Author Topic: V7 series- What did you change/add from original and why?  (Read 115742 times)
Offline Bobic69
Re: V7 series- What did you change/add from original and why?
« Reply #120 on: February 01, 2019, 05:13:17 AM »
Where is the top shot from ?
Coledale, south of Sydney, just north of Wollongong.
Bellagio
Offline egschade
« Reply #121 on: February 01, 2019, 07:27:07 AM »
Handlebar risers,1" longer Hagon shocks, heavier Progressive fork springs,  Pirelli MT 60 tires and some cosmetics like the ribbed seat and tank pads.
« Last Edit: February 01, 2019, 07:37:29 AM by egschade »
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #122 on: February 01, 2019, 08:03:12 AM »
Moto Guzzi Engine Guard
Moto Guzzi Small Rack
MM10 LED running lights mounted to engine guard
Skenedesign LED rear tail/brake lights
RAM balls on handlebar clamp
Zumo 660 GPS and bike mount
Bitubo Shocks with red springs
Traxxion Dynamics Front cartridges
Red "Moto Guzzi" decals on wheels
« Reply #123 on: February 01, 2019, 09:09:25 AM »
Alrighty then
Offline jpv7
« Reply #124 on: February 01, 2019, 11:22:14 AM »
Let's see...
Rear Hagon shocks
Front Racetech springs, gold valve emulator, fork oil, forks raised 10mm
Continental RA tires
sintered front pads
LSL rear sets
LSL speed bar, CRG bar end mirrors, short levers
Hindle mufflers, fueling, canister removal
guzzi rear rack
metal fuel filter, plugs, caps
Dart flyscreen
Lots of fun on the backroads - fork was the best money spend FOR ME
Offline Rhodan
« Reply #125 on: February 01, 2019, 12:34:43 PM »
...1" longer Hagon shocks...
Did that affect the handling or the seating since the back is jacked up a bit?  I'm looking at options to raise the seat.  Taller seat is one but longer shocks is another.
Offline redhawk47
  • Traveler
« Reply #126 on: February 02, 2019, 12:21:49 AM »
How are those tires working for you? To get the correct sizes for the V7 it a MT-60-RS 110/80R18 on the front and a MT-60 130/70-17 on the rear.
That's a radial on the front and a bias ply on the rear! I have read reports of people getting away with that but the info I have found from tire manufacturers and distributors say bias front and radial rear only, or don't mix then unless the moto manufacturer says it is OK.
Dan
Offline romanoaf
« Reply #127 on: February 02, 2019, 08:12:13 AM »
Bought it dropped, so had to replace a few components. Front to back.
Headlight/speedo lowering bracket- 3d printed trim with added voltmeter (cosmetic)
Rizoma LED turnsignals (originals too conspicuous)
Bitubo fork adjustable drop in springs and caps (night and day over stock setup)
Agostini sport handle bars (originals were bent, the agostini feel short and sporty)
Machined lever controls
Barend mirrors
Mosfet voltage regulator (original failed at 1000km, then 1 more) no issues since
Wrapped headers (so I wouldn't burn myself anymore)
ZARD pipes (with db killers, running without) best value on the market at the time
Elk hide wrapped factory seat (original was scuffed)
Rear fender delete and LED brake light (cosmetic)
Bitubo adjustable twin shocks
Relay box for usb charging and voltmeter relay
Beetle Map
« Last Edit: February 02, 2019, 08:16:01 AM by romanoaf »
14' V7 Stone, 08' 1200S
Offline jpv7
« Reply #128 on: February 02, 2019, 08:50:35 AM »
Nah...just ran a Conti radial up front, and a Michelin bias rear all last season.  With tubes too.  Handled great.  And that is pushing it with the forks raised 10mm too.
Offline egschade
« Reply #129 on: February 02, 2019, 10:19:03 AM »
I have not experienced any handling issues at least not up to 70 or so. I don't push too hard on twisty roads but again it does not feel Twitchy or unstable.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline egschade
« Reply #130 on: February 02, 2019, 10:23:59 AM »
I worried about the front radial / rear bias mix myself until Moto Guzzi came out with the rough version which uses the very same tires. I figure if Guzzi is selling them off the floor with that combo I'll be fine. With several hundred miles on various roads and speeds I have not experienced any problems with the tires. Not sure I would use them for track days but that's not how I use my bike. Moderate speed riding I'm back roads is great and these tires are wonderful on dirt and gravel roads.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline redhawk47
  • Traveler
« Reply #131 on: February 02, 2019, 07:32:54 PM »
Sounds good. Moto Guzzi has "approved" that combo. But it doesn't mean that any radial front/bias rear is OK.
Dan
Dan
Offline SportsterDoc
« Reply #132 on: July 30, 2019, 08:27:28 AM »
Dart Marlin flyscreen
Pelican side cases
LED brake/tail bulb
Tool bag under seat
Who in Las Vegas bought my V7II from Las Vegas Yamaha?
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
Offline mechanicsavant
« Reply #133 on: July 30, 2019, 06:47:49 PM »
It’s a 16 V7II bought as a leftover when Guzzi had “deals”going . Out the door $7k
Since then .
Hepco Becker , 30 liter cases w/racks &tail rack & ctr Stand & crash bars (dealer discounted 15% all H-B)
Race-tech Ft. springs & fresh fork oil . Icon rear shocks
HH brake pads & bleed fluids (huge improvement)
Fat Ducks & de-cat-ed mufflers.Im sure not as good as the legendary Beetle map ,but a significant improvement over stock.
Conti Radials ,possibly best single improvement
Mirror extenders,Guzzi windshield, brighter headlight bulb w/relays to batt.
Sump extender. Re-paint ( OEM paint was poor)
Guzzi gel seat & tank pads (won @ Rally ! )
Shure seems like a lot , I’m hoping to ride & enjoy . It’s pretty well broken in @ 14k Mi.
No oil consumption & motor has smoothed out nicely
Offline Martins
« Reply #134 on: November 16, 2021, 10:09:35 PM »
Hi there..
Not much in here... 2018 V7iii Stone:
-Dart Piranha Fly Screen
-Mistral Short Slip-Ons (and compared with the originals... well.. they're a blast of a soundtrack in any ride....)
-Guzzi OEM tank pads
I just keep it simple
« Reply #135 on: November 16, 2021, 11:09:21 PM »
Made the wheels tubeless
Larger rear tire to correct the speedo
Extra loud horns to make myself heard
Driving spot lights to make me more visible
Added a pistol box to carry all my crap
Girbing Bluetooth heated gear controller
LED Headlight to save Amps for heated gear
Battery Voltmeter
Dart Marlin screen
And most important of all a cup holder and card holder so I can use the drive thru.
« Reply #136 on: November 17, 2021, 06:34:06 AM »
2013 Stone:
* GuzziPower (Ed Millich) Sump Spacer (for more oil capacity)
* Over-racing frame sliders
* HB racks for side and topcase (powdercoated black before HB offered them that way)
* Dart Marlin
* OEM Cafe take-off seat
* YSS Shocks
* Centerstand and Euro sidestand
* Black aluminum injector covers
* OEM mirrors (Guzzi 1200 sport/Aprilia/other brands)
I wouldn't mind figuring out a more robust headlight bucket, it's a little rattly/tinny.
I also would like black handlebars, but the positioning is right so I feel stupid changing them.
No need to change exhaust, and though the forks are rather basic they do they job.
I could see springing for a Corbin, but I've got two other bikes that are better for distance, do I dunno.
I should probably upgrade the tail light someday, but I'm not in a rush obviously (going on 5 years).
Still love it.
UPDATE -
* Used silicone to seal the headlight assembly to the bucket, now it's less rattly
* Changed the Dart Marlin to a Emgo Viper cafe fairing
* Changed Cafe seat to a Corbin Cafe seat
* Added Knight Desgin 2" drop pegs
* Added KOF control peg drops
NOTE: I've had an LED replacement taillight bulb in a package on the workbench for something like 2-3 years.  :shocked:
« Last Edit: March 06, 2025, 08:59:10 AM by Kev m »
Offline Brand X
« Reply #137 on: November 17, 2021, 09:33:26 AM »
2016 V-7ii Stornello bought last month with 400 miles..
quality oils/service
Dropped the fork oil, mixed my own batch
Ikon rear shocks
Conti road attack 3 tires,
Built all my racks for C-bow, and many luggage options there.
Givi tank bag, and custom quick-look ring
Dart Classic screen,
Side stand fixed in my press
Removed all the aluminum side cover plates/headlight #plate
Removed all safety stickers/reflectors :evil:
Metal fuel filter. because I don't care for the real swelled up factory one..
Cheap bar-end mirrors that I made to fit using my milling machine. Good view/super clear now..No longer a member of the Mickey Mouse Club.. :grin:
Gold Wing  clone ft pegs
Filled the front master cylinder to the correct level, so it no longer pukes fluid.. Funny how that works..
Heated grips on the way, and a e-bay racer tank with pads from AF1  I am going to store away the factory white tank for now.. These will be tough to find down the road, Although I could paint another one the same..(just not into painting things at this point)
It runs perfect, and needs zero mapping. although hooking up Guzzidiag is quick, and painless) Getting around 60 mpg up here in  the High Dessert Country in Oregon. Mid-grade gas works better then the higher spec no alky stuff . The sound of the Arrow high pipe is pleasing. Just right like the rest of the machine.(now)I have a bit over 1000 miles, and expect things are going to get better when things get worn in a bit.. Sweetheart now though.. :cool:
« Last Edit: November 17, 2021, 09:35:47 AM by Brand X »
Offline Roebling3
« Reply #138 on: November 18, 2021, 11:19:45 AM »
As my last new bike it was disheartening to learn: 'what noise. they all do that'. The gear noise is terrible, even with good ear plugs, The bike feels much heavier than 410, 430'. And it is! ~485. I bought the wee bitch anyway. All my friends ride Guzzis. The bikes are fun w/only good folks to be with.
Oddly enough? I'm fanatical regarding a possible breakdown. I like bikes that handle well, stop well and look good. Get you there and back, on time, with clean hands and clothing. Thanks to Jim Hamlin. He made a raft full of changes to make me grin: Legnano bars, all steel fuel pump, NGK spark plug connectors, swopped wire wheels for cast AND no tubes, added K-Tec front end. Jim had the seat cover changed to dk brown w/red stitching, added a tail rack and delivered it to our rally site. SURPRISE!!!  WOW! That's a dealer.
I rode it in rain for two days. So far so good,- 'til it wasn't. It's a'17 racer, Lower case 'cause I can't stand posers or matte finishes. I chose the changes over a few years hoping for more power, better handling and stoppage. I had the cast wheels powder coated. Added frt. fender extender from UK. and molded it in. Stripped the bike of all the "tin ware", added a Marlin instrument shield of fibre glass, so it could hold paint.
The bike is a very dark brown with gold dust. Front fender has a 25mm wide red line almost end to end. Side panels have a red checker board like some sport models and white stripe. The racer emblems were added.  I think it's a good looking bike. ~7700 miles. "Weigh" too heavy for me.
              For Sale. Pictures available.  R3~
Online Bulldog9
« Reply #139 on: November 18, 2021, 08:38:24 PM »
For the Stornello TT: Goodness where do I start......
1. Suspension: 420 MM Hagon Rear Enduro/Trail Shocks 7.5 LB KTECH fork springs. Better ride quality, increase in ride height (1.5" unladen, 3/4" seated) for off road riding.
2. Electrical: AUX LED driving lights, tail light, and USB Power port to the GPS Power lead, swapped out head and tail lights for LED. LED's to save power, and USB/GPS power.
3. Electrical Accessories: MGMP Module for Smart Phone App, Oxford Heated grips,TPMS. Data from the MGMP is useful but not necessary, heated grips ARE ;-)
4. Tuning/Engine: Beetle Map, replaced Plug ends, valves set at .10 & .15mm, Mistral Exhaust. Beetle Map is a must, the plug ends are a recommended prevention, tighter valve clearances work with the BM, and the Mistral Exhaust sounds even better than the Arrow, but is almost 2" closer to the frame allowing the custom HB rack.
5. Chassis: Modified Norge Windscreen adapted to Dart brackets, Stelvio Hand Guards, 1.5" mirror extension brackets, raised front fender by mounting on topside of fork brace/fender mount, Hepco Becker Triple bags with custom exhaust side bracket. Love the variety of bags available to the HB rack.
 Hepco becker Center Stand and Engine Case Guards, 1" SW Motech Bar Risers, Goldwing Pegs, custom seat by KOF. All these modifications were for function, better weather protection, carry capability of luggage, better fit for my body, and
6. Tires/Brakes: Shinko 705 in stock sizes, Front HH sintered brake pads. The HH pads have better bite and response for the single disk. Not impressed with the 705's. Had good press, but street performance lacks.
7. Cosmetic: Custom Painted Yellow Tank (added, did not paint the stock tank) and painted side covers with Medallions.
I may have missed a few things, but my goal was to create a V85 TT alternative. So far, I am very pleased with the outcome. The Stornello TT is an all road touring machine. I have over 7K on the build. Adequate on the highway, comfortable for 8+ hours a day, 45mpg, a total blast to ride, and if/when the pavement ends, the fun does not stop.
« Last Edit: November 18, 2021, 08:47:48 PM by Bulldog9 »
MGNOC#23231
Offline Brand X
« Reply #140 on: November 18, 2021, 09:31:53 PM »
OK Bulldog9
I will raise your Yellow Stornello tank by a Nickel  :evil:
I added the tank pads to tone it down a bit.I have different tank decals coming but will have to see in that.. Stored my white tank away to keep it mint..
Mine is a very nice street bike now..
Offline Roebling3
« Reply #141 on: November 19, 2021, 01:25:18 AM »
Addenda:I forgot to add the best of all.
As new the abs did not. A hard stop was, potentially suicidal. I bled the brakes many times, often overnight under pressure. I could ride it 5 -7 miles and the lever would pull to the hand grip. Several computer controlled bleedings (a la factory), were no better. Jim Hamlin offered a frt. brake system designed in house w/one of his Tech's. It's a 4 pot, radial Brembo caliper + radial master cylinder w/ a swing lever and remote reservoir. It's almost an exact copy of the system on my RS125 Racer. (that bike weighs less than 300#). I believe the yclept MG Euro racers have a very similar arrangement. What a difference! I could float the rear wheel. AND, within a week or so the abs began working. It's wonderful. Ill never have less.
I wonder how much the abs system weighs?   R3~
« Reply #142 on: November 19, 2021, 06:43:18 AM »
Since this thread was resurrected I guess I should update.
- Removed the rear rack
Added
- Sato Racing rear sets
- Mistral Short Exhaust
- V7 Racer Cafe seat
- LSL aluminum clubman bars
- Napoleon bar end mirrors
- Moto Guzzi Cafe Fairing
« Last Edit: November 19, 2021, 06:56:57 AM by twowheeladdict »
Online Bulldog9
« Reply #143 on: November 19, 2021, 06:22:12 PM »
OK Bulldog9
NICE!
Tell you what if they come out with a Carbon Bright Version of the V7 850, I could be convinced into one....
MGNOC#23231
Offline Brand X
« Reply #144 on: November 19, 2021, 10:03:15 PM »
NICE!
I took a few pics in natural light outside.. Running the standard Royster bag setup. It works well for grabbing some things at the Market.
I did get about 5.5 gals into it. any more, and it will start puking gas out the top hose on the tank. No clamp on it...
« Last Edit: November 19, 2021, 10:06:27 PM by Brand X »
Offline DucDucGuzz
  • Part 3
« Reply #145 on: September 06, 2022, 01:44:58 PM »
Hi all. I guess I’ll chime in.
After selling my beloved 2013 V7 due to an injury, and after resolving it with hip replacement surgery, I simply couldn’t do without another V7. So I upgraded. Here’s my 2020 V7III Stone S with the following updates…
- Bitubo fork cartridge kit/rear shocks (setup by Dave Moss Tuning)
- Agostini Sport drop bars/rear passenger pegs/Super Short exhaust slip-ons
- Sprint dry air filter
- GTM SAS delete/ECU flash tune
- EVAP canister delete
- Factory Guzzi V9 rear-sets w/Rizoma pegs (modified to fit V7III)
- BAAK short aluminum front fender
- K-town rear LED/fender delete
- Gecko front LED micro blinkers
- CRG Hindsight bar-end mirror
- Rizoma bar end
- ProGrip 780 grips
- ProGrip 480 lever covers
- Factory seat from V7III Carbon Shine
- Aluminum “Moto Guzzi” tank badge
- ShiftTech carbon license plate frame
I may be missing something, but I believe she’s fully updated with the all the mods I planned originally. I also realized that I dislike the OEM Dunlops, so
I’ve decided on Continental Road Attack 3s for my next set. Ciao…🇮🇹❤️
'20 MG V7 Stone S/‘20 MG V85TT/'12 Ducati SF848/'07 Ducati Monster S4RS
Offline Alfetta
« Reply #146 on: September 06, 2022, 02:09:55 PM »
1. after-market mufflers, so it sounds like a Guzzi
2. fabricated a rack with a back pad, for the wife.
3. mounted pelican cases, for the convivence.
4. cut both levers down to two finger units, cause that's what I like.
5. jammed a marble into the SAS air supply line, for no snap crackle and pop on deceleration.
6. mounted a new clutch cable.
7. replacing rear tire (again) average 4K on rear...
Offline Vagrant
« Reply #147 on: September 07, 2022, 03:15:58 PM »
How about a pic of the sas mod?
Offline chrisfer
« Reply #148 on: September 09, 2022, 03:56:00 AM »
On V7 III
1. Rear shock absorbers, for more comfort.
2. Exhausts, for sound and no catalysts.
3. Mapping, for better behavior.
4. Center stand, for safe parking, for inspection and maintenance.
5. Engine Guard, to minimize drops.
6. Rigid bags, little rear rack, practical.
7. Windshield, for more comfort
8. Mirrors, for the look.
9. Tank pads, for handle.
10. Horn, for louder.
11. Longer fender, to reduce projections
12. Conti Road Attack 3, because they are Radial
« Last Edit: September 09, 2022, 11:00:18 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
« Reply #149 on: September 09, 2022, 06:18:11 AM »
- Rizoma bar end
- ProGrip 780 grips
So, there is now nothing on the bike that distinguishes it as a Stone S. Even the engine cooling fins look black in the photo instead of polished. What are you going to do with all the take off parts?
