Author Topic: Centre stand options V7II  (Read 5304 times)
Offline MotoBug
« on: July 30, 2017, 10:26:33 PM »
Just wondering what people are using for a centre stand. Is it attached to the bike or a separate item? Diy'ed or shop bought? I suppose I'll be needing something for when I want to drop the oil or spin the back wheel for valve adjustments.
Offline voncrump
Re: Centre stand options V7II
« Reply #1 on: July 31, 2017, 01:44:54 AM »
I have fitted a centre stand from LGC (Stucchi Luigi) to my V711. Very well made but I had to make a small adjustment for gear linkage clearance. If you own a Stone make sure you buy the grab handles as well.
I think Hepco & Becker make one as well.
Cheers, voncrump.
1996 1100 sport
2016 V711
1988  Lario ( long gone )
1982 V50111 (long gone)
Offline MotoBug
« Reply #2 on: July 31, 2017, 02:08:56 AM »
LGC designs appear to be good. I like the look of their crash bars. Unfortunately for the price of their centre stand I could buy a hydraulic scissor lift. I think I'll be looking into a paddock stand or the one in link unless a better option presents itself.
https://www.rpchardware.com.au/index.php?route=product/product&product_id=358&language=en&currency=AUD&gclid=Cj0KCQjwh_bLBRDeARIsAH4ZYEO6PxhLw37icbHXcd8AlND3EHCaDl_o8nnyAR3FXbpVwfb3OOxrqfYaAvT7EALw_wcB
Offline tris
1993 TW125 "POS" - Resting
Offline stokes
« Reply #4 on: July 31, 2017, 06:41:16 AM »
I got this one,http://www.mgcycle.com/index.php?main_page=product_info&cPath=73&products_id=4932 MG didnt have it in stock so I ordered directly from Stein-Dinse.
Offline SportsterDoc
« Reply #5 on: July 31, 2017, 07:19:40 AM »
To allow the rear wheel to rotate for cleaning, I simply use a scissor jack on the side of the frame opposite the side stand.   If I were to use it to remove the wheel, I'd add a tie-down strap to the right side of the handlebar and hook it to a heavy duty eye hook in the garage ceiling...not for load, but for stability.
Been thinking about making a stand to go into the open frame tubes, facing rear, with some width stability.
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
Offline malik
« Reply #6 on: July 31, 2017, 02:32:10 PM »
 FWIW, Johnannes really prefers the H&B centrestand he put on his V7II, to the OEM one he had on his V7C. Sourced from & mounted by Motociclo.
Offline redhawk47
  • Traveler
« Reply #7 on: August 01, 2017, 01:34:02 AM »
I have the Hepco-Becker center stand on my V7II. No interference with the side stand. A bit on the long side; I usually have to roll the rear wheel up on a 2x4 to get it up on the stand.
A recommendation when using any center stand. If you are removing the rear wheel tie a strap between the center stand and the front wheel to prevent the stand from folding up while you are working on the bike.
Dan
Offline MotoBug
« Reply #8 on: August 02, 2017, 03:37:08 AM »
Thanks all for the replies. Always good to know what's out there for different situations. I'm still considering options but definitely liking the idea of a mounted one like bikes used to have. The stand stokes mentioned looks like a good option as well.
When did this trend of omitting side stands come in? Smells like bean counter thinking to me.
Offline malik
« Reply #9 on: August 02, 2017, 08:48:58 PM »
? A hold over from sports bikes? A badly designed centre stand can be the first thing that scrapes on tighter corners. So they binned it & sent owners back to shops for any little thing.
« Reply #10 on: August 02, 2017, 09:01:58 PM »
Offline MotoBug
« Reply #11 on: August 02, 2017, 09:03:01 PM »
On a sports bike I can maybe understand but on a bike like the V7 it's plain silly. I had a look at Motociclo website but couldn't see the stand you mentioned.
Offline malik
« Reply #12 on: August 03, 2017, 02:38:35 AM »
It's by Hepco & Becker. Give Johnny or Nicole a ring. They may have got it in for Johannes especially, I do remember it took a long time to turn up. And their website is not always up to date - there's only the 3 of them there, and they haven't put the girls to work yet.
Offline MotoBug
« Reply #13 on: August 03, 2017, 03:07:59 AM »
Just looked at the Aussie distributor price and the HB stand is $360! Tight? Yes it does squeak occasionally but sometimes for good reason. I'm convinced the V7 is an excellent bike but I'm also lured by the charms of a Griso hence my hesitation to spend on the V7 atm.
Offline wyno
« Reply #14 on: August 03, 2017, 06:34:20 PM »
Motobug, if you want to try out the charms of a Griso, and if you're in Melbourne, I could come up from Geelong and let you try mine. I went from a 750 Breva to the Griso and it was made for me. However, if you want to stay with the V7, a centrestand is the way to go. I got a factory one fitted when I bought the Breva and it just makes things so much easier. Motorcycle Adventure Products sell the Hepco and Becker stands and they are very good to deal with.
Wyno
Offline MotoBug
« Reply #15 on: August 03, 2017, 08:16:15 PM »
Hey thanks for the generous offer wyno. I'm in Gippsland but I'll keep it in mind. I'll check out the options at MAP. The thought of a Griso is only a tickle atm but if a used one came up at the right price I'd consider it.
Anyway it's good to know there are a few stand options out there. I have no idea how I'd change a flat in the wild without a centre stand.
Offline malik
« Reply #16 on: August 04, 2017, 01:22:31 AM »
Check out IB Mini bike lift - it's what I take along for the 1100 Sport & the V11. A Guzzusta now operates IB Bike Lifts, so it's sort of like keeping the money in the family.
Offline TimmyTheHog
« Reply #17 on: August 04, 2017, 02:02:20 PM »
holy dayammmmn....this is handy!
how come no one has ever suggested this before!!!! :thumb: :bow:
Currently Bikeless...*cry*
Offline MotoBug
« Reply #18 on: August 04, 2017, 07:42:31 PM »
Looks good. Have you had to use it in the wild? It's a pretty small footprint so using it on a dirt road and sloping or soft road shoulder might be hard on the nerves.
Offline malik
« Reply #19 on: August 05, 2017, 06:18:47 PM »
Yes, I've used it in the wild. Mostly on the Carberry - chain-driven final drive & a QD hub -I don't remember any problems. The 1100 Sport's sidestand is a delicate balance at best, & care has to be taken with siting - the weight is supported by the Lift & the side stand. Most bikes have a more centrally mounted sidestand than the 1100 Sport, and are much more straight forward. But even with the 1100 Sport it worked well, although I probably picked dead flat concrete or bitumen surfaces & removed the luggage. Would not be a problem with the V7.
