Author Topic: Increasing V7 Tire size  (Read 32309 times)
Offline DangerDan
« on: April 22, 2017, 08:51:32 PM »
Thinking of increasing the tire size on my 2013 v7 special.
Searched around but havent found what i am looking for..
Front -
Stock is 100/90-18 thinking of going to 110/90
Rear -
Stock is 130/80-17 thinking of going to 140/80
Thinking of this change to fill out the front fender a bit and to even up the circumference front to back.
Clearance measurements of my Speed Deamons shows that I will be clear, however i am thinking of going to BT45 or Scorpion Trail 2.
Has anyone had experience with this size setup or have thoughts about it?
Thoughts on the Scoprion traill 2?
Cheers
Offline redhawk47
  • Traveler
Re: Increasing V7 Tire size
« Reply #1 on: April 23, 2017, 12:21:43 AM »
FWIW 110/80-18 is alternative front tire size per V7III specs.
I had Scorpion Trail 2s on my Stelvio. They were good tires but the front cupped pretty early. I am not an aggressive rider, nor very sensitive to the tires. I think they are rated 90/10 on/off road.
Why do you want larger tires? Just for appearance?
I'm looking at 80/20s for my V7II Stone. I like to ride dirt roads as well as pavement.
Dan
« Reply #2 on: April 23, 2017, 12:54:48 AM »
1 time I went from a 100/90-18 front tire on my CX100 to a 110/90.....BIG mistake!   Made the handling from OK to like a truck.  :cry:
On my 750 Breva I went from a 130/80-17 rear to a 130/90 to get longer lasting tires and taller gearing....works for me + it made my speedo accurate.  :thumb:
« Last Edit: April 23, 2017, 12:58:21 AM by Arizona Wayne »
« Reply #3 on: April 23, 2017, 04:34:43 AM »
They're already over tyred. If you want it to *look* good accept the fact it will throw the steering even further into the toilet and will handle like a fridge but I suspect that won't matter too much so as long as they won't roll off the rim? Go fer yer life!
Offline Perazzimx14
« Reply #4 on: April 23, 2017, 07:26:33 AM »
Never thought about it until not but I couldn't agree more with the modern small block being over tired. My V50 with a 90 up front and a 100 in the rear handled worlds better than my 2012 V7R.
Offline sign216
« Reply #5 on: April 23, 2017, 09:45:37 AM »
I went with smaller tires, to lower height.  Same tire size actually, but some diligent searching showed low profile tires.
They've really worked well.
Sorry for the thread drift.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline DangerDan
« Reply #6 on: April 23, 2017, 03:00:10 PM »
Yea I saw that 110/80 is an alternative, however i have been looking at the 110/90.
Reason for the change...probably not a good one haha. Was just looking at the bike and thinking that i would like the front fender 'filled' a bit more.
Also a bit of a smoother ride through bumps (or the never ending stream of potholes on my commute), bit of extra cushion.
...Really that much of a difference?! This is my first bike and I ride pretty tame around the city, but certainly dont want a fridge.
The scorpions only come in the 100/90.. so if i go with those its a moot point.
Which tires did you go for? My original plan was to get Whitewalls (ive got a red/orange + white bike) but they are nowhere to be found in acceptable sizes.
« Reply #7 on: April 23, 2017, 03:10:13 PM »
The heavier big block Guzzis are OK with a 110 front tire but the CX(LM II) bike it was a disaster in the curves even w/a handlebar instead of the clip ons the CX came with.   Now my CX has a 110/90-16 on the front and that works great.  :thumb:   I added that after liking my LM IV w/a 110/90-16 on it's front.
« Reply #8 on: April 23, 2017, 04:32:01 PM »
I really don't think I could get a 130/90/17 in the rear of the Breva. The 80 goes in deflated just to get it in.
Offline sign216
« Reply #9 on: April 23, 2017, 04:57:13 PM »
I've got Bridgestone Battlax in 100/80 for front, and 130/70 rear.  They shave a little height off the bike without any suffering.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline malik
« Reply #10 on: April 23, 2017, 05:53:50 PM »
If you are after a smoother ride through bumps, ensure your tyre pressures are around the 36/36 psi recommended. And change your fork oil - that makes a difference, the oil is only supposed to last 6months anyway. If that's not good enough,  get a set of Racetech springs for your weight - may need playing about with the pre-load tube, the air gap & the oil weights, and set up your suspension properly, front & rear.  They work together. Aftermarket rear shocks make a difference also. The Gazi's on the V7C seem better than the Ikons on the V7S, but either are an improvement on the stock. Worth the cost? Perhaps - depends on how much riding you do, & how long you plan to keep the bike. Change the fork oil first & see how you go.
« Reply #11 on: April 23, 2017, 10:39:27 PM »
You don't, huh, well I've done it twice with no issues.  The only real difference is the OD of the 2 sizes.  The centerstand doesn't complain but the sidestand does some.  I do it to get longer mileage out of that tire.
Offline Kev m
« Reply #12 on: April 24, 2017, 03:01:46 AM »
Front -
Rear -
I agree it would likely hurt handling.
And if evening up circumference is a goal:
100/90 = 90mm of sidewall
110/90 = 91mm of sidewall or +2mm of circumference
130/80 = 104mm of sidewall
140/80 =  112mm of sidewall or +8mm
So net you get the front and rear tires 6mm closer in circumference.
Do you really think that something you're gonna see?
I suspect you will feel the change, not from the balance of circumference but because of the increase in widths (absent some dramatic change in profile).
Not to mention if you're​ not changing front and rear together the actual front circumference at the tread will mean different circumference when you put a new rear on to go with the partially worn front.
Personally I have changed tire sizes on various bikes, mostly to go down slightly in rear width for quicker break over into turns. I've only ever gone up 10mm once on a front, and that was my current Harley.
I don't think I'd make these changes to my 13 Stone.
Offline DangerDan
« Reply #13 on: April 24, 2017, 03:01:30 PM »
Thanks for the feedback.
A refresh on the suspension is likely due. I dont think that it had been done prior to my owning of the bike.
After further review Ive decided to go with the Scoprion Trail 2. Which means I wont have the option to upsize. Regardless i think the feedback received turned me against that plan.
Dan
« Reply #14 on: April 24, 2017, 06:00:00 PM »
Unlike car tires, which no matter the brand seem to stay close on tire dimensions, MC tires vary widely on OD & width depending what style tire it is.  Just because they claim to be the same size many of them aren't the same size as competitors tires of same claimed dimension.  For instance, Bridgestone BT45 tires run smaller than other brand tires of the same designated size.
« Last Edit: April 24, 2017, 06:03:29 PM by Arizona Wayne »
« Reply #15 on: May 19, 2020, 09:13:45 PM »
I just fitted an Avon 140/80/17 RoadRider on the rear of my V7iii Special.
I had to let the air out to wrestle it in but its quite a bit higher than the stock so hopefully the speedo will be a bit closer to reality
I originally asked for Michelin Pilot Activ but my tire guy said why would you put a 25 year old design on and wouldn't sell me one.
I also converted the spoked wheels to tubeless so hopefully I won't be pulling it off again for a long time.
« Last Edit: May 19, 2020, 09:18:50 PM by Kiwi_Roy »
Offline Kev m
« Reply #16 on: May 20, 2020, 06:22:36 AM »
That's stupid:
* It's a 50 y/o chassis anyway.
* The Pilot Activ design might be old, but its modern rubber and works just fine.
* You're the customer.
But again, the Pilot Activ has done EVERYTHING I've asked of it, including a track day. I don't need more. I'd tell him to "bugger off".
Offline pyoungbl
« Reply #17 on: May 20, 2020, 08:10:45 AM »
The 130 series tire on my 2013 V7 Special is a tight fit.  I'm not sure a 140 series would fit without rubbing on the swingarm.  Oh, and even the 130 is a bit of a bitch when it comes to reinstalling unless I also remove the bevel drive.
Peter Y.
'13 V7 Special (red/white)
Offline malik
« Reply #18 on: May 20, 2020, 03:31:13 PM »
As a matter of interest, the special Pirellis made for the V7 endurance racers are, I believe, a 140. John at Motociclo (local dealer) reports that they fit on, no problem. Interesting tread pattern, but not cheap.
Offline bad Chad
« Reply #19 on: May 20, 2020, 05:41:54 PM »
I don't know what to think?
Sport Demons on v9 seem ok, no complaints, only 900 miles so far.  I suspect from what I'm reading they will be lucky to get 5K.
Bias vs Radial?  That's where you guys have me all over a barrel.   SB don't come with radials, why?  Is it all about cost?  If radials really were that much better, wouldn't it have made sense for Guzzi to put them on the Racer?  They already charge a premium for that model, why not put radials on to highlight its sporting characteristics if it only ads $50?
1988 YX600 Radian
« Reply #20 on: May 20, 2020, 08:37:45 PM »
Peter Y.
It is close for sure, barely slide a credit card through the gap the right side, lots of room on the left of course
It would be easy enough to shim it to the left 1mm or so but I don't believe it will rub, i'll keep an eye on it.
That's stupid:
True, I am the customer, the customer is always right eh!
Problem is I have a long term relationship with this guy, he has treated me very well on several occasions.
He did pay attention when I told him about the speedo error and found me a tire with a higher profile, a good inch taller than the Pirelli
He's a multi brand shop, doesn't have a dealership but he does ride a Guzzi as his personal bike so he can't be all bad.
Anyway i'm pleased with the Avon so far.
« Last Edit: May 20, 2020, 08:59:39 PM by Kiwi_Roy »
Offline Kev m
« Reply #21 on: May 20, 2020, 09:11:07 PM »
As long as you're happy.  :thumb:
Though I still think his reasoning was crap.
Offline MMRanch
  • MMRanch
« Reply #22 on: May 20, 2020, 09:51:23 PM »
https://tiresize.com/comparison/
This is a nice tool when comparing tire sizes .   I've had it bookmarked for years .   It needs a width larger than 100 , so use 101 instead.
The width of a 130/80 and a 130/90 are the same
The compare boxes is what your looking for .    Speedometer correction data is on there too!
The 130/90-17 AM26 AVON lasted almost 10,000 miles ... I only got about 4,500 from the Sports Demon.   I'm running a 712 Shinko now and its lasting better than the Demon did .
« Last Edit: May 20, 2020, 10:11:33 PM by MMRanch »
2016 V7-II Stone
Offline chrisfer
« Reply #23 on: May 21, 2020, 01:23:03 AM »
That's stupid:
The rubber was good 20 year ago and is always good. But no the rubber of the Pilot Activ is the same as 20 years ago, no changes.
For a good rubber modern improvement and stay Bias, there is now the Metzeler Raodtec 01 for V7.
« Last Edit: May 21, 2020, 01:23:39 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline Kev m
« Reply #24 on: May 21, 2020, 06:53:11 AM »
We know for sure that Michelin has not changed anything about the way they make the compound for the Pilot Activ?
Ok, let's assume that is true. That's no longer considered modern rubber? I mean did something not change between say WWI or WWII and when the Pilot Activ was first made?
And let's assume something again, IF NOT, DOES IT MATTER? I mean crap, don't most companies both motorcycle and tire aim to build a quality product that is going to work well and bring you back to them again?
Sure something might be BETTER - just like I can find a lot faster bikes or bikes with better suspensions.
But if the tire works and does everything I want it to do, then does BETTER actually buy me anything?
I have no problem with Kiwi's tire guy saying something like "Why don't you consider this, it will stick more" or "I've really seen much better performance out of" but that's not the same as refusing to order what he asked for right?
« Reply #25 on: May 21, 2020, 08:45:08 AM »
I think to say my tire guy refused to order we a tire I asked for is a bit strong, first of all he said he hasn't sold one in 4 years and offered the lower profile newer version of Michelin but listened when I raised the concern about speedometer error. The tire size comparator MMRanch posted is very good IMHO
I will keep you posted on how I find the Avon.
« Last Edit: May 21, 2020, 08:52:18 AM by Kiwi_Roy »
Offline Groover
    • Scooteropolis
« Reply #26 on: May 21, 2020, 09:28:09 AM »
I researched this a lot when I got tires for my G5, I think one of the tires sites out there, which I can't find anymore (maybe Dennis kirk) showed overall diameter for each tire, which did vary from brand to brand. I ended up going up one size for both front and rear (110/90 instead of 110/90 in front, and 120/90 instead of 110/90) in the Pirelli Sport Demon, and if I recall correctly they ran "smaller" than some other brands anyway. I mostly ride two-up and I wanted better load protection (hitting pot holes when riding 2-up) which was more important to me that going fast in twisties, which I don't do when I'm 2-up or hardly ever with my G5. I also like the look, and the handling works for me. I don't think the bike feels much different overall than what was on there before (which were still the old 3.5 and 4.2 measurement type tires)
Avon showed the overall diameter at that time, and so did Michelin. These are old screen shots I did, but I'd probably check their sites for new information. Rim width will come into play when it comes to the profile distortion if going wider
Though as most say, probably best to stick with the original size. I just wanted to point this out that it also depends on the brand when it comes to a few mm. I think this is what Arizona Wayne was also saying.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Kev m
« Reply #27 on: May 21, 2020, 10:41:39 AM »
Fair enough.
:boozing:
« Last Edit: May 21, 2020, 10:51:17 AM by Kev m »
Offline TexMexStrada
    • YouTube Channel
« Reply #28 on: May 23, 2020, 04:57:13 PM »
Dan
Good choice! I've had them on my V7III for over 5,000 miles now, quite happy with them. Haven't had any cupping issues, the rear does wear quite a bit in the middle on dead straight Texas highways, but the thread depth means I'm looking at 8,000-10,000 miles out of a set. I found that running the front tire at 1.5 psi more than the rear (when cold) helps the handling as the pressures even out on the road (the rear pressure climbs more than the front when hot).
TexMexStrada
2018 V7III Stone
« Reply #29 on: May 24, 2020, 06:17:25 PM »
I'm pleased to report the Avon 140/80/17 RoadRider on the rear of my V7iii Special bought the Speedo to within spec
I had my buddy ride at 100 klicks by GPS and the V7 followed suit within a couple of KPH
