Author Topic: 97 1100i whatsit  (Read 2770 times)
Offline Motomoto
97 1100i whatsit
« on: July 30, 2017, 06:35:13 PM »
What's the purpose of this connector? Should it be plugged into something?  Comes out of fitting on left side under tank in front of petcock bung. Thx.
upload the pictures
Re: 97 1100i whatsit
« Reply #1 on: July 30, 2017, 06:39:44 PM »
 UH OH , you haven't touched it have you ? Doing so will void the warranty and cause the rotation of the Earth around the Sun to reverse  :shocked:
Offline marcmorrison
« Reply #2 on: July 30, 2017, 06:52:57 PM »
To answer part of your question...YES, it does connect with something (as seen on my 75th ANN. MG Cali 1100), however, I would either have to take off the gas tank to identify the function or attempt to decipher a wiring diagram.
1999 MG Bassa (pearl white)
« Reply #3 on: July 30, 2017, 07:06:47 PM »
Breaking News...went back and took another look.  It is connected to the low fuel sensor (located on the bottom of the gas tank on the left side).  Perhaps the sensor went bad and was disconnected to avoid that pesky low fuel warning light???
Offline twhitaker
« Reply #4 on: July 30, 2017, 07:09:01 PM »
Looks like the fuel sender connector. Mine doesn't work either.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline guzzista
« Reply #5 on: July 30, 2017, 07:13:29 PM »
It is the low level fuel sensor. They usually turn on somewhere between 100/120 miles from full tank in combined riding and a bit more 130/140 in steady cruising mode ( higher MPG).
« Last Edit: July 30, 2017, 07:14:09 PM by guzzista »
« Reply #6 on: July 31, 2017, 11:31:58 AM »
Flux Capacitor link?
Oscillation Overthruster.....
Todd.
« Last Edit: July 31, 2017, 11:32:37 AM by cruzziguzzi »
Offline TOMB
« Reply #7 on: July 31, 2017, 03:11:06 PM »
Don't worry about it . Your blatter will give out before you drain the whole tank, I have the same problem on my Convert 6gal tank and a 60-100 mile blatter
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #8 on: July 31, 2017, 03:18:13 PM »
I have a disconnected one my Strada.  Low fuel sensor was removed.  Haven't checked but IIRC probably have one on my Cali III too.
« Last Edit: July 31, 2017, 03:18:34 PM by Tom »
