply #7 on: April 18, 2017, 05:37:38 PM »
mold is in our house that we rent. Gotmy ev1100 in my t today. no pictures till i get a phone card in 2 weeks! slowed internet! and we will be moving. got a lot to do.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #8 on: April 22, 2017, 08:21:24 PM »
motors in...
 heres the motor while i had it apart.  says .40 on the rods. bottom end was spotless
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #9 on: May 04, 2017, 07:03:05 PM »
more blurry pictures/crappy camera. I am going to drain my oil back to the timing sensor on the front of the motor but untill we can get moved im not doing anything.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #10 on: June 05, 2017, 08:27:47 PM »
spent the weekend moving. soon will start getting stuff done. fabricateing some one off parts. will be bringing the bike home soon. will have a indoor shop/garge.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #11 on: June 17, 2017, 08:36:15 PM »
got in our new house. today i made a oil return that will run the oil into what used to be the sensor over the timing chain since the ev doesnt drain into the block. and i rethreaded the spark plug with a helicoil. waiting for the locktite to set 24 hours is a longtime
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #12 on: June 20, 2017, 04:34:11 PM »
today i put the new clutch cable on. adjusted it. readjusted the clutch arm, must have had a midget engineer in that job...still got to drop my dist in. speedo cable, rewire it from scratch....got to figure out a seat. may end up making a kick stand cause i aint got one. need a set of headlight brackets...but its coming together. no pictures/no camera!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #13 on: June 25, 2017, 06:56:07 PM »
got a bit to do yet. rewire, easy peasy, still have been very busy with getting in the casa... gonna get the dizzy in tommoro..if the good lords willing.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Online Tom H
« Reply #14 on: June 26, 2017, 01:09:56 AM »
Turning out to be a nice looking bike!!
  • Dr frankie
« Reply #15 on: June 26, 2017, 05:32:03 PM »
today i put the dizzy in. forgot to tighten the bolts. dizzy jumped out....put it back in, got lucky. its in good now, tom, thanks I have a lot to do yet.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #16 on: September 08, 2017, 11:10:42 AM »
i have been very busy the past few months. today i wll get gas in the carbs and see if it will run!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #17 on: September 11, 2017, 12:17:26 PM »
got the Monster of Frankinstein going, sounds great but loud lol...
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
Re: Satardays 850-T, Ahnold part deaux. or the purests be damned lol
« Reply #18 on: September 11, 2017, 12:19:18 PM »
anyways ill be riding soon.   :bike-037: :   :copcar: :copcar: :copcar: :copcar: :copcar:
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #19 on: September 25, 2017, 06:21:44 PM »
today I got a battree. its running but tanks still too dirty to use. im going to fill the fuel lines and ride to the top of my driveway and coast back to the garage, repeat! repeat! lol
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #20 on: September 26, 2017, 03:28:36 PM »
rode it today! im back with the living...
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #21 on: September 29, 2017, 08:13:38 PM »
today i got a top box it came off a susuki...cut and graft so it fits...next is a vetter fairing when i find one!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #22 on: October 10, 2017, 04:15:08 PM »
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #23 on: October 14, 2017, 09:27:31 AM »
new old windsheild
how do you upload pictures
 have a great day!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #24 on: October 23, 2017, 12:50:31 PM »
 honda cb750 windsheild added last night!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #25 on: November 05, 2017, 02:18:33 PM »
 :bike-037: rode it just a minute ago. lo air in the tires, leaking oil,,,didnt go far incase it quit, debble bike lives, felt very  :boozing:  :afro: :drool: powerful!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Online Tom H
« Reply #26 on: November 09, 2017, 05:45:04 PM »
Yeah!!!!!!
  • Dr frankie
« Reply #27 on: November 10, 2017, 05:50:40 PM »
I rode it to the corner and back. timings way off.had it up to 55 mph! oil pan gasket is leaking. got 2 new gaskets but no extra oil...I think it needs me to build a heel toe shifter. im going to heat a old chineese 19 mm and bend it at a 90 degrees and weld it to the old shifter. yeah yeah here comes the purests lol. i have very little cash. both tires are i beleve flat spotted! Ill buy the new front first...yes its loud like thunder! lol may figure out something else on the exhaust...but not quite...speedomitor works.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #28 on: November 29, 2017, 12:19:42 PM »
put bags on from a yamaha venture royal and built a trailor hitch!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline jvb
« Reply #29 on: November 30, 2017, 04:40:46 AM »
They may have flat spotted due to sitting for a long time.
Take a ride and allow them to warm up and they may come good. If they are old it is delaying the inevitable replacement, but, they can wait till you have the funds. (but don't leave it too long.)
Enjoying your story.
John :thumb:
