If you have sufficient technique and stay in practice, you'll find you don't NEED to flat foot both sides at once.
My hesitance is the seat height and the maintenance since I'll be doing a short commute on it every day. I currently don't work on my own bikes so while I'm getting up to speed on performing my own routine maintenance I'll be running to the dealer.And, I'm short. I am in the process of moving back to the states now and am considering buying a particular used V7 from a dealer without having ridden it. I'm banking on the lower seat, my riding boots and if necessary modifying shocks to get it to a comfortable height. I don't like to mess with suspensions but since I'm still an intermediate female rider and I only weight 130lbs after a big dinner I think it'll be ok.There you have it. Thoughts? I appreciate your time....
That may be true. But for my part, despite a lifetime of experience, I'm not buying any more bikes where I can't comfortably reach the ground with both feet when stopped, even at 6'2" and 32" inseam.First of all, especially in a commuting situation on ugly city streets with potholes, gravel, manhole covers, antifreeze and diesel on the road, etc, you don't always have the luxury of stopping where you have good footing on both sides, and you can't always see what the footing is before you stop. Many a time I've stopped, put my feet down, and had one foot go right out from under me on pea gravel or a patch of slick stuff on the pavement. Only the fact that I had both feet down and my "body language" could get my COG to the other side instantly saved me from a fall. If my other foot were "strapped to the peg", I'd be down.My Stelvio was "tip toe" only when I got it. I got tired of that, especially riding it two-up with a load, so I lowered it an inch or inch and a half with a new rear suspension (the old one was worn out anyway) and an upgraded front, and now my feet are down flat. On my Triumph, I did a lowered seat and lowered footpegs and now am comfortable with the height - with a heavy bike, loaded two-up, I really need some stability.Lots of nice bikes out there, all of the modifiable for height if they're an inch too high. If it's more than that, I'd skip that bike and choose another .....Lannis
We can all come up with a litany of horror stories about the certain disaster that awaits the hapless poor individual that dares to venture out on a bike that they can't reach the ground from both sides at once on.
If she were my daughter, I'd be happier to see her come home with a broken clutch lever and a scratched knee, than a head on collision because she got hung out to dry trying to pass a belching diesel on an uphill grade into a head wind.
Great feedback, thank you. The standard I ride now now has a 28' seat height and I can flat foot it easily without riding boots. I appreciate your first hand feedback....
Is it a single throttle body V7? I recall reading here that those machines can have stalling issue on cold startup.
I think Sign answered the height thing well, though I would check with the dealer in question as they may be willing to set it up for you initially (including any suspension parts swaps).I've got a good friend who is 4' 10" and a Triumph dealer tried everything they could (swapping shocks, moving forks) to test fit her.As for commuting what's the daily/weekly distance?Let's say it's 200 miles/week (40/day), and you're exclusively using the dealer then you're back to the dealer about every 30 weeks or close to 2x/year.Is this acceptable to you? Will you have a backup method?That's the kind of question I'd want to ask myself.
The V7 is stylish, easy to ride, and extremely approachable in terms of routine maintenance. I am not quite certain about your traffic situation. It is an air cooled bike- so prolonged gridlock might be a problem. It's also mu opinion that it would not be a great highway machine. Plenty of folks here will screech and howl at that, but I still maintain that a larger machine would be better on the open slab. Then again, your physical constraints might rule that out. As far as parts and every day wrenching- you should have no problems. The groups here is extremely helpful. Is it a single throttle body V7? I recall reading here that those machines can have stalling issue on cold startup.
The V7 is stylish, easy to ride, and extremely approachable in terms of routine maintenance. I am not quite certain about your traffic situation. It is an air cooled bike- so prolonged gridlock might be a problem. It's also mu opinion that it would not be a great highway machine. Is it a single throttle body V7? I recall reading here that those machines can have stalling issue on cold startup.
Ok guys- thanks for all the helpful feedback and different points of view!Success! After going back and forth via email from here in Asia for a bit, the awesome rep at the dealer is going to hold the bike for me on refundable deposit until I return to the states in a couple weeks.He's also aware of the mods we might need and they're going to try to help sort it for me.We'll find out if it's doable! Thanks again for all your time as I hopefully move into a mid-sized!Ltl1Congratulations on your MG ownership. Not to bad when you have all these helpful people on this forum.Makes ownership a great experience!
Ok guys- thanks for all the helpful feedback and different points of view!Success! After going back and forth via email from here in Asia for a bit, the awesome rep at the dealer is going to hold the bike for me on refundable deposit until I return to the states in a couple weeks.He's also aware of the mods we might need and they're going to try to help sort it for me.We'll find out if it's doable! Thanks again for all your time as I hopefully move into a mid-sized!Ltl1Congrats - - and when you get her home - - post a photo for the forum!! :1:
