Author Topic: Speedometer options for V7 Racer v1  (Read 879 times)
Offline jcb72
« on: July 27, 2017, 08:32:37 PM »
Hi
I'm looking at doing some mods for the coming summer (Australia), I want to clean up the front of the bike by removing the front fairing, so the cluster has to go as I think its messy, I was looking at an integrated Light& speedo but was also looking at a cleaner cluster which would still achieve a similar look.
Does anyone know if the Guzzi Audace speedo would fit the V7 racer or are there other alternatives that anyone has tried?
Cheers
Re: Speedometer options for V7 Racer v1
« Reply #1 on: July 27, 2017, 08:49:52 PM »
Not only are functions like the indicators controlled by the dash but the pin-out, canbus functions and parameters used in the Cali 14 unit are all going to be wildly different. A non-started for certain. There may be some sort of aftermarket dash that would work but it will involve a lot of work and you'll need a sub loom for the indicators at least.
A huge PITA I'd think. Life's too short.
Offline jcb72
« Reply #2 on: July 27, 2017, 09:08:59 PM »
Damn! thanks for the advice, BAK make an integrated light Speedo but not sure if its plug n play, and it's also expensive, I'll probably get a new Saddle from them as the price is fair but everything else is over priced.
cheers
