Author Topic: Stripped exhaust threads, how do you fix them?  (Read 13363 times)
Offline oldtime
Re: Stripped exhaust threads, how do you fix them?
« Reply #30 on: June 27, 2017, 04:35:44 AM »
I made an oversize tap and cut new threads same pitch  . Made oversize nuts  !! Ask Pete roper it was for a friend of his .
« Reply #31 on: June 27, 2017, 10:01:55 AM »
That's a great way to go if you have the machine and the skill to use it.
On that note didn't one of the suppliers used to sell oversize nuts that would cut their own threads?
« Reply #32 on: June 27, 2017, 12:47:30 PM »
Don't forget the exhaust gasket that goes between the the head and the header pipe.
Offline Farmer Dan
« Reply #33 on: June 27, 2017, 03:48:28 PM »
Have a pair on my bench already.  Waiting for payday then I'll order all the "stuff" I think I'll need.  Gaskets, O-rings, locking nuts, etc.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #34 on: June 27, 2017, 04:18:59 PM »
Offline JoeW
    • The Guzzi Doctor
« Reply #35 on: June 28, 2017, 11:02:16 AM »
Well I guess that settles it then.  I want to keep the bike as original as possible so if the head can be repaired then that's what I will do.  If it's that easy to put back on then I shouldn't have any trouble.  Once I send the head out I'll order new gaskets and exhaust nuts (with the keeper).
When you get the head back from Competition Cycles, please post a picture of the repair. I have an Ambo head in stock with a welded in insert, I don't know who did it. It looks like this...
Here is the repair done by my machinist...
Joe Walano
Offline swooshdave
« Reply #36 on: June 28, 2017, 12:30:12 PM »
Stripped exhaust threads are very common with Nortons. The nut gets loose and rattles around and destroys the threads.
Tighten when hot and you should be good.
There are several fixes out there for the Nortons. I've seen them welded up and recut, oversize nuts, inserts welded in and probably the nicest fix is an aluminum/bronze insert. The head is CNC cut to remove the old threads, and the new insert is screwed in. You can't see it when the exhaust is on but you know it's not going to cause you problems.
2001 V11 Sport
Offline Farmer Dan
« Reply #37 on: June 28, 2017, 01:48:12 PM »
Any chance the insert they make for the Nortons would be the same size we need for our heads?
I've never had the pleasure of owning or working on a Norton.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
Offline Farmer Dan
« Reply #38 on: July 07, 2017, 04:18:56 PM »
The head is on its way to Competition Cycle.  I'll post some pictures of it when it comes back.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #39 on: July 07, 2017, 05:12:37 PM »
Nice doggie!  :grin:
Offline danedg
« Reply #40 on: July 07, 2017, 06:26:30 PM »
It will look like this....
+100 for Comp Cycles!
Best deal I've found in a long time!
He said he can repair almost any brand.
« Last Edit: July 07, 2017, 06:28:01 PM by danedg »
'74 Eldo
'65 R60/2
'68 R60US
'54 R51/3
'78 Honda Hawk
'95 Mystic
« Reply #41 on: June 25, 2024, 07:57:54 PM »
my 72 had stripped threads as well
I didn't want to subject the heads to the stress of welding inserts so I converted them over to a flange arrangement.
Sorry, don't have a picture.
