Author Topic: Glass beading my engine  (Read 3104 times)
Offline gearman
« on: August 13, 2017, 11:58:46 AM »
After trying various al. brightners I decided to just blast the engine.75 psi and large beads.
gif hosting
« Last Edit: August 13, 2017, 11:59:30 AM by gearman »
Offline Huzo
Re: Glass beading my engine
« Reply #1 on: August 13, 2017, 12:13:15 PM »
Have you been left with a nice "sheen" or has it gone flat and every time you touch it, you're left with smudge marks? It sure as hell looks like a good result...
« Reply #2 on: August 13, 2017, 02:41:45 PM »
That takes some work.  I'm whittling the blistered paint off a free engine case with the sandblaster.  I've got about 4 hours into it now and it still has reluctant patches.  So I understand the effort.
You might want to have it clear coated.  A zero or low-gloss clear powder coat will keep it looking like that for a long time.
Offline gearman
« Reply #3 on: August 13, 2017, 05:35:42 PM »
Yes the sheen is wonderfull. You get that by using the right size beads and not too high pressure.It is still new so it will weather. I see that someone here said to spray it with WD40 once in a while to keep the discoloring at bay.Any Ideas?RK, I thought about clear coat but am concerned about soft paint. I did my valve covers a few years ago and the metallic part softened and changed for the worse. Any body do rattle can clear?
Offline wrbix
« Reply #4 on: August 13, 2017, 05:47:41 PM »
I've always used walnut shell derived abrasive on mechanical parts for fear of glass or sand residua in the nooks and crannies. Walnut shells residua supposedly less damaging to moving parts.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
« Reply #5 on: August 13, 2017, 06:00:39 PM »
I said powdercoat, not paint.
Offline gearman
« Reply #6 on: August 13, 2017, 06:25:56 PM »
Powder coat means the engine would have to come apart. Right?
Offline Lee Davis
« Reply #7 on: August 13, 2017, 06:37:50 PM »
In my VW/Porsche engine rebuilding business we always glass beaded the heads before rebuilding. Made them look like new, but in a different sort of way. Never used walnut shells or other items like that, but I think that I would like to try. I am currently setting up a new shop and will make my own blasting cabinet and use glass beads to start on loopframe heads.
Loopframe rebuilder and Erotic Farmer
« Reply #8 on: August 13, 2017, 06:44:55 PM »
Yes, just like for proper glass beading.
Offline dsrdave
« Reply #9 on: August 13, 2017, 08:33:16 PM »
+1 on the walnut shells, a couple glass beads in the wrong spot (and it gets EVERYWHERE) can wreak havoc.  Amsoil metal protectant or wd40 every now an then helps retain the sheen.
Offline gearman
« Reply #10 on: August 14, 2017, 04:28:03 AM »
If you know what you are doing, you can do what I did.No need to take the engine apart. one hour of blasting vs ?????????
