Has anyone hung dual Dyna Coils on a Tonti, can you share how you did it?
Topic: Has anyone hung dual Dyna Coils on a Tonti, can you share how you did it? (Read 3316 times)
NCAmother
August 13, 2017, 12:29:21 PM »
I just had the heads on my 850T dual plugged, but I'm drawing a blank on to where to hang the dual dyna coils. I wanted to weld a bracket under the gas tank, but there's not enough room. (there probably is but I'm drawing a blank!) Any suggestions, pics would help me out a lot!!!
Cheers,
Mother
Last Edit: August 13, 2017, 12:30:09 PM by NCAmother
Howdy
charlie b
Re: Has anyone hung dual Dyna Coils on a Tonti, can you share how you did it?
Reply #1 on:
August 13, 2017, 01:40:52 PM »
When I got my T5 they were mounted inside the left side cover. I didn't think about it as I got it that way. The PO had mounted them such that one was up against the frame bar. Over time it wore a hole in the side and shorted the coil, which also destroyed the Dyna III module. I switched to VW coils and made a bracket to mount them under the left side cover.
redrider90
Reply #2 on:
August 13, 2017, 01:42:19 PM »
The Mille is the next generation of an 850T so I wonder what your 850T looks like. But this is where my Dyna's fit. And I believe I could put dual plug coils in that spot. right where the stock coils fit except you would need a different bracket/holder. But there is enough room.
Red 90 Mille GT
guzzista
Reply #3 on:
August 13, 2017, 02:17:03 PM »
On the T the original coils are positioned under the tank on frame provided brackets. I have Dyna coils in the same positions except that I used some angle aluminum from Lowes and fashioned brackets to fit. There are some Dyna brackets available for some Beemer applications made from galvanized steel, but you would need to mod those anyway so the aluminum angle is cheaper and cooler IMHO. The T sidecovers/ toolboxes would need some mods or completely be removed to allow mounting of coils ala T3/G5, LM1 etc
Guzzistajohn
Reply #4 on:
August 13, 2017, 04:56:35 PM »
how to upload photos to the internet
How bou dah?
Last Edit: August 13, 2017, 04:59:13 PM by Guzzistajohn
NCAmother
Reply #5 on:
August 13, 2017, 05:01:27 PM »
You guys are awesome
I have the beemer brackets, but they don't work, maybe modified. I'd like to stuff the coils under the tank but it looks like there is not enough space
Howdy
Two Checks
Reply #6 on:
August 13, 2017, 05:21:31 PM »
The tool boxes n the T take up the space where the coils are on the T5, etc.
Yep there is room between the cylinders.
1990 Cal III f/f "Il Duce' III"
1987 1000 SPII "Il Duce' II"
Chuck in Indiana
Reply #7 on:
August 13, 2017, 07:16:20 PM »
I've made brackets and mounted them under the side cover.. and under the tank. There is room to do either.
SED
Reply #8 on:
August 13, 2017, 11:54:48 PM »
Under left side cover. Made a plate that holds the bottom of both coils:
upload foto share link
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
mtiberio
Reply #9 on:
August 14, 2017, 07:25:59 AM »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
