Author Topic: T3 melting brake line weirdness  (Read 1655 times)
Offline Unk Tantor
« on: July 28, 2017, 12:02:49 PM »
Hello.
I recently replaced tabrake hose of my linked side T3 brakes,. They had previously been swapped for Goodridge 'buildaline" type stainless stell hoses. A leak appeared to have sprung on the line from the rear master cylinder to the spliter on the other side. I purchased a new sytle buildaline, these days they come with a clear plastic coating over the stainless hose, as indeed does my front line , which I replaced a few years earlier.Anyhoo, look ing at the bike today I noticed that the plastic had melted off in the middle. Thats weris thought I. I started the bike and ticked it over with the headlights on, the hose started to get hot!?! After a few minuetes almost too hot to hold comfortably. There is no wire touching the hose anywhere.
Recent alterations have been a LED mainheadlight ( which I've now swapped back to filliment in case that was somehow causing it and a replacement horn and a oFibre glass mat battery (Odyssey) battery.
Any thoughts ? Cheers
Offline pehayes
Re: T3 melting brake line weirdness
« Reply #1 on: July 28, 2017, 12:15:25 PM »
The front forks are electrically isolated from the frame because of the pivot bearings and grease.  Thus, the wire plan usually includes some sort of grounding bypass wire to ensure that anything up front grounds to the main frame.  Is it possible this has been compromised and you are trying to ground through the brake line stainless?  Just an idea.
« Reply #2 on: July 28, 2017, 01:35:47 PM »
It's a classic, pehayes, , and you're right, imo.  Before the juice had the brake line route-to-ground it was probably travelling along the speedo and tach cables.  That's a common reason to break the twirley parts and melt the plastic stuff in the instruments.  Sometimes it travels down the clutch or throttle cables.  None are good events, and all are avoidable if you install a 10ga ground wire from the top tree to the frame.
Unk, I'd carry some spares for the cables mentioned.  If they've been weakened, they are going to break.  Also, after you get the ground installed, you might want to change out the brake fluid.  It probably got quite hot, too.
Offline JoeW
    • The Guzzi Doctor
« Reply #3 on: July 28, 2017, 03:05:41 PM »
I think Mr Hayes is on to something, run a ground wire from the headlight bucket to the frame, there should have been one there from the factory. It plugs into the male spade tab that's riveted to the bottom of the bucket.
Joe Walano
Offline Unk Tantor
« Reply #4 on: July 28, 2017, 03:37:50 PM »
Thanks for the advice, I'll check the earth from the headlight to frame.
Offline Unk Tantor
« Reply #5 on: July 29, 2017, 08:32:31 AM »
 turns out it was the earth from the rectifier which was  supposedly earthed to the rear master brake cylinder :tongue:
it was not getting to the frame and the thin stainless hose material was getting too hot with the current.
