Author Topic: Veglia Gauge Bezels  (Read 22516 times)
Re: Veglia Gauge Bezels
« Reply #30 on: December 01, 2018, 06:32:29 PM »
BSANUT on Ebay sells the chrome and black bezel kits, I have installed many of them, good quality.
https://www.ebay.com/itm/Veglia-80mm-Tachometer-Bezel-Repair-Kit-Ducati-Moto-Guzzi-Morini-Laverda-CHROME/183426872678?hash=item2ab517f566:g:mqsAAOSwg3FUq~em:rk:5:pf:0
My method is to clamp the instrument into a jig I made up, I prey the bezel off very delicately working around the gauge with a very small flat glade screwdriver
Pry off the old bezel, remove the glass, clean the instrument face and then install the new glass, rubber rings and bezel.
Clamp it all back into the jig, make sure the gauges is clamped down very firmly.
I use a brass punch to tap the bezel around the gauge progressively flattening the ring
For my Laverda gauges I made a holder from aluminum and used a tool in my lathe to spin the ring back on
The tool is just an old wheel bearing in a piece of steel bar, the face of the bearing is pressed up against the spinning instrument and the cross slide turned in to press the ring over.
Offline wicks
« Reply #31 on: November 06, 2024, 10:44:22 PM »
Can't find these currently for sale - are they NLA?  Dirty inside the crystal...
Is there someone who does this as a service - send the whole instruments for a cleanup and such?
'77 LM1 / '93 1000s / '73 V7 Sport / '06 Ducati Paul Smart  / '73 Porsche 911s / '94 Porsche 964 Turbo / '94 Defender 90
Offline pehayes
« Reply #32 on: November 06, 2024, 11:05:33 PM »
Offline Cal3Me
« Reply #33 on: November 07, 2024, 12:05:57 AM »
Here is another choice for gauge repair I have used a few times for both British & Veglia ,,,, Andrew Taylor of SMITHSWERK in Carson, Iowa. He presently will be repairing my LeMans gauge I sent him . He also converted KPH to MPH for me on my Nuovo Falcone and a 1950's Norton single. Very happy with his work.
I have also used Joel Levine in the past.
 andrew@smithswerk.com
He has had a vendor spot at the Davenport, IA swap meet for a few years now. Give him a call 712-746-7450
TMS
