Author Topic: Stelvio ! SERVICE Indicator  (Read 18434 times)
Re: Stelvio ! SERVICE Indicator
« Reply #30 on: April 06, 2017, 01:24:00 PM »
Is your cruise control working?
Offline Jimijoe
« Reply #31 on: April 06, 2017, 01:46:02 PM »
The last time I used the cruise control it worked. I did not use the cruise control  on the ride when the service word showed up, I have not tried the cc or driven the bike since seeing the "service " warning  ( not the wrench) I know how to eliminate the wrench, Thanks, Pete for answers, will keep following to see what I can learn . Thanks John
« Reply #32 on: April 06, 2017, 01:50:12 PM »
See if the CC is working. If it isn't it's most likely the clutch or brake light switches as these are linked to the CC.
Offline Jimijoe
« Reply #33 on: April 06, 2017, 01:59:06 PM »
Then it must be OK to run it to check the cc ? Will check when I return Thanks
Offline smdl
« Reply #34 on: April 06, 2017, 07:39:42 PM »
Thanks, ... no I don't  know how to access on bike, in fact I just got this alaris just for this "service" warning,  & the electronics are all new to me. Appreciate any help I can get
I don't have a 1400 myself, so can't provide the exact procedure for that bike, but I'm sure someone here can help.
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
Offline Jimijoe
« Reply #35 on: April 06, 2017, 08:17:02 PM »
Thanks to everyone for your help,....... Pete, I think your on to something;  just took the bike out for a spin on the freeway, and could NOT get the Cruise Control  to go on. Do you know if there is a way to isolate whether it the clutch switch or brake switch or should I order each (maybe have one become a spare?)  Thank you Pete as you seem to have nailed it. At least found something not working.
Offline John in PA
  • ML & me
« Reply #36 on: April 06, 2017, 09:17:53 PM »
I also have a Cal 1400 with the SERVICE warning. Is there a way to display the diagnosis code on the dash? How about with Guzzidiag?
Also, on the 1400's, how do you reset the wrench icon without PADS?
John Wells
Hollidaysburg, PA
Buncha Guzzi's
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #37 on: April 06, 2017, 10:17:11 PM »
Yes, Guzzidiag will diagnostic errors, I'm yet to see them on the dash but then I prefer to check things directly with Guzzidiag.
Reset service wrench icon code is 34534 which I discovered last year.  Yell if you need instructions how to apply it, but it is quite straightforward.
« Reply #38 on: April 06, 2017, 11:38:44 PM »
If the brake lights work it's unlikely to be the brake light switches which leaves the clutch...... :grin:
Offline Jimijoe
« Reply #39 on: April 07, 2017, 12:17:24 AM »
Makes sense, thank you , Pete you have really nailed my problem down quickly. I WILL source out the part and get back with my results. Thank you, John  :thumb:
Offline jacksonracingcomau
« Reply #40 on: April 07, 2017, 12:30:30 AM »
Today I had same problem as Dave & Joe, different bike, different symptom but I bet it's same part.
Ducati Scrambler wouldn't start in gear with clutch pulled in
Pathetic micro switch bent itself to not function
Fixed with pliers but next time it gets bypassed, nonsense safety switch for fools and their lawyers in this case but for cruise control cut it's pretty important.
No code on dash on Scrambler just an obvious fault
Better switch called for, if hydraulic clutch, pressure switch banjo bolt would solve it
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #41 on: April 07, 2017, 01:48:35 AM »
Pressure switch with banjo bolt needs to much pressure to switch. Won't work. Normally the microswitch has a long life.
Easy to check with guzzidiag.
Paul
Daytona 1225, Stelvio 1151
Offline Jimijoe
« Reply #42 on: April 07, 2017, 01:33:15 PM »
California 1400 clutch switch for your viewing pleasure
Offline Jimijoe
« Reply #43 on: April 15, 2017, 02:25:25 PM »
Hi all , just wanted to get back with the results, first, thanks a lot to pete, & kiwi dave, ...I found  the switch online, my friend soldered on the original wire loom, installed the switch,  & cleared the "Service" word by clearing the TDC using the alaris (techno-research). Hope this helps anyone else with similar problem.
Offline Jimijoe
« Reply #44 on: April 15, 2017, 02:28:11 PM »
