Author Topic: Should I give in and sell the old girl? What would you do?  (Read 9381 times)
Offline Denis
Re: Should I give in and sell the old girl? What would you do?
« Reply #30 on: July 14, 2017, 09:39:13 AM »
You may be on to something here.  Maybe I should look into upgrading to disc brakes?  Probably not easy to find now days.
I'd keep it. I went through my Eldorado in the mid 1990s and since then I've run out of gas once, broke two front brake shoe springs and two clutch cables. (made it home both times). I'd say that's pretty damn good for 20-some years.
If you're iffy about the front brake send the wheel, brake, cable and lever to Vintage Brake in California. I sent them my 4LS on the Eldo and it was one of the best things I've done for that bike.
'87 SPII
'74 Eldorado
'85 LeMans
'91 California big valve
'61 Falcone Turismo,
'41 Indian 841
'40 Indian Model 640B ex-Canadian Army
'40 Indian Chief 340B
Offline Denis
« Reply #31 on: July 14, 2017, 09:46:51 AM »
If you can find one, the 4LS brake is very effective and the only other modification required is a lower leg with the brake retaining bracket.
Nick
It's a GREAT brake when properly set up. If it's not set up correctly it will try and kill you. These days the 4LS stuff isn't cheap. And he'll need to get the cables and associate lever parts unique to that setup.
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
« Reply #32 on: July 14, 2017, 10:16:37 AM »
KEEP IT!!!
I converted my 72 Eldorado to twin disc, FAC dampers and progressive springs, it rides and stops almost as good as 'modern' bike. Mark Ethridge found me single disc front end and I used new Brembo calipers , discs and master cylinder from MG Cycle.
The front fender welded supports are different from the drum model but you could easily modify a stock fender, the chrome fender front support was off a Cali (MG Cycle), all the hose fittings and brake hose were from MG Cycle.
I am really glad I mad the change, the stopping power really instills confidence especially riding at highway speed in traffic.
Offline 80CX100
« Reply #33 on: July 14, 2017, 10:19:42 AM »
Hey FD,     That is one gorgeous motorcycle, with the history and personal attachment to it, that you obviously have, I would never sell it.
     You've mentioned that the forks haven't been rebuilt, I think money and time into a front fork/disc brake conversion would be well spent, and pay dividends over the years. Definitely preserving an important part of your Father's legacy, that is clearly, near and dear to you.
     In regards to your Father's concerns,,, as we age and become more in tune with our mortality,,, there's probably a little voice in the back of his head, worried that if you got into an accident on his old bike, somehow he would bear/feel some responsibility. Reassure him, the joy the bike brings to you, AND your prudent actions to mitigate the risks of riding that bike,,,, and get the message to him "If I die on a ride on your bike, I die happy".
     I'd stress to your father how much the bike means to you, do the work required to make it brake more effectively on the front end,,, then ride the tires off it, lol.
     I agree with Roy, I'd give my left nut to be in your dilemna.
     Ride safe & take care
     Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #34 on: July 14, 2017, 10:27:00 AM »
I did exactly the same for my two BSA twin-leading-shoe front wheels with Vintage Brake.   You can chirp the front tire on a panic stop (following a car at a reasonable distance, glance to the side at the SAME INSTANT that the car slams on brakes, look back, you're almost in his trunk, grab the brakes, SAVED!) .... the brakes will still fade on a long downhill but you can control how fast you go down that, it's an older bike and you just compensate.
A round drum, modern-composition shoes arced to the drum, and you've got decent brakes.   Not disks, but good ....
« Last Edit: July 14, 2017, 01:28:11 PM by Lannis »
« Reply #35 on: July 14, 2017, 10:32:05 AM »
I know the feeling well. The Kid has the same afflictions as I do.. motorcycles and antique and homebuilt airplanes. I *know* those are his decisions.. but that little voice bothers me occasionally. <shrug>
« Reply #36 on: July 14, 2017, 10:49:10 AM »
I'm not a loop frame guy, but your dad's bike could make me a convert (sorry for the play on words.)
Bob
« Reply #37 on: July 14, 2017, 11:56:45 AM »
Keep it, I wish I still had one. The first one I bought from my Dad, I put about 168 K miles on it. during that time I bought another from the father of a pilot in my squadron so I could always have one running if one needed maintenance. I didn't have a car the four years that I was stationed at Beale AFB in California. I had to live in the barracks until I became a sergeant which I didn't like so when I was off duty I rode. and rode . Yep keep it- snapping suspenders
« Reply #38 on: July 14, 2017, 01:18:17 PM »
Just my 2 cents worth: before going "whole hog" for a disc front end, I'd try relined shoes properly arced to the drum, with a good quality cable and linkage adjusted correctly. For the forks themselves, Wirth progressive springs and 8 oz. of 30w fork oil in each leg. See how that works, then decide if you want to go disk.
In my experience, the Guzzi disc forks will never give the ride quality of the drum forks - there's just too much "stiction" - single seals, FAC dampers and progressive springs won't change that. The drum forks are far more compliant.
It's very possible to build a disc front-end from T/T3/Convert, etc. parts and have it look "original". The drum-brake fork shrouds and fork tubes can be retained, Tonti parts needed are fork lowers/sliders, damper/spring assemblies, wheel with disc(s), caliper(s) and master cylinder. You'll need to modify the drum fender and find suitable braces or a Cal II fender will fit with minor modification. You'll need a disc Eldo axle (Harper's has them n-o-s). To get the brake disc(s) spaced out where it(they) need to be, you'll either need to find a(2) 39 mm wide bearing carrier(s) or machined aluminum spacer(s).
Offline bigbikerrick
« Reply #39 on: July 14, 2017, 01:50:57 PM »
 Dan, my friend,You will eventually  kick yourself in the ass if you ever sell that  gorgeous eldo.....besides, those "Rocket" mufflers on it look badass, and no one else has them!   HaHaHa :thumb:
Rick
« Reply #40 on: July 14, 2017, 02:14:30 PM »
Can't you keep it AND get a smaller, cheaper daily rider?
 :1:
Offline danedg
« Reply #41 on: July 14, 2017, 07:19:31 PM »
Never sell that bike. It would be like selling the old man.
Disc brakes require disc forks.
20 years from now it will still be your "go to" bike.
I still have my old mans' A5 with a prehistoric s/n...
I'll never sell that either....
« Last Edit: July 14, 2017, 08:16:06 PM by danedg »
'74 Eldo
'65 R60/2
'68 R60US
'54 R51/3
'78 Honda Hawk
'95 Mystic
Offline jrt
« Reply #42 on: July 14, 2017, 07:56:36 PM »
I didn't see this question, so I'll ask- you said it broke down 2-3 times?  What broke down?  Can you address that point before going off in a tangent?
I had an Eldo that started 'breaking down' on a very predictable basis- turned out to be a plugged gas cap.
With regards to Charlie's statement on drum/disk forks- I have fully rebuilt disc forks with FAC dampers.  It is a much stiffer ride than the old drum front end.  Personally, I like that- the rear shocks are stiffer as well, but that's my personal preference.  Others will (and do) see it differently.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Farmer Dan
« Reply #43 on: July 15, 2017, 12:32:44 AM »
First break down turned out the generator was polarized backwards.  I was 4 hours from home, once I found the problem the local harley davidson shop was so happy to see the bike he polarized the generator and put in a new regulator for free.  Second time the points failed.  Yea that little metal thing on the end of the arm feel off.  They don't run good like that, I was two blocks from home.  Third time was this exhaust nut thread.  I have never heard of that problem before so I will lay the blame for that on me.  I got the head back today and will be using stainless steel nuts with the lock nut on them.  And check them once in a while so we don't do that again.  I was 80 miles from home when the exhaust header blew off.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
Offline Farmer Dan
« Reply #44 on: July 15, 2017, 12:37:46 AM »
Actually I kind of like the way she handles, I just don't like all that oil leaking all over the front of my bike.  I need to find someone near by that put in new seals for me.  I can get the drum turned and install new shoes and better cable.  I know if I take my time and adjust the brakes properly they do seem to work better.  For a while any way LOL.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #45 on: July 15, 2017, 08:22:18 AM »
I wouldn't turn the drum unless it's out of round.
Offline jrt
« Reply #46 on: July 15, 2017, 08:54:54 AM »
The forks are really easy to rebuild.  If you have any mechanical aptitude, you should do them yourself.
The only specialized tool you need is a fork tube puller and you can either buy one or make one (I used a threaded rod with a plumber's emergency expandable plug on the end).  Greg Bender's site has a walk-through, I am sure.
L-720
1973 Eldorado
2020 R1250RS
« Reply #47 on: July 15, 2017, 11:35:20 AM »
It's best to have the proper tool to remove the chrome seal holders as well.
http://www.thisoldtractor.com/moto_guzzi_loopframe_fork_rebuilding.html
Offline Farmer Dan
« Reply #48 on: July 15, 2017, 03:40:37 PM »
The way my health has been and not having the right tools I need to find someone local that can do the fork seals.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #49 on: July 15, 2017, 03:48:21 PM »
 just leave it here for a couple years........ :cool:
