Author Topic: EV Rear main seal: Frame crabbbing etc  (Read 8195 times)
Offline Mr Revhead
« on: May 08, 2017, 03:04:36 AM »
So, I need to replace the rear tyre on my 2003 Cali EV.
Thought I might as well get into the leaky rear main seal it has as well. I see there's a few articles about and I've been reading but have a couple of questions:
Haven't found much on the actual replacing of the rear main, am I correct in thinking I can just prise the deal out and drive a new one in easily once I have the flywheel out of the way?
How likely is it my 2003 bike has the plastic cage bearings in the gear box?
How hard is it to improvise the special tools with normal workshop tools? I suspect they will be hard to get and a lot of $$ here in NZ. Or, which ones are vital for the gearbox, clutch and flywheel?
What else should I do or inspect whilst that far in?
Who wants to come do it for me for $100?  :kiss:
Progress: https://goo.gl/photos/U6bnBZw83bzNS76N8
« Last Edit: May 21, 2017, 02:08:50 AM by Mr Revhead »
Re: EV Rear main seal
« Reply #1 on: May 08, 2017, 06:56:11 AM »
are you sure the leak is motor oil and not gear lube?
« Reply #2 on: May 08, 2017, 07:29:48 AM »
Make sure it's not just the breather hose, too..  :smiley:
Offline Madtownguzzi
« Reply #3 on: May 08, 2017, 07:47:21 AM »
Also check to make sure your crank case breather valve is working.
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #4 on: May 08, 2017, 09:56:49 AM »
There are a LOT of other leak points. Inspect them all.
It generally can be done with normal tools. If you need to replace the rear cover gasket, it is tricky without special tools.
100% sure you have plastic caged bearings unless they were replaced.
Sent from my SM-G935V using Tapatalk
Offline Mr Revhead
« Reply #5 on: May 08, 2017, 02:11:51 PM »
I don't think my bike has that breather hose. Can't see one..
Definitely not gear oil.
Ok so box apart and bearings as well.
This is going to be a big job!
« Reply #6 on: May 08, 2017, 02:46:47 PM »
it's a large hose (about 1" diameter)  from the top rear of the block to the center frame tube under the tank, known to crack w/age. can also leak into the bell housing and look like a main seal leak.
Offline twhitaker
« Reply #7 on: May 08, 2017, 03:08:20 PM »
If I'm not mistaken (and I usually am, ask my wife :laugh:), the '03 has the breather hose coming out of the timing cover.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #8 on: May 08, 2017, 07:05:20 PM »
Yes, somewhere in 2003 they put the breather in the timing cover.
Offline Mr Revhead
« Reply #9 on: May 08, 2017, 07:16:44 PM »
Thanks guys.
Pretty sure mine has the breather at the front.
Turns out I can hire the tools from Moto Kiwi here so that's one thing sorted.
Guess I just get stuck in swinging the spanners!
Online Tom H
« Reply #10 on: May 08, 2017, 11:11:33 PM »
Good luck :thumb: :smiley:
Let us know how it goes!!
Offline balvenie
« Reply #11 on: May 08, 2017, 11:36:46 PM »
ditto :grin:
Oz
04 Cali
Offline Mr Revhead
« Reply #12 on: May 09, 2017, 12:38:06 AM »
I will, but don't hold your breath, seeing as it needs a front tyre as well, and removing the front helps crabbing, I reckon I'll change the fork oil etc at the same time. And while it's all apart I'll give everything a damn good clean and polish. So it'll be in bits for a month or so!
Offline KiwiKev
« Reply #13 on: May 09, 2017, 07:44:44 AM »
Sent u a pm
Offline Mr Revhead
« Reply #14 on: May 12, 2017, 11:58:32 PM »
Well started today...
Worst part so far was getting the bloody air box out.
https://goo.gl/photos/p1DbXbvEncrpVZ6y7
Offline balvenie
« Reply #15 on: May 13, 2017, 04:05:59 AM »
Aha :grin: We have the same colour bike :thumb: Following your thread with great interest as my RMS should probably be replaced too.
Oz
04 Cali
« Reply #16 on: May 13, 2017, 09:30:29 AM »
Just wait until you try to get it back in.
Offline antmanbee
« Reply #17 on: May 13, 2017, 09:56:44 AM »
Time to throw that airbox out.
This is what I do with my Guzzis.
http://wildguzzi.com/forum/index.php?topic=85626.msg1350535#msg1350535
Offline Mr Revhead
Re: EV Rear main seal: Frame crabbbing etc
« Reply #18 on: May 21, 2017, 02:12:22 AM »
Righto, been busy and got the gear box out today, all pics so far:
Some are just for my reference so won't show much of interest.
I might have an issue with the drive shaft to bevel drive coupling. It's very dry on the bevel end and the coupling seems to be stuck fast to the shaft :( Not sure how I'm getting that out yet.
I assume a high moly grease is used on those splines? I don't think this was lubed right from factory.
« Reply #19 on: May 21, 2017, 06:26:09 AM »
The main thing is to *have* grease to stop rust/fretting. Looks like Luigi struck again..
Offline Mr Revhead
« Reply #20 on: June 17, 2017, 01:06:12 AM »
So it would seem my leak is probably the bearing housing gasket :(
I've checked the bolts are tight. Interestingly the lower 2 bolts are blind and NOT open to the sump as I've read in many places.
Oh well back together it goes. If it still leaks then at least I know what it is and it's not a major problem.
Offline Old Jock
« Reply #21 on: June 17, 2017, 03:47:19 AM »
So you going to open the gearbox?
Personally I wouldn't bother unless you have an issue.
However if you are and you want to replace the input and output bearings Pete might be able to help you.
If going in that far then it's also worth checking the shimming on the selector drum. Improving on standard can sweeten the gear changing of the box.
Standard Phenolic caged bearing on the right replacement on the left
Offline Mr Revhead
« Reply #22 on: June 17, 2017, 03:49:57 AM »
Oh yeah I did that. Replaced both and shimmed the drum  :thumb:
Offline Mr Revhead
« Reply #23 on: August 11, 2017, 02:04:22 AM »
So it's FINALLY going back together. Resorted to taking a couple days off work to get a chance to work on it uninterrupted.
I have to say trying to get the U/J and bearing back in the swing arm is  *@#$ of a job  :thewife: Then getting the swing arm in and lining up the splines isn't fun either!
And the air box... This thing is lucky i love it!!
But should have it all back together Monday. If I get things clean, those spoked wheels look nice, but man that are a prick to clean!
Was going to do the fork oil as well, but I don't have anything large enough to undo the caps, so that will be another weekend.
Offline balvenie
« Reply #24 on: August 11, 2017, 04:09:51 AM »
Mr. Revhead,
Did you end up replacing your rear main seal mate? :smiley:
Oz
04 Cali
Offline Mr Revhead
« Reply #25 on: August 11, 2017, 05:22:22 AM »
I did, but only because I was in there. Turns out the leak was from the rear main bearing carrier gasket. Whole new level of hassle doing that, so I tweaked the bolts up and if that doesn't fix it, tough. Coming from there it was only leaking straight down and not being flung all over the place so it won't bother the clutch.
FYI 2003 Calis, the two lower bolts in there, are NOT all the way through. They are blind holes contrary to a lot of things I read.
Offline Texas Turnip
« Reply #26 on: August 11, 2017, 05:58:20 AM »
Worst part so far was getting the " bloody" air box out.
How do you know when to use the word "bloody"? When you go in a whorehouse, do you ask for some "bloody" women?
Thanks,
Tex
« Reply #27 on: August 11, 2017, 06:35:49 AM »
 :shocked: You were *right there.* It's generally no big deal to pull the bearing carrier.. (?)
Offline Mr Revhead
« Reply #28 on: August 12, 2017, 12:27:15 AM »
Everything thing I read suggested it was quite the job as it's a very tight fit and is pressed out...
Offline Mr Revhead
« Reply #29 on: August 14, 2017, 12:45:14 AM »
Well, all back together and so far so good! Only been for about 10kms shakedown run as the weather was about to turn NASTY.
Nothing fell off! No leaks either... Time will tell on that one!
One tip: The spacers for the two bolts that hold the frame together and the exhaust mount/rear foot rest bracket, they go on the OUTSIDE of the frame. Otherwise they space the nuts out and jam your swing arm. lucky I spotted that before riding it!! Just goes to show, no matter how many times you check something when you're working on it. It always pays to check again!
Now, fingers crossed for some sunny weekends so I can get to riding this thing again, I'd forgotten how cool it sounds!  :bike-037:
