Author Topic: 2012 Norge fork oil change  (Read 3706 times)
Offline toolittletime
    • mysportgear.com
« on: July 26, 2017, 04:18:20 PM »
Is it necessary to remove the forks ....to do a fork oil change?  Or is it possible to pump or siphon it out?   Also what weight oil?
Thanks.....Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
    • mysportgear.com
Re: 2012 Norge fork oil change
« Reply #1 on: July 26, 2017, 05:09:00 PM »
Anyone????
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #2 on: July 26, 2017, 05:11:46 PM »
On my '07, the forks are always removed, upended and refilled.  I don't know what the 2012 calls for in the way of fork oil, but mine as different springs and cartridge emulators and uses 15w.
YMMV.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
Offline lti_57
  • Directly above the center of the Earth
« Reply #3 on: July 26, 2017, 05:19:10 PM »
Maybe its just me
But pulling the forks and cleaning every thing checking things out.
For me its just good quality time spent with my scoot
I always  drain my forks by hanging them upside down
Usually i pull the guts and clean and replace if need be
2007 Guzzi Griso
1992 BMW K75
Offline ITSec
« Reply #4 on: July 26, 2017, 05:47:05 PM »
Thanks.....Tim
There are people who pump out the old oil - it never gets as much out as actually removing and inverting them to drain. Weight selection is a matter of preference, and may also change if you use a non-stock spring such as HyperPro or Wilbers.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
    • mysportgear.com
« Reply #5 on: July 26, 2017, 10:11:38 PM »
Thanks for the replies!!!
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
« Reply #6 on: July 27, 2017, 12:56:03 AM »
Yep, what they all said,firstly loosen the fork caps after loosening the top pinch bolts. GENTLY tap a wedge lightly in the lower clamp to expand it a COUPLE of thou' after first loosening the lower pinch bolts.  Remove the cap and compress the forks placing the bits on the bench as they appear. Then ass up with the forks and drain the cat's piss out that they added in Mandello. I use Bel Ray 15W, I think it is .. Every 20,000 k. Hand tighten the cap and re install the forks,nip up the lower pinch bolts, and tighten the caps gently BEFORE YOU NIP UP THE TOP PINCH BOLTS !
Offline yogidozer
« Reply #7 on: July 27, 2017, 06:13:32 AM »
I don't have that model, but I'd look into drilling a drain screw in each leg after disassembling the first time.
« Reply #8 on: July 28, 2017, 12:52:24 AM »
 :bike-037:
Crossed my mind more than once !
    • mysportgear.com
« Reply #9 on: July 28, 2017, 04:51:40 PM »
Not such a bad job...about 2 hours actual work time...let them drain during lunch. Good tip Huzo on using a wedge on the pinch bolts...it is quite a tight fit, if you don't do that. The stuff that came out didn't look too bad, considering it is the factory oil with about 14,000 miles on it.
  It called for about 18 oz. in each one, and that matched up with the service manual measurements of 110 mm down from the top, with the sleeve and spring removed, and the fork compressed.. Refilled with 10w this time to give it a try.......if not I can replace it with a little heavier.
Good news is the shop was in the 70's  all day.  I opened the doors this morning and placed a fan to circulate some of the cool Canadian air in ...50 degrees this morning....closed the doors.........and it stayed nice for working all day................ now the customary 300 mile test ride!!!
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
« Reply #10 on: July 28, 2017, 05:25:24 PM »
See mate. It's a bonding thing as I see it. Turn on your favourite music (Bob Seger), crack a can (VB), get your favourite mate around to talk some bull****, and just do it. It's amazing how many potential dramas you see when you get into it. BTW, I've never enjoyed my maintenance so much as I have since I bought my scissor lift work stand. They're the Duck's Guts...
    • mysportgear.com
« Reply #11 on: July 28, 2017, 07:42:59 PM »
Oh yea...couldn't do it without the lift.  And the work is always a little easier when I don my Moto Guzzi workwear.
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
« Reply #12 on: July 29, 2017, 04:18:15 AM »
Damn right TLT !
