Author Topic: What Motor Oil ?  (Read 22557 times)
Bonaventure
What Motor Oil ?
« on: July 19, 2017, 03:04:17 PM »
I don't have a Guzzi yet.  My Ducatis were unit/shared sump w/ wet clutch.  Used the recommended viscosity of 15W50 in full synthetic and JASO MA compliant.
What does the manual for the Guzzi 8 valve 1200's recommend?  And also, what is popular with you guys?  I'm seeing that the Guzzi's are dry clutch with gear box oil separate, so then is there no issue with using an oil containing friction modifiers (which you can't with wet clutches)?
I have two new sealed 4 liter jugs of JASO MA2 compliant 15W50 full synthetic in the garage left over from the Ducati-- Spectro Platinum 4 and Silkolene Pro 4.  Guessing neither is suitable for the Guzzi 1200 engine . . .
Offline yogidozer
Re: What Motor Oil ?
« Reply #1 on: July 19, 2017, 03:15:52 PM »
You will find this interesting, they recommend 10-60.
http://www.guzzitek.org/gb/ma_us_uk/1200/Griso1200_8V_072008_Atel(GB).pdf
I use 15-50 fs in my EV and 1100 sport. Someone with a Griso will give you an answer....or 17 answers....as far as brands  :wink:
« Last Edit: July 19, 2017, 03:30:46 PM by yogidozer »
Offline Zoom Zoom
« Reply #2 on: July 19, 2017, 03:22:57 PM »
10W-60
ZZ
Offline Idontwantapickle
« Reply #3 on: July 19, 2017, 03:34:49 PM »
Stick to the recommended type and weight and all will be fine. Don't put dino squeezin's in the 8 valve engine, use synthetic.
I order the AGIP direct from Eni but many people use Red Line or any number of other popular motorcycle oils. As long as it meets the spec all is well.
Don't fret over it too much.
Hunter
 :popcorn:
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Dilliw
« Reply #4 on: July 19, 2017, 03:44:22 PM »
What's popular?  Now that's a question  :boozing:
I use this one:
https://www.amazon.com/gp/product/B00CPL918E/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
YMMV
George Westbury
Austin, TX
« Reply #5 on: July 19, 2017, 04:01:27 PM »
Do NOT use a friction modified oil. You will glaze the bores and have oil consumption problems.
Offline bigbikerrick
« Reply #6 on: July 19, 2017, 04:09:37 PM »
I like the mobil 1 15 W 50 , its available at wal mart, and does not have friction modifiers. as a second I like the shell rotella blue jug synthetic,I use shell rotella dino oil in my eldo ( changed every 1500 miles)because its cheap, good, and readily available.
Rick.
Offline yogidozer
« Reply #7 on: July 19, 2017, 04:16:31 PM »
Rick.
Yeah, I use that, Mobil 1, for my EV and Sport 1100, but the 8 valve Griso needs the 10-60
Offline Demar
« Reply #8 on: July 19, 2017, 04:52:07 PM »
I use Motul 7100 4T 10w60. Available from Amazon and Revzilla.
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
Offline drums4money
« Reply #9 on: July 19, 2017, 04:52:39 PM »
Hunter
 :popcorn:
yep. . .10/60 for my 1200 as spec'd in the service manual.  Agip a case at a time direct from Eni.
Old School Audio:
Offline bad Chad
« Reply #10 on: July 19, 2017, 04:56:32 PM »
Corn oil for your rear end.
1988 YX600 Radian
Bonaventure
« Reply #11 on: July 19, 2017, 04:57:09 PM »
Does Guzzi let you download the owner manuals?
« Last Edit: July 19, 2017, 04:58:20 PM by Bonaventure »
Offline ITSec
« Reply #12 on: July 19, 2017, 05:47:45 PM »
There are scanned copies widely available for almost all models, though Piaggio itself doesn't provide downloadable copies last I checked.
All CARC bikes are specified as needing 10w60 synthetic oil. While some people use other viscosities, some people who do so also report odd things like getting spurious oil pressure warnings or similar annoyances. As to specific brands, there are many, many threads - some of them not even nasty - about people's preferences. Oil selection approaches religious fervor with some people. I am more pragmatic - I just know what I have used and how well it has worked, how easy (or not) it was to obtain, and how much it cost.
Buying by the case is always a good way to do things. Agip/ENI is often available this way, as are ELF/Total and some other brands. I used to use ELF/Total with good success, but my source for case lots dried up and the price got silly.
I base my thoughts on over 125,000 miles and growing  on my Norge (always 10w60 synthetic, brands varied, usually double ester), on over 137,000 miles on my previous V-Strom DL-1000 (that one liked Rotella synthetic 5w40), etc.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Online Tom
« Reply #13 on: July 19, 2017, 06:00:24 PM »
Read the ABC letter code for the recommended AGIP oil for the bike and see if it's compatible with the oil for you Ducati.  Best way.
Offline yogidozer
« Reply #14 on: July 19, 2017, 06:52:22 PM »
I sent this link above ^ Should tell you everything
Offline 750S3
« Reply #15 on: July 21, 2017, 12:24:02 PM »
Hunter
 :popcorn:
Hi Pickle, where and how do you order the Agip oil directly from ENI? I've been looking for a source other that a MG dealer.
Puch125
Honda250
Kawasaki750
Ducati 900GTS
Moto Guzzi 750S3
Moto Guzzi Griso 8VSE Tenni
Offline Demar
« Reply #16 on: July 21, 2017, 12:49:57 PM »
http://www.af1racing.com/store/Scripts/prodView.asp?idProduct=7320
2012 MG Stelvio NTX
1953 Galletto 175
Offline 750S3
« Reply #17 on: July 21, 2017, 03:11:54 PM »
Yes I knew that, I thought pickle mentioned he was ordering directly from ENI.
Puch125
Honda250
Kawasaki750
Ducati 900GTS
Moto Guzzi 750S3
Offline Ncdan
« Reply #18 on: July 21, 2017, 04:11:20 PM »
Is the 8 valve  motor what's in my 07 Calvin?
« Reply #19 on: July 21, 2017, 05:40:23 PM »
I got a nice letter some while back from ENI saying in as complicated a way as possible that they were no longer selling direct. It went along with the rebranding of AGIP to ENI.
I looked again after posting the other day and the links I used in the past are broken.
Bummer.
72 Eldo
84 BMW R100RS
Offline ITSec
« Reply #20 on: July 21, 2017, 07:25:26 PM »
I'm pretty sure the 07 had a 2v (per cylinder) engine.
ITSecurity
« Reply #21 on: July 21, 2017, 07:50:01 PM »
No. The 8V motor was never used in any Tonti, (Thank god!)
« Last Edit: July 21, 2017, 07:52:39 PM by pete roper »
Offline Beowulf
« Reply #22 on: October 23, 2017, 07:55:52 PM »
 This is rather late but i believe eni north america sells directly to the public on their site. It says nothing about just selling to commercial interests only. Just click the online lubricants store top of the page. Motorcarr is another source both sell by the case. Hope this helps.
Offline ITSec
« Reply #23 on: October 23, 2017, 08:11:02 PM »
A quote from the ENI website: "In North America Eni markets directly lubricants and special products."
The link at ENI North America is https://buyenilubes.com/index.php/shop/motorcycle-engine-oils/eni-i-ride-78.html - currently a case of 12 costs $120, which is fairly reasonable if not actually cheap. At that price I might but there, though it's always nice to be able to buy the LiquiMoly at the local NAPA store.
« Last Edit: October 23, 2017, 08:13:24 PM by ITSec »
ITSecurity
« Reply #24 on: October 23, 2017, 08:16:10 PM »
only use extra virgin olive oil.
never domestic.
« Reply #25 on: October 23, 2017, 08:32:48 PM »
AAARRRGGG an oil thread!  save us please!
« Reply #26 on: October 23, 2017, 10:38:57 PM »
Whoo Hoo, a revived oil thread!!!! :evil:
Sorry, couldn't help it.
tom
PS: oil threads can be of help to not just newbie's, but old riders as well! Sometimes a new version of oil can be a good thing to find out about!
Offline ITSec
« Reply #27 on: October 23, 2017, 11:25:54 PM »
tom
Or sometimes new sources for oil - there's always a chance of a retailer you didn't know before...
ITSecurity
Bonaventure
« Reply #28 on: October 24, 2017, 08:32:00 AM »
My pre-Guzzi oil thread resurrected, LoL.
I ended up buying 4 liters of ENI i-Ride PG 10W60 for $51 shipped off eBay from Staccato Motor Sports.  Also went with the default recommended gear oils from ENI. So that's a good price $120/case, if the shipping is free then even better.
Put all three oils in last Wednesday.
At the risk of perpetuating the thread, there are two ENI i-Ride 10W60's, there is the light blue label "PG" and the black label "MotoGP."  Be interesting to know the subtle differences between the two.  On ENI's product data sheet (PDS) for each the 100C viscosity and other numbers are  identical, if memory serves.
Offline Beowulf
« Reply #29 on: October 28, 2017, 02:34:25 AM »
 :coffee i called eni a few months back to ask about the differences between the gp and the pg oil. The gentleman on the phone looked it up for me and told me there was no difference except the labeling. If you look at the data sheet there is no difference in performance numbers. I have been happy running the 10w60 gp. Bike hasnt exploded and the wear indicators on the plug have improved. I will send for uoa soon hopefully. Af1 also sells the gp in their oil change kit for the guzzi.
