Author Topic: The care and feeding of aluminum wheels ....  (Read 1998 times)
Offline normzone
« on: May 10, 2017, 02:07:35 PM »
For a long time I didn't give a damn about my wheels - just kept tires on them, and washed them along with the rest of the bike when things got too dirty.
Recently I took a closer look at the rims, and there's a lot of oxidation going on - almost looks as though I live by the ocean, instead of thirty miles inland.
I have not gotten down to the toothbrush and scotchbrite level yet, but we may wind up there.
Of greater concern is some odd patterns around some of the spoke mounts in the hub on the front left, where the linked brakes front disc lives.
They are very localized, next to the spoke mounts. I know you modern guys would have posted a picture already, but I'm going to have to arrange for one of those police portrait persons to do a sketch based on my description.
Do these wheels ('99 EV Bassa) have any history of issues? I have not yet used any aggressive cleaners, just the usual wimpy stuff.
Re: The care and feeding of aluminum wheels ....
« Reply #1 on: May 10, 2017, 03:44:56 PM »
where I come from 30 miles IS by the ocean.
Offline Groover
    • Scooteropolis
« Reply #2 on: May 10, 2017, 04:46:41 PM »
Me too. Technically, you should be riding a boat not a bike.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline 93spada
« Reply #3 on: May 10, 2017, 05:37:44 PM »
Hi Folks
Just a thought.
Did some research on prepping for paint on aluminum.
From Aircraft guys, Found that it prefers an acid base (low pH) cleaner like a citrus type.
Most washes are alkaline (high pH) like S100. That is why they say to rinse off immediately.
The acid is not as good for grease but it is more gentle on ALL (engine etc.) the aluminum.
If you want to know the pH of a cleaner go to the mfg web site and look up the MSDS or newer SDS spec sheet. Just Google something like S100 cleaner MSDS and looking thru some others you will find this.
http://www.sunbelt-labs.com/catalog/msds/SK%20GHS%20Degreaser%20Cleaner%20_S100_.pdf
I am a little more careful now.
Paul
PJM
« Reply #4 on: May 10, 2017, 06:03:11 PM »
The inside of aluminum rims take a lot of abuse, moisture seeps in past the spoke nipples and slowly rots away the inside of the rim,
This is typically what I find when I pull the tire and tube off a Borrani wheel
To get the rim cleaned and inspected the spokes need to come off and the rim cleaned to bare alloy.
Soda blasting is safe, if messy
Cleaned but before the spokes have been removed
Once the spokes are out I take a small wire wheel in a dremel and clean the spoke recess in the rim.
Prior to reassembly I coat the inside of the rim with ACF-50
I have had one rim that was so corroded around the spoke dimples that it was dangerous to use, had to throw it out (Florida bike).
