Author Topic: Buying a new Guzzi  (Read 13222 times)
Offline Kent in Upstate NY
Re: Buying a new Guzzi
« Reply #30 on: August 15, 2017, 09:58:20 PM »
I'm pretty sure they could cobble another one up if you asked.
Offline ITSec
« Reply #31 on: August 15, 2017, 10:14:17 PM »
I'm sure they could - but probably not at the price of one they'd done on spec!  :grin:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Calculon
Re: Buying a new Guzzi - Updated
« Reply #32 on: August 16, 2017, 04:29:34 AM »
this will be in my garage in a few weeks.
Very nice!  Congrats.
2015 Honda Forza 300 ABS
« Reply #33 on: August 16, 2017, 05:43:35 PM »
It's official. BTW, I asked Dave Richardson at Moto International if he had other packages like I just got and he said yes. He either has one or can put one together. Call him at 206-297-3822.
« Reply #34 on: August 16, 2017, 05:47:27 PM »
 :thumb:  Kent
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #35 on: August 16, 2017, 05:57:26 PM »
I'm curious to know the difference in weight between the spoke wheels with off road tires, and the cast ones with road tires.  Any change of weighing them when you do your first swapover?
« Reply #36 on: August 16, 2017, 09:20:03 PM »
I could probably get the weights of one set of wheels when I get them. As to weighing them when I change them, you might have to remind me.
Offline bacongrease
« Reply #37 on: August 17, 2017, 10:13:18 AM »
  Hummmm...I didn't know any of you guys bought new ? ?    :huh:   :boozing:
« Reply #38 on: August 17, 2017, 10:59:25 AM »
We just wait until the dealer has a bunch of leftovers and discounts the heck out of them.  :wink:
Offline ITSec
« Reply #39 on: August 17, 2017, 12:24:12 PM »
I bought my Norge new - by doing exactly what Kent said!  :wink:
ITSecurity
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #40 on: August 17, 2017, 01:09:41 PM »
Congrats!  She certainly is a looker.   :thumb:
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
« Reply #41 on: September 06, 2017, 09:58:02 AM »
Just got word from MI that my new Stelvio is on its way! Here is some info he sent me regarding the codes and stuff.
Here are a couple of things about your bike’s instrument panel that we’d like you to know that aren’t covered well in the manual.
Service codes
A code is needed to access the section of the menu called Diagnostics. Here (depending on model) you can reset the instrument panel after a service, store a key code, introduce new keys, set some display defaults, or perform diagnosis possible from the instrument panel.
Models
Grisos
1200 Sport,
early Breva 1100
Norge, late Breva 1100
Stelvio
Shiver
Mana
Tuono
V-twin
Dorso-duro
V4s
SR50
Code
12425
36421
28315
10695
12398
12321
13432
98789
12412
45256
Introducing new chipped keys to your bike
Your bike has to recognize each key as acceptable, done through the dashboard menu. Depending on the model, you may need the service code and you’ll for sure be prompted for a key code in the key replacement section. There is no special key code (default is 00000) unless you designate one in the “Change the code” section. We strongly advise against it, as someday you might sell your bike and forget to pass on your key code. For this reason, we suggest that all key codes remain all zeroes. Follow the prompted instructions. If you screw up, turn the key switch off, wait a few seconds, and start all over again.
Error message
When you first turn on the key, you'll see a message saying "Remember to insert your user code." Best to ignore this and it will disappear in 5 seconds. You can put in a unique code, but if you sell the bike someday and forget to tell the new owner, he’ll never be able to add a replacement key.
Moving the mode button left or right scrolls the bottom of the display through various things: odometer, trip meter, time run, top speed, average speed, and gas miles. Moving it 3 seconds to the right takes you from screen 1 to screen 2, so you can keep track of two sets of information, like a tank of gas vs. a whole trip. Pressing the button in for 3 seconds erases all this information for just the screen you're on (1 or 2), leaving the other still recorded and of course this doesn't erase total miles. Moving it 3 seconds to the right beyond screen 2 takes you to other things: battery voltage, chronometer, instantaneous gas mileage, traction control, and menu. Push the button in on menu to go into the menu. Scroll through the choices a second at a time and go into your choice by holding it in, again for 3 seconds.
Hot grips are controlled by a little button on the front of the left switch module at the bottom. Again, holding 3 seconds toggles between on and off and 1 second gets you from low to medium, medium to high, and high to low.
« Reply #42 on: September 06, 2017, 05:27:04 PM »
Can't tell you how many times I erased my data thinking it was the turn signal switch!
Offline ITSec
« Reply #43 on: September 06, 2017, 05:53:40 PM »
For those who had trouble reading Ken's post on dash service access codes, here it is again in legible form:
Grisos -         12425
1200 Sport, early Breva 1100 -   36421
Norge, late Breva 1100 -   28315
Stelvio -         10695
Shiver -         12398
Mana -         12321
Tuono V-twin -      13432
Dorsoduro -      98789
V4s -         12412
SR50 -         45256
At least, I think that's what it started out as before web formatting blasted it to pieces.
ITSecurity
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #44 on: September 08, 2017, 09:07:12 AM »
There is no special key code (default is 00000) unless you designate one in the �Change the code� section. We strongly advise against it, as someday you might sell your bike and forget to pass on your key code. For this reason, we suggest that all key codes remain all zeroes. Follow the prompted instructions. If you screw up, turn the key switch off, wait a few seconds, and start all over again.
No user code gives absolutely no security.  I would suggest extract a code from the VIN number or use the diagnostics code as the user code too.  That's if you cannot remember personal numbers.
« Reply #45 on: September 09, 2017, 08:25:49 PM »
For the code I just use the first five numerals of my birthdate. Hard to forget.
Offline Guzzi Gal
« Reply #46 on: September 20, 2017, 06:24:50 PM »
Has your bike arrived yet?
"Miri" and Mori"
« Reply #47 on: September 20, 2017, 09:56:51 PM »
Last update it was in York PA. Any day now.
Offline Guzzi Gal
« Reply #48 on: September 20, 2017, 10:41:19 PM »
I hope it's soone,r than later.  I received my delivery window today.  I could have mine as early as Friday.  One can wish, right?
"Miri" and Mori"
« Reply #49 on: September 22, 2017, 11:47:15 AM »
I just got notice that mine will be here next Tuesday, Wednesday, or Thursday. :grin:
