Author Topic: Really tiny valve lash setting?  (Read 2129 times)
Online bad Chad
« on: June 20, 2017, 04:40:11 PM »
I was setting the lash on my 229cc  CSC ZenShong today.  Its basically a knockoff of a seventies era Honda CG 125cc motor.  Very simple, very rugged.
Anyway it took me quite a while to get the gap just right, as its specked at 0.07 mm.   The gap can range from 0.07 -- 0.04mm, but to set the gap at 0.07 mm because as the valve wears the gap will shrink.   I get that it's a smaller motor, but I recall the big block Guzzi gap at something significantly greater?
1988 YX600 Radian
Re: Really tiny valve lash setting?
« Reply #1 on: June 20, 2017, 04:51:12 PM »
Did you re-torque the head too? Go like you are going big side of gap.
Offline pehayes
« Reply #2 on: June 20, 2017, 07:25:02 PM »
My antique Guzzi Falcone single 500 runs nearly zero-zero.  Valve lash improves as the horizontal cylinder lengthens under heat.
« Reply #3 on: June 20, 2017, 07:58:41 PM »
 Yes , and the OP's little motor is OHC , and OHC engines run small valve lash settings .
« Reply #4 on: June 20, 2017, 08:14:31 PM »
My `91 VX800 Suzuki SOHC water cooled V-twin 4 valve clearance is .004" good for at least 18K miles.  Right now it has 84.5K miles on it and it still hardly loses any dino oil between oil changes.  :bow:
« Reply #5 on: June 20, 2017, 09:03:13 PM »
The CSC TT250 (if that's what Bad Chad's bike is) has a pushrod engine, not OHC.
https://www.cscmotorcycles.com/Articles.asp?ID=293
« Last Edit: June 21, 2017, 09:44:34 AM by Antietam Classic Cycle »
« Reply #6 on: June 20, 2017, 09:27:54 PM »
The CSC TT230 (if that's what Bad Chad's bike is) has pushrod engine, not OHC.
 Well I stand corrected then .
Online bad Chad
« Reply #7 on: June 20, 2017, 10:27:48 PM »
Thanks Charlie.
1988 YX600 Radian
Offline wymple
« Reply #8 on: June 20, 2017, 11:28:33 PM »
My GS Suzuki runs about under .002 set correctly. They don't get adjusted (bucket & shim) unless I catch them around .001.  That's in inches, the factory calls for .03-.08 mm.  My Guzzis have always had many times that clearance.
