Author Topic: Extracting a very recessed screw - completed!  (Read 11305 times)
Re: Extracting a very recessed screw
« Reply #30 on: August 14, 2017, 01:55:45 PM »
Trying to drill one out of the sump of the California II I ruined a couple of drill bits.
It turned out I was running the drill too fast, slowed it down to a crawl and it chewed through the head in no time.
Offline ITSec
« Reply #31 on: August 14, 2017, 02:30:21 PM »
Good tip. I'll have to be careful, since my right-angle drill is a single-speed, though slower than the top speed of my regular drill. I am still going to try the Torx trick first, as well as one I haven't seen posted yet (found it on another site). If the new trick works, I'll post it, but if it doesn't there's no point leading people to a blind alley.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Idontwantapickle
« Reply #32 on: August 14, 2017, 03:19:04 PM »
Nope, put a drill in you chuck backwards. Spin it in reverse and watch the flutes go down into the hole
Seriously? If that were true then cutting the head off of a bolt and flipping it over would make a left hand threaded stud. It just ain't so.
Spinning a drill bit backwards just makes a sharp bit dull.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline ITSec
Re: Extracting a very recessed screw - completed!
« Reply #33 on: August 14, 2017, 03:57:05 PM »
Well, since the Torx set still hasn't arrived, I tried the new trick - and it worked.
First, I took a long awl-tip tool and thoroughly cleaned the recess of the hex. I had previously sprayed it with solvent to ease this process. Next, I wrapped a small amount of aluminum foil around the tip of a long 5mm hex socket. I used enough to make the fit as snug as I could while still allowing the tool tip to bottom in the socket; the foil was ONLY on the side, BTW. This, combined with the cleaning, the solvent, and a careful hand on the wrench broke the screw free.
I saw a couple of variations on this method, using foil, rubber bands or cling wrap to fill the gap between the tool tip and the rounded head. It's a variation on the Torx approach, but it may be worth trying before sacrificing a tool or filling the hole with JB or other glues. It has the advantage of leaving all the other options open if it doesn't work.
Now to clean it and put it all together! Oh, and I didn't have to turn the bike over...  :azn:
ITSecurity
« Reply #34 on: August 14, 2017, 04:18:48 PM »
NICE!
Todd.
« Reply #35 on: August 14, 2017, 04:19:45 PM »
I'm disappointed.  We give you two pages of ideas, and you find something that works without our tender attentions.   :boxing:
Wait -- I meant goodonya!   :thumb:
Now you have to get those screws back up in the well.  I think that getting the pan back on was the longest operation of my entire engine swap.
Offline Chesterfield
« Reply #36 on: August 14, 2017, 04:23:19 PM »
I think what I am trying to explain is it will grab the screw if you make the outside points sharp with no center point, it not drill a hole. It`s not ideal, but has worked for me.  You don`t have to flip, it just makes it easier to get sharp points when I do.
Offline Adk.IBO
« Reply #37 on: August 14, 2017, 04:24:29 PM »
Good job :thumb:!!
Luke 23:34
Offline centauro
« Reply #38 on: August 14, 2017, 05:43:29 PM »
And now, when it all goes back together, don't forget to use some anti-seize on each screw, so this won't happen again.....
BTDT......
Val Barone
1984 1000 SP/NT (sold)
1985 Vespa PX150E
1973 Honda CB 350 Four
Offline not-fishing
« Reply #39 on: August 15, 2017, 06:02:17 AM »
Also on the stubborn screws, after I get them out I've been visiting my local Ace Hardware, buy the right size tap and chasing the holes.
Yes it's a belt and red suspenders sort of thing.
Mark
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #40 on: August 15, 2017, 07:58:06 AM »
Mark
Just good shop practice..
« Reply #41 on: August 15, 2017, 09:38:38 PM »
 1 If using a hand lock chuck on your drill motor, it is likely it will let go the drill when you try to use it with a reverse drill
 use an old fashioned chuck tightened with a key.
  2  learn to type in the width of your page so the rest of us don't have to scroll back and forth to read it.
« Reply #42 on: August 15, 2017, 09:56:40 PM »
Jim, the page width thing is your computer.  The screen resolution and zoom aren't set.  Assuming you're on a PC, use <ctrl - >(control and minus key) a tap or two to make it better.  If you make it too much better, the <ctrl + > will get you back.
Offline ITSec
« Reply #43 on: August 15, 2017, 10:16:28 PM »
Not exactly the case. There's a post on the first page of this thread that forces the page past normal limits, and as soon as you move away from that page it returns to normal. I haven't spent the time to figure out which post it is, but there's one there that has a forced arbitrary width attached.
ITSecurity
« Reply #44 on: August 15, 2017, 11:57:26 PM »
OK, I'll buy that.  I've been fixing it with the zoom, thinking it was the video driver.
Sorry, Jim.  It's not your set.  But the fix is still good.
