Author Topic: V7 II - Downhill stalling issue - engine dies when clutch pulled  (Read 22602 times)
beetle
Re: V7 II - Downhill stalling issue - engine dies when clutch pulled
« Reply #60 on: July 09, 2017, 06:14:08 AM »
Disconnect the clutch switch and test again. No need to log.
Offline waxi
« Reply #61 on: July 09, 2017, 07:16:41 AM »
Can you send me the entire log?
Find it in the same post.
Moto Guzzi Nevada, 1998
Offline waxi
« Reply #62 on: July 09, 2017, 07:55:26 AM »
Nothing.
beetle
« Reply #63 on: July 09, 2017, 03:31:39 PM »
Offline waxi
« Reply #64 on: July 09, 2017, 03:39:12 PM »
What? Same? Stalled?
Yes, the same. I was also pressing the switch while driving downhill... Not a slightes difference. Stalled.
Can we lift idle again just for test? For another 150 RPM?
Offline RinkRat II
  • Lake Powell AZ
« Reply #65 on: July 09, 2017, 04:07:23 PM »
Hi waxi,
 Does your model have ABS? The reason I ask as it seems odd that the engine goes into a different mode when coming down on compression, All bikes I've ridden were always linear until you stopped or killed it.  :popcorn:
Regards, Paul B :boozing:
beetle
« Reply #66 on: July 09, 2017, 07:27:30 PM »
Yep. Link sent.
Offline waxi
« Reply #67 on: July 15, 2017, 04:57:38 PM »
After some crazy days I finally tested +200 idle RPM's map. It does make it a bit better! Problem is still there, but it didn't died so fast.
Another idea: If there is something loose regarding the butterfly... What would happen If I artificially lift TPS by holding the throttle twisted a bit when resetting TPS with GuzziDiag?
beetle
« Reply #68 on: July 15, 2017, 05:24:42 PM »
Don't do that, you don't have a calibrated hand.  :laugh:
Try it. Interesting things might happen.
Offline redhawk47
  • Traveler
« Reply #69 on: July 15, 2017, 07:46:47 PM »
Have you checked the fuel pump?
Several others, in addition to myself, had a similar problem with BMW F800GSs - stalling when off the throttle.
The solution was to replace the fuel pump. Cause was never found, to my knowledge. Perhaps low voltage when engine was at idle speed.
Dan
beetle
« Reply #70 on: July 15, 2017, 07:55:28 PM »
Surely then it would occur on level ground as well? Not just downhill?
beetle
« Reply #71 on: July 15, 2017, 09:40:32 PM »
I don't think it's a loose butterfly. An examination of an MIU unit makes me think it's unlikely. The butterfly is attached via screws which are punched to prevent movement. Even if one or both screws became loose, it would only move a tiny mount. Anything more than that would have an affect at cruise. The butterfly shaft does have slight lateral movement. The shaft has a screw and clip to hold the throttle cam, but if the screw was loose it only allows the cam to move sideways on the shaft.
