Author Topic: Sometimes its the simple things  (Read 5296 times)
Online sdcr
« on: May 26, 2017, 05:02:56 PM »
    Last month I discovered that the left Delorto PHF 36 carb was leaking past the float, when the pet cock is on. Had this same issue with the right side just after I got this Le Mans in 2012, which turned out to be a bad needle valve. So, same symptoms, I ordered a new needle valve, float and bowl gasket from our friends at MG Cycle.
    When the parts arrived in a day or two, I pulled the left carb, and set about installing the new valve, float and gasket. While I had the carb off, I cleaned all the jets, and pulled the petcocks, which had very little gunk in them. Buttoned everything up, and took it for a ride. Only went a short distance since we were due for rain, but it appeared that everything was OK. Last weekend, I went for a longer ride, left cylinder barely fired. Got it home, and started over my previous work. Initially, could not find what was wrong, but the left float was not filling with fuel. Went back over everything that I had done, checked and rechecked.
    Finally, after being completely flustered by this, I found the culprit. After pulling everything apart , I saw that one of the rubber inlet fuel lines had gotten kinked, most likely when I had done the original work. New piece of hose, and problem solved.  :grin:
« Last Edit: May 26, 2017, 05:03:55 PM by sdcr »
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Re: Sometimes its the simple things
« Reply #1 on: May 26, 2017, 05:09:48 PM »
 Are you sure it's fixed ? Sounds way too simple , sure it isn't ignition ? :rolleyes: :grin:
Online RinkRat II
  • Lake Powell AZ
« Reply #2 on: May 26, 2017, 05:41:46 PM »
 Precisely my thoughts too Dusty. Methinks a good sparkplug thread would be appropriate for the long weekend......NGK?? E3?? Champion?? :evil: :popcorn:
     Paul B :boozing:
Online sdcr
« Reply #3 on: May 26, 2017, 05:56:56 PM »
Well, I had thought about spark, and did check that. Spark is good.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #4 on: May 26, 2017, 06:04:53 PM »
     Paul B :boozing:
 Well...
 I don't know man , sounds like a bad battery to me  :laugh:
Offline KiwiKev
« Reply #5 on: May 26, 2017, 06:44:47 PM »
Probably using the wrong oil !!!
Offline Pop
« Reply #6 on: May 26, 2017, 07:56:26 PM »
Guys
It's clearly a case of non stock tires. What were you thinking??
Pop
Ride to eat, if there ain't food, I ain't goin'
« Reply #7 on: May 26, 2017, 08:12:46 PM »
Wrong sized hose clamp.
Offline wirespokes
« Reply #8 on: May 26, 2017, 09:09:19 PM »
I fear it's something more serious - a leaky valve or worn rings. Time for a teardown!
« Reply #9 on: May 26, 2017, 09:42:55 PM »
Hope you didn't use white floats.
Online rodekyll
« Reply #10 on: May 26, 2017, 10:07:36 PM »
     Paul B :boozing:
Ok.  I got an opinion here.  After a career as a mechanic and after changing plugs ad nauseum, I am 100% in favor of good sparkplug threads.
Thanks for listening.  I feel better now.
« Reply #11 on: May 26, 2017, 10:12:39 PM »
 The more I think about this , maybe pulling the heads for a look see wouldn't hurt , since it seems the group believes the sparking plugs need changing  :grin:
Offline guzzi4me
« Reply #12 on: May 26, 2017, 10:34:42 PM »
Can tell it's going to be one of THOSE weekends!
Regular air or nitrogen for tires?
What PSI???
Inquiring minds want to know...
Ride safe,
Jeff
Jeff S
Fruita CO
01 Jackal "Mistress"...sold
Offline Huzo
« Reply #13 on: May 27, 2017, 03:30:16 AM »
The firing intervals are up shit creek. Should be 180 degrees ( apparently) :embarrassed:
kidneb
« Reply #14 on: May 27, 2017, 04:52:11 AM »
Still in doubt ?
You can see the Moto Guzzi firing order reflected in music and dance here : https://www.youtube.com/watch?v=-holhDGpuX0
                :kiss:
Online sdcr
« Reply #15 on: May 27, 2017, 07:30:17 AM »
Uh,....thanks guys. it is running fine now.
I put a hose clamp on the float bowl, and all is well.  :evil:
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Rusty goose
« Reply #16 on: May 27, 2017, 09:50:19 AM »
Yep, uneven amounts of fork oil, happened to a friend of mine one time in the middle of nowhere.
Rusty
" A situation is never so bad that it can't get just a little bit worse."
« Reply #17 on: May 27, 2017, 12:14:43 PM »
Told ya! :grin:
