Author Topic: Electronic ignition for older Guzzi's  (Read 6302 times)
Offline ray bear
« on: May 03, 2017, 01:15:34 AM »
Tri Spark have a new electronic ignition for older Guzzi's, they make a good product and I  have personally had good success with their units fitted to my rocket 3 and commando.
I wont be fitting one to my Eldo as the points system suits me fine for how I plod around  and the V7 sport works fine with its Dyna system but thought someone else may be interested although not cheap   cheers Bill
http://www.trispark.com.au/home/products/
http://trispark.blogspot.com.au/2017/04/new-kit-for-moto-guzzi.html
« Last Edit: May 03, 2017, 01:20:18 AM by raybear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline Don G
Re: Electronic ignition for older Guzzi's
« Reply #1 on: May 03, 2017, 02:29:22 PM »
Has anyone tried one on a Guzzi yet?  DonG
« Reply #2 on: May 03, 2017, 03:19:22 PM »
Wonder if they realize the (single-point) distributor housing of the V700/Ambo/Eldo/V7 Special/850GT is much smaller than the (dual-point) timer housing of the Tonti-frame bikes. I can't see how one unit would fit both...
Offline swooshdave
« Reply #3 on: May 03, 2017, 04:37:29 PM »
I just left them that note.
2001 V11 Sport
Offline cwiseman
    • C&D Motorsports
« Reply #4 on: May 03, 2017, 07:32:59 PM »
I know the C5 ignition from Paul Crowe works like a champ in my Eldo and sounds like it is a similar set up to the tri-spark.
618-544-RIDE
Offline swooshdave
« Reply #5 on: May 04, 2017, 12:25:14 PM »
What years were the single point distributors?
2001 V11 Sport
« Reply #6 on: May 04, 2017, 01:12:32 PM »
'67 to '69 V700
'69 to '72 Ambassador/V7 Special
'72 to '75 Eldorado/850GT
Offline swooshdave
« Reply #7 on: May 04, 2017, 01:16:55 PM »
Thanks!
If they had designed it for the smaller distributor would it then work in the bigger one?
2001 V11 Sport
« Reply #8 on: May 04, 2017, 03:09:40 PM »
Thanks!
Nope. Totally different in the size, the way ignition unit would need to mount, the way the "trigger wheel" would need to fit onto the shaft, etc.
Single-point distributor: only 55 mm o.d.:
Dual-point timer:
Offline swooshdave
« Reply #9 on: May 04, 2017, 05:26:21 PM »
As always excellent information. Thank you for sharing.
2001 V11 Sport
Online n3303j
  • Ron Cichowski
« Reply #10 on: May 04, 2017, 07:03:03 PM »
C5 sure looks like PowerArc from Gary in Iowa. When they work they are very good on electric start bikes. On kick start bikes they can get confused counting pulses off the toothed wheel and can offer quite an interesting kickback. I have seen enough of the PowerArc fail that I carry a second unit as a backup.
The Australian unit is a magnetic sensor whereas PowerArc (C5) is using a pair of infrared optical sensors. One detects initial "home" position the second counts location away from home position.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline cwiseman
    • C&D Motorsports
« Reply #11 on: May 06, 2017, 02:12:31 AM »
C5 is indeed Powerarc, I've used them for years without any problems thankfully.
You could always use a newer distributer body with the gear from a older unit and make that work in a older loop frame. I used a motosplat ignition body to fit a C5 into my Eldo. If the engine was stock I would have never left the comfort of the stock points or probably should have just used a dual point distributer but was having trouble finding one by the time I needed it.
618-544-RIDE
Offline sign216
« Reply #12 on: May 06, 2017, 08:45:19 AM »
Anyone try Velleman's electronic ignition kit, for a points based system?  I've got a hankering to use it some old non-Guzzi bikes I have.
http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=350487
« Last Edit: May 06, 2017, 10:25:42 AM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
