Author Topic: VHB30 notch setting  (Read 1577 times)
Offline JayDee24ca
VHB30 notch setting
« on: May 18, 2017, 02:12:01 PM »
Is a bike with VHB30s and K&Ns likely to run better with the needle pinned on the top notch or the lower notch? It would seem intuitive that with less restrictive air filters, a lower notch setting (pinned to the lower notch setting on the needle) would give more fuel to match the increase O2 t any given throttle opening. Am i looking at this correctly?
John D.
'74 Nuovo Falcone
'79 Convert
79 G5
the rest are all gone.....
Offline Two Checks
Re: VHB30 notch setting
« Reply #1 on: May 18, 2017, 02:15:23 PM »
Depends on jetting.
1987 1000 SPII "Il Duce' II"
« Reply #2 on: May 18, 2017, 02:22:10 PM »
As long as that is all you are changing, yes.
Edit: This can be instructive..
carb_jet_circuits by Charles Stottlemyer, on Flickr
« Last Edit: May 18, 2017, 02:26:12 PM by Chuck in Indiana »
Offline TOMB
« Reply #3 on: May 19, 2017, 10:50:12 AM »
It will run better if the carb Intakes are there and screwed in . Most people when installing K&N filters  just attached tve filter to the carb without the throuts attacbed which does not allow flr a snooth transition of fuel and air.
If you have the standard type of filter the opening is to small to fit over the carb intake tube so they have them turned down - just remove the ridge on the intake tube then reinstall go for a ride then make the next desistion
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline JayDee24ca
« Reply #4 on: May 19, 2017, 11:43:36 PM »
TOMB
Yeah, thanks TOMB, I have new intake runners (velo stacks) screwed on both sides, using the 2-into-one K&N filter. Its a real tight fit.
JD
« Last Edit: May 19, 2017, 11:44:27 PM by JayDee24ca »
'74 Nuovo Falcone
'79 Convert
79 G5
