Author Topic: I need help..."Yes, we KNEW that!"  (Read 1733 times)
« on: August 21, 2017, 07:50:02 PM »
See the aluminum-colored small conical piece on the end of the LH grip?  I need one of those...looked thru parts catalogs and can't find the same thing so I'm guessing it was unique to the Stelvio handguard kit? I can take a close-up solo shot if necessary...would love to get another one to replace one that was lost somewhere between Datil and home...thanks in advance!
Offline lorazepam
  • Almost ready for suspenders
Re: I need help..."Yes, we KNEW that!"
« Reply #1 on: August 21, 2017, 08:00:43 PM »
I am sure there is a part number for it. Should use the parts look up on one of the vendors sites. They are pretty handy.
Offline pyoungbl
« Reply #2 on: August 21, 2017, 08:19:59 PM »
You are correct, the part does not show up on the AF1 Racing parts list.  I lost the same part on my Stelvio so I turned a new one on the lathe.  That does not help you much but maybe you have a machinist friend who can make one for you.
'13 V7 Special (red/white)
« Reply #3 on: August 21, 2017, 09:31:36 PM »
AP8121819       says it's a washer
« Reply #4 on: August 21, 2017, 09:43:19 PM »
Thank you again!! That's it...
Offline ITSec
« Reply #5 on: August 21, 2017, 11:00:30 PM »
So, when Guzzi says "Special Parts", it means all the NTX accessory package stuff! Good detective work there, Steve!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline BAT 11
  • Do it today, tomorrow may be too late!
« Reply #6 on: August 22, 2017, 01:24:10 AM »
lost mine on right returning from ACT. temp fix with insulation tape,then drilled a Aussie gold coin on both sides  to match and slid a cutoff tubeless valve base i found in plenty outside the tyre fitters over the bolt head,very unique! works a treat.
