Author Topic: Leaning trike rip  (Read 7559 times)
Offline gearman
Leaning trike rip
« on: July 13, 2017, 04:01:07 PM »
Well I decided the rear leaning was not workable .Looks like reverse trikes are 3 times more stable based on my modeling. (this from the same guy who thought the leaning rear trike would work) lol.I started taking it apart today and now I need a good rear swingarm, the two lower frame rails and a good seat or pan.Five months of fun I guess but a disappointment.Mayb e the next try will be better.
free image hosting for websites
Re: Leaning trike rip
« Reply #1 on: July 13, 2017, 04:07:48 PM »
 Still a worthy project . Not a failure if you learned something .
Offline gearman
« Reply #2 on: July 13, 2017, 04:13:24 PM »
You are right. I did learn a lot.
« Reply #3 on: July 13, 2017, 04:21:06 PM »
"Failure is success in progress..." - Albert Einstein
Offline gearman
« Reply #4 on: July 13, 2017, 04:36:30 PM »
Some one on Ebay has California EVE frame lowers. Will they fit my convert?
« Reply #5 on: July 13, 2017, 05:13:39 PM »
« Reply #6 on: July 13, 2017, 05:16:12 PM »
I think "inspiration is 90% perspiration" is involved, too.. keep at it.
« Reply #7 on: July 13, 2017, 06:08:50 PM »
Agreed...for inspiration, check this out:  http://www.tiltingmotorworks.com/
Offline Idontwantapickle
« Reply #8 on: July 13, 2017, 06:23:29 PM »
The Tilting Motor conversion is pretty cool, I could actually be tempted by that in my old age.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #9 on: July 13, 2017, 06:57:33 PM »
Keep after it, you may come up with something that really works. If you give up now you'll have a bunch of specialized knowledge just laying around in your brain  :gotpics:
Offline RinkRat II
  • Lake Powell AZ
« Reply #10 on: July 13, 2017, 07:06:30 PM »
 You don't know what you don't know until you try it out. You've got the fabrication skills and desire. Keep on the path!
   Paul B :boozing:
« Reply #11 on: July 13, 2017, 09:06:53 PM »
I had a lot of core failures while I was building mine.  It took three years to sort out.  What is the basic flaw?  I'm guessing the rear axle length is too short for the length of the trike, and the weight distribution isn't right, but that's just at a glance.  Those things are fixable if you want to keep going at it.
Offline pat80flh
« Reply #12 on: July 14, 2017, 03:45:39 AM »
You are to be applauded for at least trying.
In the pile of parts I've amassed for my T-something project, I've ended up with 2 swingarms.
Since I have a couple of cast wheels, I'll be using a rear disc, and the swingarm with the brake stay(those of you more knowledgeable correct me if I'm wrong)
You can have the other cheap, or trade maybe?
00 Bassa
80 FLH (in rehab)
75 850T prject
Offline screamday
« Reply #13 on: July 14, 2017, 08:07:30 AM »
Very cool!
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
« Reply #14 on: July 14, 2017, 09:03:11 AM »
The stay is for drum brake.  The disk swingarm has a lug near the axle hole for the carrier plate.
What cast wheels?
« Reply #15 on: July 14, 2017, 09:26:34 AM »
It's a constant learning experience. This guy figured out how to turn a hi-powered mono wheel vehicle into a drag machine ...... with skids!
Skids, way out front!
Everyone will want one now.  :boozing:
« Last Edit: July 14, 2017, 09:27:22 AM by Penderic »
Offline gearman
« Reply #16 on: July 14, 2017, 09:37:37 AM »
According to RK you need to keep the one wo the stay.Are ther identical except for that? Will it work on my convert?
Offline gearman
« Reply #17 on: July 14, 2017, 09:43:14 AM »
RK, the big flaw was that I only had 100 pounds on the front wheel. Going down our bumpy roads it felt like I was only riding on the rear wheels. Scary. The rear engine idea just could not be fixed.She is all apart now waiting for the future.I might use the locking tilt mechanism for the parking brake.I was looking at my posted pictures and thought ,I could have a much crappier job with less work and still found out it was flawed. LOL
« Last Edit: July 14, 2017, 10:03:56 AM by gearman »
« Reply #18 on: July 14, 2017, 04:48:09 PM »
So why not flip the rear axle around and make it a mid-engine?
Offline Texas Turnip
« Reply #19 on: July 14, 2017, 04:51:59 PM »
After watching Rodekyll perform miracles on his trike, I bet he could make your rig work.
Tex
« Reply #20 on: July 14, 2017, 05:18:17 PM »
I'd go for the mid engine idea myself. The weight and balance on prototype number 1  :smiley: just didn't get it.
Offline pat80flh
« Reply #21 on: July 14, 2017, 05:22:04 PM »
I couldn't say for sure, they look identical except for the tab for the stay.  Those more knowledgeable?  I would think you could make any Tonti frame work. Not to hijack your thread, but Rodekyll, these are the wheels I plan on running, on a 75 850T project.
Let me know when you figure out what you want to do. Neither swingarm is going anywhere soon, when I figure out which one I'll need, you're welcome to the other one.
00 Bassa
80 FLH (in rehab)
75 850T prject
« Reply #22 on: July 14, 2017, 05:29:07 PM »
I think there is also a tiny (mm's) difference between the drive shaft side trailing arm.  That means there could be alignment problems with various final drives.
But the disk brake arm has no brake stay lug and the drum brake arm has no caliper holder lug.  So mods would be needed at that level at least if you start out with the wrong one.
Pat -- thanks for the pic.  I have a curiosity about who's doing what with cast wheels.
Offline gearman
« Reply #23 on: July 14, 2017, 07:04:45 PM »
I think I would have a hell of a reverse speed. I also would be sitting on to :grin:p of the engine.
« Reply #24 on: July 14, 2017, 07:15:57 PM »
Depends on how you flop it.
Offline Rick4003
« Reply #25 on: July 15, 2017, 04:58:49 AM »
It could be interesting if you could make something that retains the original position for the motor and come up with some transfer system to the rear axle . Still try the leaning idea but with better weight distribution.
The thing that worried me the most about the original prototype was the rear position of the engine and the fact that the mass of unsprung weight was far higher than the sprung part of the trike.
How about hydraulic drive to the rear axle? If you focus on having a good flow in the system you might not loose too much energy on the oil.
-Ulrik
Sent from my SM-A520F using Tapatalk
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline gearman
« Reply #26 on: July 15, 2017, 01:15:10 PM »
It would have to be upside down.Pinion would be on top. Right?
