Author Topic: Will my new V7iii be ok?  (Read 11744 times)
Offline lorengo70
Re: Will my new V7iii be ok?
« Reply #30 on: August 11, 2018, 07:48:55 AM »
Kev, will bring the valve stem seals possibility up to my mechanic and see if anything can /should be done.
Pete, I don't ride her gently. I flog the crap out of her and what my mechanic had said in the past is that if you are riding the bike at high speeds in the highway for an extended period, the bike will tend to burn some oil. As a such, I keep a keen eye on the oil levels every week. Just was not sure if a burn rate of 1 liter over 4000 km was a "normal" burn rate or if there is something else at play. I am willing to live with it as it is but if there is a fix I am not aware of, then would love to have my bike in top performing shape. .
Thanks for the thoughts and comments.
Cheers. Luciano
2016 V7 II Stone (Black)
2015 Suzuki TU250
« Reply #31 on: August 11, 2018, 10:31:44 AM »
You don't have to mention anything to your mechanic other than the oil consumption. He knows what to check. Pete may well be right still (he usually is).
Offline Roebling3
« Reply #32 on: August 11, 2018, 10:57:24 AM »
  I'm w/Chuck! Have done it that way on every new engine I've been exposed to; there have been dozens, from tiny 2 strokes to big, over the road diesels.
This is nearly an oil thread; with engines thrown in for added interest.
What does it mean that there is a gap of ~16 months before restarting?
Apologies, for wasting your time.
And GuzziGal? Looking for an xxx rating? Just sayin' R3~
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #33 on: August 11, 2018, 11:55:01 AM »
I've always said that MOST manufacturers check it unscrewed. That said I think my 13 Stone might have been the first Guzzi I've owned that was spec'd that way (unless I'm not remembering my B11 correctly, which is possible, it's been a while).
Not to mention I used aftermarket dipsticks on both the Jackal and B11, and on all 3 I've run the oil about midway on the sticks anyway. Usually cold... Sometimes checked warm.
Just double checked my manual - V7 III is to be checked with the bike upright on both wheels, warm, and with the dip stick "fully tightened".
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline Dofin
« Reply #34 on: August 11, 2018, 04:19:37 PM »
Hopefully at oil/filter change your verified the oil level position on your dip stick?   My V7 had the incorrect/wrong stick installed from the factory!!!   Indicated HIGHER oil level than it actually was.  I created my own hash marks on the prob so I could see the proper oil level.
76' Yamaha RD400
76' Suzuki GT500
89' Honda PC800
15' Guzzi V7 Stone
« Reply #35 on: August 11, 2018, 07:22:42 PM »
Surprise, surprise. Who would have thought?  :grin:
« Reply #36 on: August 11, 2018, 09:50:51 PM »
On the first oil change on the Breva I measured out the 1.8 lits specified, ran it until warm, then checked it with the dipstick screwed in as specified. It was dead on the "full" mark.
Flukes count I guess. :thumb: :grin:
« Reply #37 on: August 11, 2018, 10:25:47 PM »
It's really very simple. If it pukes oil into the airbox it's got too much in. Drain out a bit and try again. When it stops puking it out? That's the amount it needs.
Offline lorengo70
« Reply #38 on: August 12, 2018, 05:50:00 PM »
Ok, so spoke to the mechanic. He said that given the spark plugs look good, no evidence of burning oil in the exhaust and no oil in the air box, his conclusion is that everything is ok and to not worry. So I won't and I guess will just keep bringing a quart of oil on my road trips. Thanks to all of you for your suggestions. Cheers
2015 Suzuki TU250
Offline fossil
« Reply #39 on: August 13, 2018, 05:51:58 AM »
Copy and paste from the manual of my 2013 Stone: ENGINE MUST BE WARM TO CHECK OIL LEVEL. THE DIPSTICK MUST BEINSERTED BUT NOT SCREWED IN.
IF YOU CHECK LEVEL WHEN THE ENGINE IS COLD, OIL LEVEL COULD TEMPORARILY DROP BELOW THE 'MIN' MARK.
And no, I´m not yelling, the capitals come from the manual. The bike has to be balanced upright also.
Greetings from Germany!
Thorsten
Online Vagrant
« Reply #40 on: August 13, 2018, 07:11:29 AM »
as with many things the 17 oil check is different from the previous years.
« Reply #41 on: August 13, 2018, 03:24:44 PM »
A wise move in my book. I don't know about other countries but SG 10w60 is not readily available in your local service station out here. I like topping up (if I ever have to) with the stuff that is in there already.
Offline egschade
« Reply #42 on: August 14, 2018, 06:32:15 AM »
And no, I�m not yelling, the capitals come from the manual. The bike has to be balanced upright also.
New engine in the III (2007 and later). I copied from MY manual. I run near the full mark on the dipstick and it's not pumping oil into the airbox. Maybe I'll add a little more (right to the full mark) to see if it burps.
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #43 on: August 14, 2018, 08:52:19 AM »
the bike is ruined.
I'll give you $500 to take  it off your hands.
« Reply #44 on: August 15, 2018, 03:57:51 PM »
the bike is ruined.
What a selfless and generous offer.  :grin:
I am sure the OP will leap at the chance to get rid of his machine that is obviously going to blow the first time he fires it up. :evil:
